tommotech Posted March 15, 2019 Author Posted March 15, 2019 Wheels and tyres fitted today, new door mirror (genuine part £3 eBay purchase) and a good clean and tidy up. MOT achieved this afternoon, with some advisories on bushes. Next jobs on the list are to sort out the LH sliding door (new handle and top carrier needed), fit a new roof ariel, sort out the lock barrels and get the heater fan working properly. The interior clean was a mission, a wire wheel and full PPE were needed! Plaster dust everywhere and that awful smell has now gone. It can now get to work. mat_the_cat, Cleon-Fonte, Frogchod and 5 others 8
500tops Posted March 15, 2019 Posted March 15, 2019 What a result! Congratulations. Nice to see the new of these getting some love. Few and far between these days tommotech 1
Burnside Posted March 15, 2019 Posted March 15, 2019 +1 on congrats with the Mot. The repainted wheels look great. It's jobs like that which can really change a look of a vehicle. How did you get on with the Door Mirror replacement? I ask as we brought a used drivers mirror for ours recently but had a right game trying to get the adjuster cable end out through the door skin while removing it. Seams the front window channel is limiting space to feed the adjuster cable out / in through. So I've been putting off replacing it for the time being. tommotech 1
wuvvum Posted March 15, 2019 Posted March 15, 2019 Nice work! Those wheels really do improve it. tommotech 1
Marm Toastsmith Posted March 15, 2019 Posted March 15, 2019 Looks great, well done. Love these vans. tommotech 1
tommotech Posted March 15, 2019 Author Posted March 15, 2019 +1 on congrats with the Mot. The repainted wheels look great. It's jobs like that which can really change a look of a vehicle. How did you get on with the Door Mirror replacement? I ask as we brought a used drivers mirror for ours recently but had a right game trying to get the adjuster cable end out through the door skin while removing it. Seams the front window channel is limiting space to feed the adjuster cable out / in through. So I've been putting off replacing it for the time being.The mirror adjust cable took a bit of jiggling, I removed the front lower channel from the two fixing points and dropped it to the bottom of the door cavity. The cable then feeds through with a bit of a jiggle, I also removed the top inner and outer weather strips for better visibility. It took about 20 mins in all, so not a bad job in the end. Burnside 1
tommotech Posted March 15, 2019 Author Posted March 15, 2019 Nice work! Those wheels really do improve it.I’m chuffed with the wheels to be fair, they’ve come out really well.
Burnside Posted March 16, 2019 Posted March 16, 2019 The mirror adjust cable took a bit of jiggling, I removed the front lower channel from the two fixing points and dropped it to the bottom of the door cavity. The cable then feeds through with a bit of a jiggle, I also removed the top inner and outer weather strips for better visibility. It took about 20 mins in all, so not a bad job in the end.Thanks for the pointers much appreciated! If like us you need to remove the rear door handle for replacing the barrel. We ended up drilling out the rivet on the rear door catch as previously mentioned. We removed the inner door handle first from the connecting rod. Then removing the outer handle with the rods and catch as one. Access was a pain but was a satisfying fix. Hopefully you may not need too if the handle isn't broken. You might be able to tease the barrel out as we did with the side doors. tommotech 1
tommotech Posted March 16, 2019 Author Posted March 16, 2019 Happy to report that the Dispatch drives well, feels planted on its new tyres and the hesitation has gone having cleaned out the tank / pickup pipe. Transported body panels to the bodyshop for the next Panther project. New rear lamp ordered and looking for an ariel, as well as DAB radio options. wuvvum, Burnside and strangeangel 3
tommotech Posted April 7, 2019 Author Posted April 7, 2019 The Slow Sevel Van has been doing ‘vanning’ quite admirably. Future jobs include the probability of having to sort the clutch. There is a feeling through the pedal when looking for the biting point, worse when you lift more slowly than usual. This is accompanied by a judder, but you can drive around it if you remember to. I’m not particularly concerned either way, clutch kits are not expensive, no OMGDMF to worry about and there is plenty of access. The fuel starvation at low fuel level has improved, but not gone away completely. Again I’m not particularly worried, just need to keep it off the fuel light. The LH sliding door still needs sorting but is, by no means, an urgent job. I had time to fit a new rear lamp yesterday. I also fitted a had a lock barrel set delivered and fitted one to the rear door, I can now lock all doors. Here it’s it doing van things; Burnside and wuvvum 2
Frogchod Posted April 7, 2019 Posted April 7, 2019 My old vans clutch lasted 360,000 km .The clutch wasn't slipping but the release bearing exploded. Previous to explosion it felt just as you describe.Low fuel warning light was exactly that. 30 km then it started spluttering. I liked the van-ness so much I bought another. 2.0 hdi this time. tommotech 1
tommotech Posted May 10, 2019 Author Posted May 10, 2019 Clutch on the Dispatch has been getting worse, in terms of judder, while the biting point has started to become variable. Whilst fetching a batch of Panther parts from an enthusiast the biting point became progressively worse last evening, to the point where the clutch is dragging intermittently. Having to stop the engine, engage gear with the clutch dipped and then restart was entertaining* Ive bitten the bullet today and purchased a Valeo clutch kit from ECP, as well as a timing belt. That’s tomorrow sorted then, pics to follow. Saabnut, scdan4, Rave and 4 others 7
tommotech Posted May 11, 2019 Author Posted May 11, 2019 Today’s findings, release bearing had collapsed and guide tube has made a bid for freedom. Pressure plate release fingers are also worn through which explains the variable biting point. Unfortunately I didn’t get a guide tube and don’t have one on hand, so the van remains stripped down until I can get back to it with parts. LUK friction disc didn’t look to have faired too badly though, I reckon it’s the original clutch too. Release bearing was hanging! I do like Valeo clutches, from previous experience. Prefer LUK if it’s DMF though, thankfully these aren’t! scdan4, Burnside, paulplom and 2 others 5
tommotech Posted May 16, 2019 Author Posted May 16, 2019 Guide sleeve procured, installed and new clutch fitted too. I’ve also fitted a new timing belt, the item fitted was pretty slack and the camshaft position was slightly out. With a new one fitted and correctly timed the van drives particularly well for what it is. The new clutch has also made a world of difference - normality restored! paulplom, Burnside, wuvvum and 5 others 8
Lacquer Peel Posted May 17, 2019 Posted May 17, 2019 Good work, it's nice to see a scruffy old van getting some love. Does it have a Bosch pump?
tommotech Posted May 18, 2019 Author Posted May 18, 2019 Nope, pump is DELPHI (previously known as Lucas, previously known as Roto Diesel / CAV). Most DW8 engines are DELPHI, possible to see Bosch but rare. Lacquer Peel 1
Lacquer Peel Posted May 18, 2019 Posted May 18, 2019 Yes, my 2000 DW8 Berlingo had a Bosch pump, I guess it's just the early DW8s.
tommotech Posted May 18, 2019 Author Posted May 18, 2019 On early DW8 both Bosch and DELPHI were fitted, with DELPHI DPCN being fitted to the later engines exclusively (with ECU timing control). Bosch drives better to be fair. Lacquer Peel 1
tommotech Posted December 22, 2019 Author Posted December 22, 2019 Not had a great deal to post on this, it’s just gone about its business without fuss. Heater has been ineffective recently so I treated it to a new thermostat, temp gauge sits nicely just below 90 now. Radio hasn’t worked for a while so I’m on the lookout for something, preferably DAB. wuvvum and 500tops 2
tommotech Posted December 29, 2019 Author Posted December 29, 2019 The broken mirror, that was gaffer taped for MOT purposes, has been replaced today. I also took the opportunity to replace the LH door lock barrel (two more to do) wuvvum, theshadow, Jim Bell and 1 other 4
bezzabsa Posted December 29, 2019 Posted December 29, 2019 I do love these vans....must be good due to the amount that are taxi converted around here, one sold before xmas with 575,000 on the clock,,2nd engine at 300,000....still had 7 months ticket too, think he got £650 for it too tommotech 1
tommotech Posted March 18, 2020 Author Posted March 18, 2020 MOT time for the van, how quickly a year passes! This hasn’t needed much attention recently, it just works without complaints. Last time the rear axle trailing arm bushes were advised, increasing creaking noises from the rear end suggested they weren’t getting any better so time to get busy before the test. An easy enough job, plenty of access and no seized boots to deal with. The left hand bush had completely deteriorated and collapsed, the right hand needed the drill trick to separate the rubber from the outer sleeve. Knackered bush in situ; Fooked vs new; New bush in situ; Now the rear axle is straight the steering wheel is off centre, something I will sort soon. MOT passed with advisory for rear number plate and a couple of brake pipes. All in all I’m happy with that for a 20 year old van. I may have the option of a VW T5, at the right price with engine repair needed. If that comes of then this van will certainly be up for sale, watch this space............. RobT, Cleon-Fonte, Marm Toastsmith and 4 others 7
tommotech Posted April 1, 2020 Author Posted April 1, 2020 So, the Dispatch will definitely be offered for sale, once restricted movement is a thing of the past. I have a VW T5 incoming and also another project that I came into possession of recently.
tommotech Posted April 1, 2020 Author Posted April 1, 2020 I'm still working, mainly from home but also travelling to Rail & Agricultural clients, as well as Tata Steel in Port Talbot - it takes them 6 weeks to turn the foundry off (after 2 weeks planning). I have some annual leave over Easter so will have time to devote to the new arrival, that came into my possession as the madness happened; Its the exOBND, exWuvvum, exHMC MG ZR Express Van. It will get a sympathetic resto and there are a number of jobs to do, namely getting an MOT when circumstances allow. Bonnet fails to close, gear change is really sloppy, clutch is heavier than normal (release arm siezing), patch needed on rear of sill and major service needed for starters. I do like the R3 and this one drives well, I'm looking forward to this running resto. Any info or tips gratefully received. Skut, wuvvum, Rave and 10 others 13
Landy Mann Posted April 1, 2020 Posted April 1, 2020 I think I've got some brand new brake caliper side pins if you or anyone else wants them. tommotech 1
tommotech Posted April 1, 2020 Author Posted April 1, 2020 26 minutes ago, Landy Mann said: I think I've got some brand new brake caliper side pins if you or anyone else wants them. Thanks, I will accumulate whatever parts are available, I’m sure they’ll be needed at some point. Let me know details please.
Landy Mann Posted April 3, 2020 Posted April 3, 2020 Postage is only £1:40 so a donation to the forum/Charity of your choice will be more than sufficient. If you PM me your address I'll get them posted, although it may be after lockdown... tommotech 1
tommotech Posted April 11, 2020 Author Posted April 11, 2020 Had some time to start fettling the MG Express today, first job to sort was the bonnet latch but the bumper has to come off to gain access / remove. The release arm had jammed in the release position due to the amount of gunge / debris and a good clean, degrease & lube sorted it nicely. Looking at the underneath it appears pretty solid, it’s just crusty on the edges and the wings are a case in point. In reality I’d like to look for a pair of replacement front wings and new bumper, which would give the front a lift, looks wise. I’ve seen an MG Rover breaker in Redditch is looking to get shot of some stock so I’m hopeful they have the items I’m looking for in the right colour. Rear sill needs a patch but that is probably (hopefully) the worst of it. I also had time to look at the washer pumps, as Wuvvum had made a temporary washer system whilst he had the car. With the bumper off access is easy, removal and test showed the washer pump to be seized although dropping on the floor (deliberately) released the impeller and operation is restored. Restoration of the wiring should sort the job nicely. BeEP, The Old Bloke Next Door, theshadow and 6 others 9
