danthecapriman Posted May 22, 2018 Posted May 22, 2018 No worries mate, I just wondered if you'd proved it with your yank tank or 'owt.I’ll stick my Georgia plates back on it this weekend and report back! eddyramrod 1
PhilA Posted May 22, 2018 Posted May 22, 2018 These came in today. Phil egg, Joloke, Christine and 1 other 4
Guest Hooli Posted May 23, 2018 Posted May 23, 2018 I think so but it should say on the form. Joloke 1
danthecapriman Posted May 25, 2018 Posted May 25, 2018 Brilliant news Jo. Now you just get to sit back and wonder what your new plate will be! Joloke 1
Junkman Posted May 25, 2018 Posted May 25, 2018 OK, where is the burnout vid? danthecapriman and Joloke 2
vulgalour Posted May 25, 2018 Posted May 25, 2018 Before you do the burnout video, SHUT THE BONNET HOOD! Joloke and danthecapriman 2
Junkman Posted May 25, 2018 Posted May 25, 2018 Before you do the burnout video, SHUT THE BONNET! EFA Joloke 1
PhilA Posted May 25, 2018 Posted May 25, 2018 Watched the second Guardians of the Galaxy with the kids on Netflix. Was amused at the beginning: Phil
Junkman Posted May 26, 2018 Posted May 26, 2018 just basic things that need doing either for safety.................. Looking cool is a lot more important than that safety bollocks. danthecapriman and Yoss 2
cort1977 Posted May 26, 2018 Posted May 26, 2018 If shipping parts is expensive i will be flying through Heathrow / Europe next month and can easily smuggle a package for you. All the door rubbers and so on are not MOT critical, my unsolicited advice would be get it on the road, enjoy it and work through the inevitable teething issues and then work on cosmetics over the next few months. So in the short term, make a mount for the switches under the dash and enjoy. Joloke 1
danthecapriman Posted May 26, 2018 Posted May 26, 2018 Would these be worth contacting for the seals? https://www.woolies-trim.co.ukAt the end of the day they’re just shaped strips of rubber so I’d imagine anywhere like this could get the correct (or near as damn it) shaped bits and you fit and cut to length. Headlining. Eddy did a nice job of this on his Cadillac using some very unassuming basic materials. I can’t remember what it was he actually used for it but it looked the part afterwards. I’ve also completely done out the rear interior of my camper van. All I’ve used is sound deadening trim carpet and trim fix adhesive (aerosols) to glue it on. It glues to metal, plastic, wood anything really. Loads of colours available too.Or what about getting a cheapo headlining kit for something like a Capri and adapting it? I can’t help much with the wiper switch though! I’m an idiot and like things ‘right’ so I’m afraid I’d fork out the dosh for the correct expensive part! Factory innit!For now though can’t you just make up a mount from some old ally sheet or similar to take your current adapted temp switches? At least then they’re tidy and fixed in place. Joloke 1
danthecapriman Posted May 26, 2018 Posted May 26, 2018 I don’t know anywhere that do them in bulk. Are they the little plastic ones or metal? There’s some different types on here, https://www.motomobil.com/online-shop,8063.html?page=2&producer_id=1&auto_id=90&auto_mod_id=92&category_id=9&category_sub_id=&state_id=&word=&artnr=&bonus=0&q=&latest=I got my Capri ones from here along with some new badges. Joloke 1
danthecapriman Posted May 26, 2018 Posted May 26, 2018 Failing that you could try not using the clips but get some of the double sided adhesive foam trim tape?Just cut a strip off big enough for the badge and stick it on instead. The tape will cover and seal the original holes in the panels too. I did this on my old Granada and it worked well. This sort of stuff https://www.ebay.co.uk/itm/Black-Double-Sided-Automotive-Permanent-Self-Adhesive-Foam-Car-Body-Trim-Tape/272864403155?hash=item3f87fc5ed3:m:mRW55AldugI_CzzTxab4X2Q Joloke 1
captain_70s Posted May 26, 2018 Posted May 26, 2018 On my Triumph I attach the badges with double sided tape... danthecapriman and Joloke 2
Junkman Posted May 26, 2018 Posted May 26, 2018 I'm not sure how many septics I've had in my life, but I can't remember a single one with a borked indicator stalk,which sometimes also contain wiper, cruise control and main beam functions. They were usually the same in every model the corp produced.It's rather bizarre that they made an especially flimsy one especially for the Mustang II. Joloke 1
Junkman Posted May 26, 2018 Posted May 26, 2018 Yeah, I may* keep forgetting that those cars are now 15 years older than when I still liked them.But the indicator switch/stalk combo in my '74 Ford was like new, now that I think of it. I find it especially bewildering on a freshly imported car. Since when do the septics indicate?Usually the switches are unused upon arrival in Ye Olde Worlde, a bit like the mirrors having never been looked into. danthecapriman and cort1977 2
danthecapriman Posted May 26, 2018 Posted May 26, 2018 Thanks GuysThe tape might be a solution as I wanted to stick the badges back on and run it a bit shite ratty for a while once its more sorted i will probably get the real clips I’m actually considering using tape for the Capri’s badges when it gets that far instead of the pins and clips. Imho drilling holes into fresh panels with new paint seems like inviting trouble. The holes are often the first places rust starts again. At least with tape it can’t do that. You’d never know the difference either unless you really started looking hard! Joloke 1
Andyrew Posted May 26, 2018 Posted May 26, 2018 SEALS id be down the local scrappy looking around to see whats similar, most boot seals are fairly generic so you may be able to cut and shut a load if its from something common, try car builder solutions or any kit car suppliers for universal indicator stalks and make something fit. Joloke 1
Andyrew Posted May 26, 2018 Posted May 26, 2018 cleaning the seals with g101 or any multipurpose cleaner and giving them a wipe with silicone grease (not the spray kind) helps them to seal better, works on sunroofs. you can try and fill the internal void with smaller diameter piping like vacuum pipe or diesel bleed off pipe, or back fill it with a silicone sealant if the gap i huge. Joloke 1
bezzabsa Posted May 26, 2018 Posted May 26, 2018 have a nosey on a kit car forum for door/boot seals....i'm sure they have a go to supplier... Re headlining, acoustic carpet and spray adhesive!!!! indicator/washer stalk....anything uk/jap you could cobble together??? jap stuff is probably similar shape as euro stuff tends to be square jap stuff IIRC is usually round Joloke 1
Guest VicN Posted May 27, 2018 Posted May 27, 2018 Shouldn't the wipers be switched via a relay? Joloke 1
danthecapriman Posted May 29, 2018 Posted May 29, 2018 You had a right result getting those bits, let alone over here and not far from home! Joloke 1
johngarty Posted May 30, 2018 Posted May 30, 2018 Goo work Jo, keep it up. Have a virtual brew to help with that Mojo richardthestag, Joloke and eddyramrod 3
bezzabsa Posted May 30, 2018 Posted May 30, 2018 woman I worked with in early 80's had a yank tank land yacht, and reckoned she could get parts shipped from the States quicker than her boyfriend could get parts for his 3.0 Capri from Ford UK!!! eddyramrod and Joloke 2
egg Posted May 30, 2018 Posted May 30, 2018 I find rockauto really good, you often get 5% off offers, items arrive well packaged etc. If you are clever with the ordering you can minimise postage and duty costs too. It's like an ECP that knows what it's doing Joloke, danthecapriman and eddyramrod 3
PhilA Posted June 1, 2018 Posted June 1, 2018 Requires 85MPH speedometer for extra points Good to see progress again! Phil Uncle Jimmy and Joloke 2
eddyramrod Posted June 2, 2018 Posted June 2, 2018 Couldn't one of our US Shiters buy that switch and ship it on to you, and you just pay them? Joloke and richardthestag 2
eddyramrod Posted June 2, 2018 Posted June 2, 2018 Makes sense to me! Caution: what makes sense to me cannot be relied upon to make sense in the outside world! Joloke 1
