13 hours ago, grogee said:
Petrol sponge
LOL! 🤣 I'm going to use that one a lot.
6 minutes ago, grogee said:
These go through engines if they use the CAVE code IIRC. A lot are running on replacement engines.
21 hours ago, cort16 said:
Cracker of a Sierra. Why was the 2.0 twin cam so hated at the time?
Google it. It was shite and blew a lot thanks to under development by ford.
https://www.ebay.co.uk/itm/324970009101?hash=item4ba9b8d20d:g:iBgAAOSwMmRhzuWD
When new, I remember the Twin Cam feeling smoother and faster than thePinto , this was usually in Granadas. I head a few Sierras when 5-10 years old and only ever had one head gasket go. Even then it was still running fine , just using a lot of water and showed up on one of those bubble analyser things. I just swapped the engine for a low mileage one, took half a day including looking for spanner’s etc- and I’m the Worlds worst mechanic.
My Mrs had a beautiful 2.0 GLSi hatch on a J that when we picked up my brother’s first Sapphire Cossie, actually pulled away from it up to to 120 ish- but then what do you expect from £2000 Cosworths- that ended up with 300 bhp supposedly, then got nicked!
2 hours ago, Shite Ron said:
This would make a nice project for someone, @vulgalour?
https://www.ebay.co.uk/itm/165262033386?hash=item267a6281ea:g:87YAAOSw8VBh0Eqi
It is a 2.0HLS so quite posh.
That's a pretty honest ad.  With Ambassadors, it's completeness that's key. Rot can be dealt with, but Ambassador specific things like trim and all the front sheet metal are very hard to get hold of.  2ltr twin carb with power steering is a nice spec for one of these, and if it does have good displacers, it's worth getting just for that.  I'm tempted, but I don't have dry storage for it which it really does need to stop it getting worse.  New windscreens are still available from Pilkingtons.
I love these although I appreciate they take a bit of looking after. They're probably not going to go down in value now.
Fiat Coupe turbo, 95k, £3795 Notts
https://www.gumtree.com/p/cars-vans-motorbikes/1996-fiat-coupe-20v-turbo-12-months-mot-appreciating-classic-excellent-condition/1422637758?utm_source=com.atomczak.notepat&utm_medium=social&utm_campaign=socialbuttons&utm_content=app_android
8 minutes ago, grogee said:
I don't like those wheels on it, but it looks nice otherwise. :)
Ford Fiesta Mazda 121 with a b0rked ignition barrel. How on earth do you break an ignition barrel just by putting the wrong key in? Was the ignition made of cheese? Was the incorrect key inserted using a hammer?  I dunno. It's £500 either way...
https://www.facebook.com/marketplace/item/597318034664074
May be an image of car and outdoors
Slightly more interesting* than the equivalent Fiesta, if only for the curio value of Mazda badged cars coming out of Dagenham. Unfortunately fitted with the wheeziest of the engines. Not sure if all the 121s had this or whether Mazda offered the 1.25/1.4 as well.
Ignition barrel easy to change but ECU needs original key chip to disable immobilizer. Do-able but faffy especially if it's rusty which it probably is
