http://www.ebay.co.uk/itm/1983-Dodge-Maxi-Custom-Van-/302486634743?hash=item466d9bc0f7:g:eesAAOSwwqBZ4Jk-
'She was converted from new by the "Van House" in Lincoln Nebraska'
'100% original and unmolested she is just as she was the day she left the "Van House"'
'she has had 4 new Dunlop tyres with white letters, a new alternator and voltage regulator, new universal joints, new fuel and air filters, plugs, Leads, coil, rotor, distributor cap and PVC valve'
So, apart from the tyres, alternator, regulator, universal joints, fuel and air filters, plugs, leads, coil, distributor cap and PCV valve, she is 100% original and unmolested just as the day she left Van House?
'The body is all but totally rust free, there is one spot on the passenger side rear corner'
So, apart from the tyres, alternator, regulator, universal joints, fuel and air filters, plugs, leads, coil, distributor cap, PCV valve and rust spot, she is 100% original and unmolested just as the day she left Van House?
'Inside is all original the only thing missing is one captains chair'
So, apart from the tyres, alternator, regulator, universal joints, fuel and air filters, plugs, leads, coil, distributor cap, PCV valve, rust spot and missing captain's chair, she is 100% original and unmolested just as the day she left Van House?
'The only thing that lets her down inside is both front seat bases where damaged during import, they have both got splits on the seems hence the seat covers.'
So, apart from the tyres, alternator, regulator, universal joints, fuel and air filters, plugs, leads, coil, distributor cap, PCV valve, rust spot, missing captain's chair damaged seats and new seat covers, she is 100% original and unmolested just as the day she left Van House?
'There are a couple of jobs that will need doing over the winter, the electric windows need work, they go up and down but need help, hence why the door cards are removed, the speedo doesn't work ( I'm pretty sure it's the short cable that runs from the bulkhead to the dash) I use an app on my phone as a speedo, the carb has a flat spot and if your fussy it will want some valve stem seals as it puffs a bit of blue smoke out when started hot.'
So, apart from the tyres, alternator, regulator, universal joints, fuel and air filters, plugs, leads, coil, distributor cap, PCV valve, rust spot, missing captain's chair damaged seats, new seat covers, shonky electric windows, non-working speedo,removed door cards, flat spot and smoking engine, she is 100% original and unmolested just as the day she left Van House?
'if you have any questions'
Is she 100% original and unmolested just as the day she left Van House?
http://www.ebay.co.uk/itm/2005-51-Renault-Laguna-3-0-V6-24v-initiale-estate-Automatic/222676380225?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
No pics because I'm slightly intoxicated but £695 for an 05 Laguna 3.0 initiale auto estate MOT'd until next May with 54k on the clock, located walking distance from me and I'm on my 5th Gin and Tonic???
Please God don't let me wake up in 7 hours to the inevitable hangover and deep sense of foreboding that I have pressed Buy it now.
That's not the first rear window louvre I've seen on a Princess, this is.
So who made them?  Where can I buy one?
IIRC they were made by a company called Auto-Plas way back in the 70s.  I very much doubt you can buy one new these days, but you might drop lucky scouring the "used" market.  Be patient and keep your wallet full though, you'll need both attributes!
