Six-cylinder Posted December 29, 2015 Posted December 29, 2015 My 2001 Volvo V70 dashboard lit up like Christmas tree a few days ago, showing faults for alarm, transmission, engine, needs service, airbag and visit your dealer triangle. Instead of taking it to a garage I was thinking of buying a code reader/reseting tool.Anybody any thoughts about what to buy, should I buy a Volvo only tool for £87 or a multi reader £225? Do some brands work better than others?http://www.ebay.co.uk/itm/VOLVO-OBD2-DIAGNOSTIC-SCANNER-TOOL-SRS-ABS-ERASE-CLEAR-FAULT-CODE-iCARSOFT-i906-/221701732671?hash=item339e73f93f:g:k6UAAOSwwbdWJs9phttp://www.ebay.co.uk/itm/Original-AUTEL-MaxiCheck-Pro-EPB-ABS-SRS-DPF-TPMS-Scanner-OBDII-Diagnostic-Tool/171883626572?_trksid=p2047675.c100009.m1982&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140328180637%26meid%3Dd022787f10fb423cbae49bb73542bd6d%26pid%3D100009%26rk%3D2%26rkt%3D10%26sd%3D291630174352
Slartibartfast Posted December 29, 2015 Posted December 29, 2015 Have you considered getting a Bluetooth dongle for a couple of quid from that eBay? Assuming the V70 has ODBII
Six-cylinder Posted December 29, 2015 Author Posted December 29, 2015 Have you considered getting a Bluetooth dongle for a couple of quid from that eBay? Assuming the V70 has ODBII How does that help me?
Pillock Posted December 29, 2015 Posted December 29, 2015 They can do code reading and resetting. I've got one I can lend you via post if you want to try? You need an Android phone and the free Torque app. gtd2000 1
sierraman Posted December 29, 2015 Posted December 29, 2015 If you are using in once a blue moon, I'd suggest a trip to a Volvo specialist, see what he says, you don't want to spend £220 then find you need to spend £1500 to put the light out. A bit extreme perhaps but...
Six-cylinder Posted December 29, 2015 Author Posted December 29, 2015 They can do code reading and resetting. I've got one I can lend you via post if you want to try? You need an Android phone and the free Torque app. My Samsump J1 is absolute rubbish and I just can't make do anything useful, it could be a combination of it and me but I don't see using it as a solution to anything.
Six-cylinder Posted December 29, 2015 Author Posted December 29, 2015 If you are using in once a blue moon, I'd suggest a trip to a Volvo specialist, see what he says, you don't want to spend £220 then find you need to spend £1500 to put the light out. A bit extreme perhaps but... It was £87 for the Volvo only one and I fear that it won't be the last time I use it even if there is nothing wrong. The £224 looks like I can use it on other cars I have and therefore spending the extra £137 might be better value in the long term.
egg Posted December 29, 2015 Posted December 29, 2015 http://www.ebay.co.uk/itm/Car-Engine-Fault-Code-Scanner-Reader-Diagnostic-Reset-Tool-OBD-2-CAN-BUS-EOBD-UK-/391026596998?hash=item5b0b005c86:g:6a4AAOSw7FRWVaFS I've got one of these basic ones. Works with my Fusion, but as yet (fingers crossed) no faults to actually diagnose!
Pillock Posted December 29, 2015 Posted December 29, 2015 Hairy Nuff, I would imagine a dedicated thing you're going to use often is more reliable than a five quid bit of Chinese smartphone accessory guff - in which case think big and get the multi reader
panhard65 Posted December 29, 2015 Posted December 29, 2015 It really depends how deep you want to go with diagnostics. The cheap OBD readers will mainly do just engine same with a lot of the bluetooth aps so not worth bothering with if you want to do ABS and airbags. The Autell one doesn't look bad but you might be better off trying to find a good used Launch X431. Either a proper UK version or one that has been updated to UK spec. The hooky chinese copies don't work very well but a properly updated launch is far better than the Snap on and Sykes crap of the same era. Bear, brickwall and overrun 3
Six-cylinder Posted December 29, 2015 Author Posted December 29, 2015 http://www.ebay.co.uk/itm/Car-Engine-Fault-Code-Scanner-Reader-Diagnostic-Reset-Tool-OBD-2-CAN-BUS-EOBD-UK-/391026596998?hash=item5b0b005c86:g:6a4AAOSw7FRWVaFS I've got one of these basic ones. Works with my Fusion, but as yet (fingers crossed) no faults to actually diagnose! Cheapness is great but I think this one is engine only and I wanted one that did other systems such as ABS, Airbags etc as well.
Six-cylinder Posted December 29, 2015 Author Posted December 29, 2015 It really depends how deep you want to go with diagnostics. The cheap OBD readers will mainly do just engine same with a lot of the bluetooth aps so not worth bothering with if you want to do ABS and airbags. The Autell one doesn't look bad but you might be better off trying to find a good used Launch X431. Either a proper UK version or one that has been updated to UK spec. The hooky chinese copies don't work very well but a properly updated launch is far better than the Snap on and Sykes crap of the same era. Is this what you meant? http://www.ebay.co.uk/itm/Genuine-LAUNCH-X431-CREADER-VIII-CAN-Code-Reader-Scanner-Car-Diagnostic-Tool-/291335888743?hash=item43d4f8df67:g:XOYAAOSwj0NUiBNf After all anyman who can deal with the complex systems of a Peugeot 204 diesel must be the right person to take this sort of advice from!
panhard65 Posted December 29, 2015 Posted December 29, 2015 I haven't tried that one yet but I have one of these.http://www.ebay.co.uk/itm/LAUNCH-X431-SUPERSCANNER-1ST-GENERATION-USED-/251661613036?hash=item3a983377ec:g:Mm4AAOSwVFlUKNVMThere are normally a few more on ebay at better prices and having the full set of cables that they come with originally is a must. Mine will do pretty much everything including Merc Sprinters. It is far better than the Snap on Solus piece of junk we had before. It works well with pre obd2 stuff so if you are running a lot of different pre 2001 stuff it will be very useful.
Six-cylinder Posted December 29, 2015 Author Posted December 29, 2015 I haven't tried that one yet but I have one of these. http://www.ebay.co.uk/itm/LAUNCH-X431-SUPERSCANNER-1ST-GENERATION-USED-/251661613036?hash=item3a983377ec:g:Mm4AAOSwVFlUKNVM There are normally a few more on ebay at better prices and having the full set of cables that they come with originally is a must. Mine will do pretty much everything including Merc Sprinters. It is far better than the Snap on Solus piece of junk we had before. It works well with pre obd2 stuff so if you are running a lot of different pre 2001 stuff it will be very useful. I think that might bust the budget. These are our post 1990 cars 2004 Range Rover TD6 Vogue 1994 Mercedes 500 SEC 1988 BMW 735i SE 2001 Volvo V70 XC 1994 Cadillac Eldorado Touring Coupe 2000 Citroen C15D Van 1996 BMW M3 Evo Convertible 1999 Citroen Xantia V6 Exclusive 1994 Mazda MX5 1999 Volvo V70 T5 1990 BMW 325i SE E30 1995 Audi Convertible 2.6 2000 BMW 330Ci 2001 Alfa Romeo 156 V6 Sportswagon Veloce 1986 Maserati 425 Bi Turbo saloon 1996 BMW 328i M sport 1992 Citroen BX Gti
Six-cylinder Posted December 29, 2015 Author Posted December 29, 2015 I needed a quick solution so I have bought the all systems Volvo only unit from a UK supplier.
HH-R Posted December 29, 2015 Posted December 29, 2015 Those Autels are pretty good if all you want is basic EML diagnostics to keep resetting the EML in the hope it goes away.
Six-cylinder Posted December 29, 2015 Author Posted December 29, 2015 I bought the iCARSOFT i906 Volvo as I did not really know what I am doing and the blurb says it looks at more systems than the multi ones. I want to use the car again so I just went for it!
Six-cylinder Posted December 31, 2015 Author Posted December 31, 2015 It has arrived this afternoon but it is pouring with rain and now dark, so maybe tomorrow. egg, brickwall and Banger Kenny 3
Six-cylinder Posted January 2, 2016 Author Posted January 2, 2016 This afternoon I have had a go, nothing is ever straightforward, first find the socket, then I soon flattened the battery and could not find the reset screen on the scanner tool as per the manual. I had to call out the big guns and Mrs Cyl sorted everything but the Engine management light. I have tried disconnecting the battery for 30 secs but that did not help. I have left the battery disconnected and the battery on charge overnight so we will see what the morning brings. Skizzer 1
Six-cylinder Posted January 3, 2016 Author Posted January 3, 2016 A full charge seemed to have completed the job of extinguishing all the warning lights. I bought one of the cigar lighter volt meter recommended on this forum and it says 14.2 volts with the engine running. brickwall, egg and Dave_Q 3
hairnet Posted January 3, 2016 Posted January 3, 2016 I had to call out the big guns and Mrs Cyl sorted everything keeper michael1703 and brickwall 2
overrun Posted February 27, 2016 Posted February 27, 2016 It really depends how deep you want to go with diagnostics. The cheap OBD readers will mainly do just engine same with a lot of the bluetooth aps so not worth bothering with if you want to do ABS and airbags. The Autell one doesn't look bad but you might be better off trying to find a good used Launch X431. Either a proper UK version or one that has been updated to UK spec. The hooky chinese copies don't work very well but a properly updated launch is far better than the Snap on and Sykes crap of the same era. Anyone got an opinion on this Launch X431? http://www.ebay.co.uk/itm/New-Genuine-LAUNCH-X431-CRP123-ENG-AT-ABS-SRS-OBDII-Scanner-Diagnostic-Tool/301878669460?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140122125356%26meid%3D10a367327e0f4004830e849d62bb8969%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D321873664634 Brand new, official product, UK supplier, 1yr free software update and seems a great deal at £102, posted.Given that it can read and reset 4 systems. Why is it so cheap, when compared to a used model?There seems to be a few variants, but all are under the X431 model name?
overrun Posted February 27, 2016 Posted February 27, 2016 Hmmm. Despite the claims, it has to be another Chinese snide.
panhard65 Posted February 27, 2016 Posted February 27, 2016 Anyone got an opinion on this Launch X431? http://www.ebay.co.uk/itm/New-Genuine-LAUNCH-X431-CRP123-ENG-AT-ABS-SRS-OBDII-Scanner-Diagnostic-Tool/301878669460?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140122125356%26meid%3D10a367327e0f4004830e849d62bb8969%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D321873664634 Brand new, official product, UK supplier, 1yr free software update and seems a great deal at £102, posted.Given that it can read and reset 4 systems. Why is it so cheap, when compared to a used model?There seems to be a few variants, but all are under the X431 model name?Not tried the newer Launch products but as mine is now obsolete with no updates available so I am told looks like I will have to try something else.
overrun Posted February 27, 2016 Posted February 27, 2016 Not tried the newer Launch products but as mine is now obsolete with no updates available so I am told looks like I will have to try something else. That's annoying, mate.Going to flog yours on? They still seem to command good money. https://www.launchtech.co.uk/enthusiast-diagnostics/launch-crp123-creader-professionalHere's the official Launch page for the CRP123 that the £102 obo eBay item claims to be, The definite genuine one is a good 80 quid more. Shame, cos I want the cheaper one, but not it is knock-off tat.
lisbon_road Posted February 27, 2016 Posted February 27, 2016 I use Ebay pirate software for Vauxhall/GM cars, with a lead off ebay to connect to my laptop. At least I would use it if I could get it to work on Windows 8, worked ok on Vista before (only thing that did). I pay a local garage a tenner to read codes when I can't get it to work, which I admit is v annoying - no disrespect to the garage who are helpful and drop everything for a bit of cash!
skattrd Posted October 31, 2018 Posted October 31, 2018 Bumpski. I'm looking for a decent code reader for w203 Merc and other things, '99 VAG, '96 Volvo.I saw the following recommended: Autel MD802https://www.ebay.co.uk/itm/Autel-Diaglink-OBD2-All-System-Code-Reader-DIY-MD802-Auto-Diagnostic-Scanner-UK/263302402486 launchtech Creader VII+ … X431 mentioned previouslyhttps://www.ebay.co.uk/itm/UK-LAUNCH-X431-Creader-VII-7-Auto-Car-OBD2-Diagnostic-Tool-Scanner-Code-Reader/301905364861 Does anyone have any comments or recommendations?
tul66 Posted January 2, 2019 Posted January 2, 2019 Can anyone recommend a good one of these which does petrol & diesel and works with iOS? There's loads on ebay but would prefer something that's known to work.
Dave_Q Posted January 2, 2019 Posted January 2, 2019 I seem to recall that only the wifi ones work on ios, because Apple. red5 1
