Kiltox Posted June 5, 2025 Author Posted June 5, 2025 This is working but does look shit. Would recommend. F1 Autocentres has a deal for 15% off 4 tyres bringing a set of Uniroyals down to £300 - cheapest decent tyres I’ve found so far. CGSB, wuvvum, Matty and 3 others 6
SiC Posted June 5, 2025 Posted June 5, 2025 Hard to say for no at that price as a general half decent tyre.
Kiltox Posted June 5, 2025 Author Posted June 5, 2025 Kumho KH52s are £50 less and get better reviews, thoughts?
SiC Posted June 5, 2025 Posted June 5, 2025 Having had both I'd side towards Rainsports as being better tyres. Kumho are decent for your average commuter runaround (like the set I put on the E320 I had/now cookiesouthwest) but I don't rate them for good handling. loserone 1
Andyrew Posted June 5, 2025 Posted June 5, 2025 1 hour ago, Kiltox said: Kumho KH52s are £50 less and get better reviews, thoughts? My kumho budgets are cracking at under a year old. Supplier suggested its normal wear and tear. Given the 40 odd part worns of various ages I've fitted didnt and don't have any cracks in them I just going with the kumhos being shite. Kiltox and mk2_craig 2
Schaefft Posted June 5, 2025 Posted June 5, 2025 6 hours ago, Kiltox said: This is working but does look shit. Would recommend. F1 Autocentres has a deal for 15% off 4 tyres bringing a set of Uniroyals down to £300 - cheapest decent tyres I’ve found so far. I've used these to pin up the headliner of the Senator. It's matching the fabric so it's one step above the shit looking pins people usually use so not too terrible. Matty and Kiltox 2
Kiltox Posted June 6, 2025 Author Posted June 6, 2025 Anyone got any tips on how to find out for sure what type of battery should be in the Vel Satis? It has a 096 in at the moment, which needs replacing. Tayna says it should be a 115 which is quite a bit bigger (but shorter) - also recommends a 110 as an alternative. GSF also recommends a 115 ECP try to sell me a 096 which is presumably why it's got one in
beko1987 Posted June 6, 2025 Posted June 6, 2025 096 will be too small. I fell foul of this in the qashqai (good deal on the size, the spec was still decent enough)and ended up with some spare room in the engine bay 😂 I'd go 115. I'm getting away with it as my car isn't too electrically heavy*, you'd notice it on a vel shatis eventually I'd imagine. Kiltox 1
Kiltox Posted June 6, 2025 Author Posted June 6, 2025 Will collect a 115 from GSF and see if it fits, easier to return if it doesn’t. Clio is getting some Uniroyal goodness tomorrow. Cookiesouwest, dome, IronStar and 2 others 5
MrBig Posted June 6, 2025 Posted June 6, 2025 On 05/06/2025 at 10:15, Kiltox said: This is working but does look shit. Would recommend. The very ethos of these hallowed pages, non? Rainsports are one of my go-to tyres. Very good in the wet (duh) and pretty good in the dry. They are quite soft so you don't get the mileage you might do on a Contisport or similar, but the significantly lower price more than offsets that. Matty 1
Kiltox Posted June 6, 2025 Author Posted June 6, 2025 9 minutes ago, MrBig said: The very ethos of these hallowed pages, non? Rainsports are one of my go-to tyres. Very good in the wet (duh) and pretty good in the dry. They are quite soft so you don't get the mileage you might do on a Contisport or similar, but the significantly lower price more than offsets that. It’s the bias towards wet that puts me off a little for a car I’ll primarily be kicking the cunt out of in the dry, but they do seem better then most other options at the same price point Matty and MrBig 2
loserone Posted June 6, 2025 Posted June 6, 2025 Whilst they are mostly fine in the wet, they're certainly not an all season tyre and are very much a summer tyre. I don't think you'll have any issues with em. Kiltox and Matty 2
wuvvum Posted June 6, 2025 Posted June 6, 2025 1 hour ago, beko1987 said: I'd go 115. I'm getting away with it as my car isn't too electrically heavy*, you'd notice it on a vel shatis eventually I'd imagine. I've got an 096 in the C Class (was originally an 019), that's a 3-litre V6 diesel with reasonably complex electrics and it's been absolutely fine. Matty and beko1987 2
Kiltox Posted June 6, 2025 Author Posted June 6, 2025 Have also ordered an AC pressure switch for the Shatis to see if it fixes it AnnoyingPentium, yes oui si, Dave_Q and 4 others 7
Kiltox Posted June 6, 2025 Author Posted June 6, 2025 Can confirm that 096 is the right battery - though there's a little spare room it definitely won't take a 115. beko1987 1
Kiltox Posted June 6, 2025 Author Posted June 6, 2025 Replaced the Vel Satis AC pressure sensor and still have no air con but can see the pressure using my scan tool now - and it’s low (but not zero). Wonder if a regas m8 would now fix it 🤔 Another issue I need to look at is that the passenger side window and mirror don’t work. With it being both of them I worry that the door loom is damaged 🙈 privatewire and beko1987 2
Kiltox Posted June 7, 2025 Author Posted June 7, 2025 Tyre booking is actually for tomorrow 🤦♂️ obviously only discovered this after sending it there. Driver was moaning at me that there was fuck all fuel in it - seems the sender got all #justcliothings because after he put a couple of gallons in the gauge shot up to well over half a tank 🤷♂️
loserone Posted June 8, 2025 Posted June 8, 2025 Needs the stiffer sidewalls to make sure you can't exceed 30 on a country road
Kiltox Posted June 8, 2025 Author Posted June 8, 2025 The OE 80 load rating seem to be pretty hard to come by these days.
beko1987 Posted June 8, 2025 Posted June 8, 2025 Love those wheels! Get some bilt hamber korrosol on them!
Kiltox Posted June 9, 2025 Author Posted June 9, 2025 Feeling like I’ve bitten off more than I can chew with the Vel Satis. It needs a lot of time spent on its various faults when I really just want it to do comfy barge things. Might appear for sale soon tbh, but I’m not sure I’ve really ticked that particular box if I’ve only driven one that’s a bit shagged. yes oui si and loserone 2
Kiltox Posted June 10, 2025 Author Posted June 10, 2025 This though, is excellent. Took it out last night and kicked its fucking head in and the difference on the new rubber is considerable. A fair old snagging list is building though, but that’s not exactly unexpected AnnoyingPentium, FakeConcern, IronStar and 10 others 12 1
320touring Posted June 10, 2025 Posted June 10, 2025 BRWAAAAP! be aware that they are such good fun when working that you'll keep on fixing it... dome and SiC 1 1
wuvvum Posted June 10, 2025 Posted June 10, 2025 9 hours ago, Kiltox said: This though, is excellent. Took it out last night and kicked its fucking head in and the difference on the new rubber is considerable. A fair old snagging list is building though, but that’s not exactly unexpected So used to driving milkfloats that you automatically head for the Pod Points even when you're in a proper car... yes oui si, FakeConcern and SiC 3
beko1987 Posted June 10, 2025 Posted June 10, 2025 They should build 12v jump points into them for the caught out shitter, their sat there powered anyway. Open a hatch, connect jump leads, fire her up then don't stall again
brownnova Posted June 10, 2025 Posted June 10, 2025 On 05/06/2025 at 10:15, Kiltox said: This is working but does look shit. Would recommend. This excellent consumer advice has got me purchasing one for my latest purchase which has the saggiest headlining of any car I have ever owned. Kiltox and yes oui si 2
Kiltox Posted June 10, 2025 Author Posted June 10, 2025 13 minutes ago, brownnova said: This excellent consumer advice has got me purchasing one for my latest purchase which has the saggiest headlining of any car I have ever owned. It has been surprisingly effective, well beyond my expectations for a fiver
Kiltox Posted June 10, 2025 Author Posted June 10, 2025 11 hours ago, Kiltox said: A fair old snagging list is building beko1987, yes oui si, IronStar and 1 other 4
