Seller seems angry.  But he did swallow the caps-lock throughout the ad, spouting
ENGINE BAY MINT FOR THE YEAR!!
So probably deserved it
Likely the
MINOR ADVISORIES-UNDERBODY IS IN GREAT ORDER
Put the buyer off
  • Advisory notice item(s)
    nearside front wheel arch corroding
    front Vehicle structure has slight corrosion both floors slightly (6.1.B.2)
    rear Vehicle structure has slight corrosion both inner sill end (6.1.B.2)
We all agree the Minor[shunt] is gopping..... or 'a worthwhile reinterpretation of a motoring legend' = its Fucked!!
Hmm??
TS
* for extra winnage it might still have 803cc on the slip
Hmm interesting - one of the prototype SD1 estates was LOE 99P. May well be the original reg but could have been used as a factory hack then registered later, like the pre-production Wedge that's been restored on here?
No, I have just read about this over on the SD1 forum. LOE444P is a private plate, this car was previously DMK 396V
Think the owner of that brown SD1 might be telling porkies with
I see no reason, why it would not pass an mot.
Registration number: DMK396V
Mileage readings are currently only available for MOTs done from 1 August 2011.
  • Vehicle makeROVER
  • Vehicle model3500 SD
  • Date first used7 February 1980
  • Fuel typePetrol
  • ColourBrown
MOT history of this vehicle
  • Test date30 May 2014
  • Expiry date18 June 2015
  • Test ResultPass
  • Odometer reading85,684 miles
  • MOT test number7482 2045 4158
    Offside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
    Nearside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
    Parking brake: parking brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
    Windscreen delaminating at edges
    Oil leak
    General corrosion in wheel arches and bottom of offside rear door
    Surface corrosion on all brakes pipes
^ nice work - why on earth would someone go to the trouble of putting that plate on though?
This looks like a peach! It's only down the road from me so if anyone wants me to have a squint let me know. Bin the wheels and put the originals back on and it will look HOT. I would be tempted myself but it haz the rong gear selector init.
FFS!
brave restoration project
have v5 in my name, tax exempt
Hmmmm
Ring Ring, Ring Ring. Sorry that's not my phone going.
Is that an empty schnapps bottle in the boot From the last owner. .
