The number plate house number is a new one on me
Ah, but not to me, since I used to live right by this masterpiece:
http://www.ebay.co.uk/itm/VOLVO-COACH-1985-B-reg-FANTASTIC-CONDITION-no-reserve-/172691729659?hash=item28353aacfb:g:VswAAOSw~FJZJLvT
'More pictures are available upon request'
​No, honestly, that's good enough on it's own. I mean, God forbid anyone would actually want to see a picture of the fucking coach, instead of your wife's make-up chart.
Woe to you, oh Auto and Shite, for ebay sends this wank  with a laugh,
Because he knows the time is short...
Let him who hath understanding reckon the number of the yard
For it is a massive scrapper,
Its a number 2, shit hundred and shitty shit
http://www.ebay.co.uk/itm/Chrysler-PT-Cruiser-Hotrod-/322527292345?hash=item4b181febb9:g:0h0AAOSwi7RZJUbm
'This car won the largest PT Cruiser show in Europe in 2013'
It looks the same size as every other one?
'1st place in Picnic in the park'
If you had a picnic in the fucking lion's enclosure at Knowsley Safari Park, it still wouldn't win an award. Though I concede, the results would actually look far nicer than this affront to decency and eyesight.
1976 Classic Jaguar XJ 3.4 barn find Runs and drives
http://www.ebay.co.uk/itm/1976-Classic-Jaguar-XJ-3-4-barn-find-Runs-and-drives/302318727496
looks dulux'd
untaxed since 1989, check out that interior
£625 at 25 bids and 1d 20h to go. not sure sella understands concept of auction
£1,600 will let you take this vehicle home.
1998 JAGUAR XJR V8 AUTO GREEN
http://www.ebay.co.uk/itm/1998-JAGUAR-XJR-V8-AUTO-GREEN-/172689589959
Been off road for 3 years
parked in long grass, yep that will do it a shit load of good
Interior, engine and gear box in excellent working order
Rear diff is broken
thrashed mercilessly
Body damage to roof, bonnet and boot lid (included in sale a spare boot lid)
someone been car walking?
No rust on body work whatsoever
awesome
Has some rust on strut tops that need attention
verdict = totally fucked your Jaaaaag
And it has more than one owner. I know, because I toyed with buying this one and then read the MoT history and realised this was a rustbucket, no contest, and the last no advisory MoT was impossible unless they rebuilt the car from scratch within a matter of days.
Stick your £375 for a month's MoT up yer arse, you opportunistic leach
https://www.gumtree.com/p/nissan/nissan-micra-1-owner-from-new/1242821020
A 5-door 16v GTa?  Rarer than a GTi.  Want.
Registration number: J61CNN
  • Vehicle makeROVER
  • Vehicle modelMETRO
  • Date first used29 August 1991
  • Fuel typePetrol
  • ColourBlue
MOT history of this vehicle
  • Test date31 May 2016
  • Expiry date31 May 2017
  • Test ResultPass
  • Odometer reading54,210 miles
  • MOT test number1908 5510 4526
  • Advisory notice item(s)
    x2 front tyres worn on inner edges.
    unable to fully inspect front brake pads!
    Offside Front Subframe mounting prescribed area is corroded but not considered excessive sill (2.4.A.3)
    Offside Front Brake pipe slightly corroded (3.6.B.2c)
  • Test date1 June 2015
  • Expiry date31 May 2016
  • Test ResultPass
  • Odometer reading51,574 miles
  • MOT test number8258 7295 5106
    Offside Front Upper Front suspension ball joint dust cover deteriorated, but preventing the ingress of dirt (2.4.G.2)
    Both front tyres wearing on inner edges.
  • Test date1 May 2015
  • Test ResultFail
  • Odometer reading51,570 miles
  • MOT test number9266 3122 5196
  • Reason(s) for failure
    Nearside Front Subframe mounting prescribed area is excessively corroded (2.4.A.3)
    Offside Rear Subframe mounting prescribed area is inadequately repaired (2.4.A.3)
    Nearside Rear Radius arm has excessive play in a pin/bush (2.4.G.2)
    Offside Rear Radius arm has excessive play in a pin/bush (2.4.G.2)
    both front tyres worn on inner edge
  • Test date6 May 2014
  • Expiry date5 May 2015
  • Test ResultPass
  • Odometer reading50,667 miles
  • MOT test number2789 0662 4101
    Both front tyres worn on inner edge
    Both front tyres perishing
  • Test date28 April 2014
  • Test ResultFail
  • Odometer reading50,664 miles
  • MOT test number5673 0811 4113
    Offside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
  • Test date27 April 2013
  • Expiry date26 April 2014
  • Test ResultPass
  • Odometer reading46,040 miles
  • MOT test number2252 1791 3134
    Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
    both front tyres worn on inside edges
  • Test ResultFail
  • MOT test number3063 5741 3127
    Hazard warning switch faulty (1.4.B.1d)
  • Test date12 April 2010
  • Expiry date11 April 2011
  • Test ResultPass
  • Odometer reading43,398 miles
  • MOT test number9940 6210 0140
    Exhaust has part of the system slightly deteriorated (7.1.1a)
    Nearside Rear Suspension arm has slight play in a pin/bush (2.4.G.2)
    Offside Rear Parking brake: parking brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.D.4)
    Offside Rear Service brake: service brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.D.4)
    corrosion on outer sill
  • Test date8 October 2008
  • Expiry date7 October 2009
  • Test ResultPass
  • Odometer reading42,965 miles
  • MOT test number8412 5278 8276
    Corrosion on both outer sills and wheel archs but not considered excessive
    Nail in nearside front tyre
    Fuel filler neck corroded
    Rear brake hose ferrules slightly corroded
  • Test date29 September 2008
  • Test ResultFail
  • Odometer reading42,959 miles
  • MOT test number3411 5327 8400
    Nearside Outer Rear Subframe mounting prescribed area is excessively corroded (2.4.A.3)
    Offside Outer Rear Seat belt anchorage prescribed area is excessively corroded (5.2.6)
    Offside Rear Brake pipe excessively corroded (3.6.B.2c)
    Nearside Front Brake pipe excessively corroded (3.6.B.2c)
  • Test date8 October 2007
  • Expiry date7 October 2008
  • Test ResultPass
  • Odometer reading41,092 miles
  • MOT test number9225 8148 7217
    Nearside Rear Radius arm has slight play in a pin/bush (2.4.G.2)
    Offside Radius arm has slight play in a pin/bush (2.4.G.2)
    corrosion on off side outer sill and rear wheel arch
  • Test date7 October 2006
  • Expiry date6 October 2007
  • Test ResultPass
  • Odometer reading39,051 miles
  • MOT test number3101 2058 6293
    front suspension slightly low
  • Test date28 September 2006
  • Test ResultFail
  • Odometer reading39,032 miles
  • MOT test number4130 2157 6210
    Offside Subframe mounting prescribed area is excessively corroded (2.4.A.3)
    petrol tank corodded
    offside rear wheel arch corodded
  • Test date13 September 2005
  • Expiry date28 September 2006
  • Test ResultPass
  • Odometer reading37,635 miles
  • MOT test number3131 8625 5273
  • Test date8 September 2005
  • Test ResultFail
  • Odometer reading37,614 miles
  • MOT test number3544 7105 5453
    Nearside Stop lamp not working (1.2.1b)
    Exhaust has a major leak of exhaust gases (7.1.2)
    outer sills and offside rear wheel arch slightly corodded
    slight play in rear radius arm bushes
