I bet they go like stink. My 1.6 16V feels fast enough for a 1.6 so with the extra power? Is it the same engine as the VX220 ?
2.2i 16V SRi 3d (AC)
7.9 secs
133 mph
144 bhp
According to parkers.
Not slow.
I had a series 1 Astra SRi with steelies and plastic trims (which all got nicked amazingly  :shock: )  The car was also nicked 3 times for good measure. I also had a Series 2 which was fooked and smelt of dog which was horrible.  I have tried pretty successfully to obliterate its memory and therefore cannot remember what type of wheels it had.
Toyota Sera for £320 classified ad
It is on the isle of sheppey, tricky collection unless you are nearby.
ex Nigel Mansell
So he got a Fiat Tempra was it ? from Ferrari and a Renault 19 from Renault, not that well thought of was he?
Wow look at this. Up Mr Barretts street I would wager.
I have toyed with the idea of hiding something like this up our allotment - Rent is about £8 a year!
previous owner Famous musician
Oooh sounds interesting, go on Roger Daltrey maybe?
Kerry Camden
Who the fuck is he? Fuxake.
Apparently he was a bassoonist.....Might have come in handy for Fulvia ownership - the ability to cover up several holes at once.
That Daimler is gorgeously dreadful, sadly no MOT and reserve not met means I'm out
http://www.ebay.co.uk/itm/TATA-Pick-Up-/291653496955
MOT has now expired.
MOT history of this vehicle
  • Test date 5 January 2016
  • Test Result Fail
  • Odometer reading 85,575 miles
  • MOT test number 6987 0621 8137
  • Reason(s) for failure
    Parking brake: efficiency below requirements (3.7.B.7)
    Horn not working (1.6.2a)
    Parking brake lever ratchet mechanism is excessively worn (3.1.5)
    nearside Drag link end ball joint has excessive play (2.2.B.1f)
    nearside front outer Track rod end ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.2.C.1c)
    nearside front inner Track rod end ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.2.C.1c)
    offside front outer Track rod end ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.2.C.1c)
    nearside front Steering pivot point has excessive play drop arm (2.2.B.1g)
    Exhaust has a major leak of exhaust gases (7.1.2)
    nearside front Suspension arm ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.4.G.2)
    offside front Suspension arm ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.4.G.2)
    offside front Suspension arm has excessive play in a ball joint (2.4.G.2)
    nearside front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
    offside front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
    nearside front Headlamp aim too low (1. 8)
    Exhaust emits an excessive level of metered smoke for a turbo charged engine (7.4.B.3b)
