twosmoke300 Posted September 11, 2021 Author Posted September 11, 2021 31 minutes ago, Spurious said: Isn't it quite common for people to be fiddling with the Positive Crankcase Ventilation system on these thinking it'll somehow improve performance? Like you said there's bloody loads of pipework in these engines. Maybe someone had a go and didn't do a right job. It doesn’t look messed with at all . So hopefully that won’t be the case . Just wish I had more time to fiddle
Matty Posted September 11, 2021 Posted September 11, 2021 16 hours ago, twosmoke300 said: It’s roughly the same temp front n rear and plenty exhaust pressure out back . Did notice when moving it in the yard today that the brake pedal was very hard so I’m putting money on a vac leak but fuck me dead these 1.8t motors have hundreds of vac pipes . Don't they just, done a few and don't want to revisit. Otherwise bullet proof that engine. Window regs and door latches aside its a tough car that mk4 platform. I reckon you're going to become a convert and start saying what a great car this era of vag product was 😁 Next @sierraman buys a mk5 golf diesel and really rates it 🤣 stripped fred and twosmoke300 2
Matty Posted September 11, 2021 Posted September 11, 2021 Don't ask, just about to delete them all mintwth 1
sierraman Posted September 11, 2021 Posted September 11, 2021 9 minutes ago, Matty said: Don't they just, done a few and don't want to revisit. Otherwise bullet proof that engine. Window regs and door latches aside its a tough car that mk4 platform. I reckon you're going to become a convert and start saying what a great car this era of vag product was 😁 Next @sierraman buys a mk5 golf diesel and really rates it 🤣 Don’t be so ridiculous. 🤣 Matty and twosmoke300 2
twosmoke300 Posted September 11, 2021 Author Posted September 11, 2021 Can’t see that ever happening . Matty 1
twosmoke300 Posted September 11, 2021 Author Posted September 11, 2021 I’ve actually owned a couple of vag group cars in the past . A 98 golf 1.9tdi pre pd. Dissapointing on fuel and a wet blancmange to drive . Skoda Octavia mk2 estate 1.9 pd 105 . Ex wife still has this and it’s actually been a bloody good car . I put a set of shells in it as a pre emptive strike as it’s the known troublesome BLS / BXE code engine but they were like new . Good on fuel , not fast but adequate. An overall good practical car . Another mk1 Octavia in low spec petrol form . Meh . 1972 beetle 1300 . As horrible as you can imagine but I was young and the ladies loved it Couple of Early 90’s Audi 80’s . Now these were bloody great cars . The cars where vag built their reputation. Think that’s it but I expect I might remember a few more at some point .
phil_lihp Posted September 11, 2021 Posted September 11, 2021 3 hours ago, twosmoke300 said: It doesn’t look messed with at all . So hopefully that won’t be the case . Just wish I had more time to fiddle Confirmed, no I have never touched it. twosmoke300 1
twosmoke300 Posted October 7, 2021 Author Posted October 7, 2021 Finally got some time to fiddle with this ( the apprentice has been off for nearly 3 weeks with the 'rona ) I think it might be fixed subject to road test. Initial fault was running massively lean , Checked all the obvious vac and breather hoses all ok. Hooked up a vac gauge to the manifold and it was only pulling 5in of vac at idle when it should be 20ish- smoke test and pressure test the inlet , all ok Took the primary lambda sensor out to allow some exhaust flow to eliminate blocked cat , no difference. I noticed if i fed some map gas into the inlet the vac would rise and run better . That made me go down a rabbit hole of checking fuel pressure etc but all tested perfect. Every thing on live data reading ok bar some dodgy map sensor readings I noticed if I put a piece of card over the inlet I could get decent vac and stall the engine so no massive leaks . I did a throttle body adaptation on VCDS and fuck me dead , 18 in of vac at idle . Jesus wept But it wasnt happy and still showed a cyl 1 misfire . Changed the plugs as they must have been getting silly hot with all the lean running but still lumpy. The coil packs had already been changed with new Delphi ones but the old ones were in the boot so swapped it over and BOOM ! sweet as a nut. What a fucking mission . TLDR VAG are over complicated and Delphi are a bit wank stripped fred, wesacosa, Agila and 14 others 17
Agila Posted October 7, 2021 Posted October 7, 2021 You iz top mekanik m9. If I ever buy any bastard vag shite I know where to bring it. What's your address again?? 😆 twosmoke300 1
Flat4 Posted October 7, 2021 Posted October 7, 2021 So the faults were a throttle body and dodgy coil pack? I'd call that a result!
twosmoke300 Posted October 7, 2021 Author Posted October 7, 2021 And a day of my life I won’t get back 😂 Tickman 1
phil_lihp Posted October 7, 2021 Posted October 7, 2021 Nice one, well done! I swapped all the coil packs over for the old ones and it made no difference but then again if the throttle body was faulty as well, guess it wouldn't have helped much. Good work, it evidently went to the right person.
twosmoke300 Posted October 7, 2021 Author Posted October 7, 2021 I don’t think the TB is faulty just needed setting up . Pain in the ass . Every day is a school day
phil_lihp Posted October 7, 2021 Posted October 7, 2021 2 hours ago, twosmoke300 said: I don’t think the TB is faulty just needed setting up . Pain in the ass . Every day is a school day That would never have occurred to me, never heard of that being a thing - the garage who were investigating it were planning to move on to fuel system tests if I'd wanted to continue so I can be fairly confident there would have been some serious chargeable hours of diagnosis before/if they got to that. The throttle body hadn't changed, though - it wasn't removed or fiddled with that I can think of. Anyway, good that you found the problem, hopefully it'll live on for a while yet - despite its miles, before this occurred, it was a really nice car to drive.
twosmoke300 Posted October 7, 2021 Author Posted October 7, 2021 I wonder if the tb adaptations had adjusted to the other leaks they found and once they were fixed it was waaayyyy out of spec . phil_lihp, SiC and stripped fred 3
