I've done a silly......CITROEN XM
8 minutes ago, richardmorris said:
Ah capt. hindsight ;-)
i had no idea it had the wrong alternator on it haha
tbh it should be up and running on tuesday
battery light fades in and out when running, soooooo that's due to the belt slipping as it's the wrong size, i reckon it's working
The battery light on my cx glowed in the dark with the headlamps, ac and radio on.
this never did until recently
but i reckon with proper belts this should work well
I take your point but would have made sense to change it at the same time. I wasn't aware there was a fairly new one fitted though.
oh yes, the old one had shredded so got a new one fitted when i got the belt done
still, getting close!
well an update.....
i fixed it!
No description available.
that's a good solid voltage too in my opinion!
what an absolute bastard of a job this is
still a nice shiny new one and all is well
done around 40 miles testing and all works well
blower fan is working correctly too!
38 minutes ago, High Jetter said:
Get in! How good does that feel?
Painful
im bruised
I wonder what’ll go wrong next 😂
7 minutes ago, High Jetter said:
Don't we all! 🤣
It’ll be an abs fault
as far as I know you can’t get the sensors new anymore
i imagine fitting second hand abs sensors will be great fun
Depends. Iirc i found a direct replacement for the brand of sensor that was fitted to early S1s (Bendix?), though it may have the wrong connector and will need the original one transplanting - when i get round to fitting it. My car should have ABS but it's only get 3 sensors and the ABS doesn't even light at switch on, so i suspect it's been disabled by a previous owner.
The later Teves sensors are easier to source new, again iirc
Very trim! (Anyone else thought they looked like weird valve heads in the first pic?)
be a bloody big engine!
I thought crank pulleys.
15 hours ago, High Jetter said:
OK, only me then. What is that golden cloth?
they're just own brand anti bacterial wipes, i bought them cos they were cheap
i must admit i kinda want to take this for one of those "health check" things
just want someone to give it a good going over and see what hilarity there is wrong with it
i know for an absolute fact at this moment it will fail an MOT
Ignorance is bliss. Well until it’s too late of course.
i've been using it for my rush hour commute to my new job all this week
no issues*
i think i've got an earth issue on the rear lights, but otherwise it's all fine and still seems to be charging it's battery!
Catching up - I thought they were fancy wheel trims  then decided they were aircon pulleys
May be an image of car and road
well, staggeringly, it's not broken yet!
drove it in a bit of slushy snow today, on summer tyres, goodyear efficient grips on the front and michelin energies on the rear
verdict
shit, not that much grip and had a very exciting moment of going down a hill, hit the brakes and all that happened was the abs kicked in and the car unsettled itself, which was fun!
otherwise it's doing well!
  • Like 8
1 hour ago, RoverFolkUs said:
Old school 90s ABS can be frightening at the best of times 😂
It works surprisingly well, it locks up for a little moment and then kicks in
But it’s a bit slidey on these summer tyres, I’ll certainly use the Michelin crossclimate equipped C5 during the worst weather
2 hours ago, Lacquer Peel said:
What a class act this car is. ❤️
I’ve owned it for 8 months now
what a weird 8 months that’s been, took a while to properly love the car and now I’d not be without it
