Mate of mine had a Ferrari rep years ago based on a MK3 MR2. It looked OKISH to be fair but of course wore the Toyota mechanicals underneath. When another one of the lads was telling me a story about it he said it was insured for £60k.......
about twice the price of a genuine one at the time.
https://www.ebay.co.uk/itm/Mercedes-S430-V8/123600558304?hash=item1cc72ad8e0:g:3kEAAOSwHDJcQDlc
Do not drive until repaired (dangerous defects):
  • Nearside Front Shock absorbers likely to become detached lower ball joint (5.3.2 (a) (ii))
  • Offside Rear Seat belt anchorage likely to become detached in the event of a collision jacking point (7.1.1 (a) (ii))
  • Offside Front Track rod end ball joint has excessive play (2.1.3 (B) (i))
  • Nearside Front Track rod end ball joint has excessive play (2.1.3 (B) (i))
  • Offside Front Shock absorbers insecurely attached lower balljoint (5.3.2 (a) (i))
  • Offside Rear Upper Suspension arm pin or bush excessively worn (5.3.4 (a) (i))
  • Offside Rear Upper Suspension arm ball joint excessively worn (5.3.4 (a) (i))
  • Nearside Rear Seat belt anchorage prescribed area strength or continuity significantly reduced side sill (7.1.1 (a) (i))
  • Offside Front Headlamp has a product on the lens but not seriously reducing light output (4.1.4 (B))
  • Rear Tyre worn close to legal limit/worn on edge both (5.2.3 (e))
  • Front Brake pipe corroded, covered in grease or other material both (1.1.11 ©)
  • Rear Direction indicator slightly discoloured both (4.4.3 (a))
What's all that 'likely to be detached' etc stuff about, needs welding?
