suzuki gs 1000 - Picture 1 of 6
suzuki gs 1000 | eBay UK
Surely that's not a GS1000S tank, and the least said about that seat the better.
https://www.mathewsons.co.uk/auction/lot/lot-876---2008-toyota-rav4-xtr-d-4d/?lot=55089
"MOT Expiry Date: EXPIRED - 08/03/2026"
Not strictly true that gents*
'FAILED
Test Date 19/03/2026
Mileage 154548
+6252 miles travelled since last MOT.
Comments
Nearside Rear Registration plate lamp insecure (4.7.1 (c) (i)) MINOR
Offside Rear Registration plate lamp insecure (4.7.1 (c) (i)) MINOR
Offside Front Suspension component mounting prescribed area excessively corroded significantly reducing structural strength (5.3.6 (a) (i)) MAJOR
Steering rack has excessive free play detected at the steering wheel (steering rack fitted) (2.3 (a) (i)) MAJOR
Nearside Front Suspension arm ball joint dust cover no longer prevents the ingress of dirt (5.3.4 (b) (ii)) MAJOR
Offside Front Suspension arm pin or bush worn but not resulting in excessive movement (5.3.4 (a) (i)) ADVISORY
Nearside Front Headlamp has a product on the lens but not seriously reducing light output (4.1.4 (b)) ADVISORY
Offside Front Headlamp has a product on the lens but not seriously reducing light output (4.1.4 (b)) ADVISORY'
Hmmm
  • Sad 2
16 hours ago, eddyramrod said:
Thank you; we have seen this one before, and it's way overpriced.  Gorgeous though, and I'd love to know what those rear lights are from, because one thing they absolutely aren't is original.
Late 40s early 50s yank at a guess. ( They're vaguely familiar) Scott at coldwarmotors in Canada will probably know.
GSX tank.
A popular mod 30 years ago to fit the larger GSX tank to your GS for continental touring.
Ask me how I know.
(Seat is gopping!)
6 hours ago, grogee said:
I love it.
Me too. It’s like brutalist architecture but with (I’m guessing) 6 and 3/4 litres of v8
49-54 Chevy tail lights  (knew they rang a bell in my pornagrahpic memory)
I must have subliminally reminded you 😉
7 hours ago, sheffcortinacentre said:
You must be psychiatric.
Every little helps 🙃
10 hours ago, Cavcraft said:
That's ace!
IIRC a feature somewhere of a Minor with a Pug diesel FWD ... 🤔
On 10/04/2026 at 18:17, Cavcraft said:
That looks class. Hopefully someone can save it by fixing the gearbox.
Pezz manual version sold yesterday @ AAC auction,
Other stuff had a few silly prices but mostly seemed sensible - place looked half empty by 4pm
Rover 25 1.4. 26,000 miles. MOT is due on 18th June. Looks OK for £1,350.Screenshot_20260412-112026.png.454e14cdf6f0761ee4b6ff7c0162be09.png
18 hours ago, sheffcortinacentre said:
There were a handful in early MK3 shells I believe
Yes and the shell is the right age with the oval hole on the rear of the back seat metalwork.
The lack of boot board brackets suggests the shell is a base model 850 or 1000 though.
The engine in the car is a small bore one so not a cooper S and the seperate engine is weird with the block mounted oil filter which I ve only seen on Morris Marina in line engines and the last Rover mini multi point injection engines but its not one of those as they didnt have a distributor hole.
If had to guess I would say its a mini 850 or 1000 and at somepoint someone has fitted some cooper S bits like the twin tanks and has the description on the logbook changed to Cooper S which was then put down on the V5 when they were computerised.
Back then no one cared that much and I ve seen a few minis listed as cooper or cooper s on the logbook but with an 850 or 1000 chassis number where this has happened.
I bet it’s quite economical?!
I’ve had a few xuds and I’ve had a moggy… I loved them all but I’m not sure if I’d like to combine the two.
