"Ecuador remapped"   " Stealing rack overalled"
Could I justify this to my better half ?
I quote : YOU ARE BIDDING ON A 1993 AUSTIN MINI THAT HAS HAD THOUSAND SPENT ON IT AS FOLLOWS.  M.E.D 1480 ENGINE WHICH IS BRAND NEW AND HAS NEVER BEEN RUN, A SERIES EARLY 11 STUD BLOCK EN4OB CRANK - COOPER S RODS, FAST ROAD/RALLY CAM, DUPLEX TIMING GEARS, POWERMAX PISTONS, CYLINDER HEAD - 1968 COOPER 11 STUD 12G940 36 INTEL 31 EXHAUST GAS FLOWED - PORTED - BRONZE GUIDERS, COOPER S HEAD GASKET 1.5 ROLLER ROCKER SET, HIGH CAPACITY WATER PUMP, 100 AMP ALTERNATOR, MAGNA CORE LEADS, LIGHTENED BALANCED FLYWHEEL, RACE CLUTCH, STRAIGHT CUT DROP GEARS 2.9 CROSS PINN DIFF, WEBBER 40 DLOE/DHLA CARB, ULTIMATE ENGINE STEADY SET 2 CORE ALUMINIUM RADIATOR FACT FUEL PUMP.
Dickhead ?  Finish it, get it MOT'd take it to the Mini National shows at erm Gaydon or wherever, and flog it for £15K ?
That Merc Koop has the most quality of all accessories.
Opposite corner chrome arches :-)
And how should it pass an emissions test if it doesn't get rung beforehand?
attn bernard b triggerstolf the 3rd.
This is the guy I bought my SD1 off and he was sound. He always seems to spend loads of ££ on his cars before getting shot of them.
Needs a bit of tidying but these things seem to be on the up so might be a decent buy. I'm sure Junkman will be able to spot if it's a plum/haunted just be staring into it's headlamps.
10922357_1424867074473816_73114619118550
http://retrorides.proboards.com/thread/176964/1970-rover-p6-chesterfield-1800ono
Half way through scalpal procurement for kidney removal.
That is LUSH
I could like it. But were cow-free ones even available?
Not sure, i know the Magentis was but not sure about this one. Links now working now did you buy it  :-D
IIRC if you fit an older engine (and can prove it) then the emissions test will go by the year of the engine rather than the car. So a '68 engine in a '93 car will need to pass the '68 emissions, which is just a smoke test.
By only viewing the photo, I just knew that this would be in the North East (!)
Us lot on the coast up here call them lot out in West Durham 'hillbillies' - here's an example of why . . .
Jed Clampett xx
Dave. My mate Dave. He could make it pass. If only I knew where Dave was now. Last time I saw him he was wearing PJ's under his clothes (due to the fact that I phoned him at bedtime in a panic) and making my 850 run sweet. So sweet that the MOT man accused me of cheating when it came to the set up for emissions. (Dave worked in Engine Development at Longbridge, in the 1980's before joining Lucas aerospace as a quality manager, but had grass track raced an 850)
