'93 Mondy thread - (very) partial PAS fluid change
The newest mk3 Mondy would be on an ‘07. That’s newer than my daily! Not to mention there’s definitely still giffer owned ones with low mileage out there. I could get a mk2 maybe?
They are definitely rather thin on the ground, though.  I've owned three of them in the past so I tend to notice them and I'm not noticing them very often!
  • Agree 2
I’ve had a few of them. You still see some of the ST ones about but the cooking ones are getting thin on the ground. I’d be surprised if any TDDI are left, minicabbed to death no doubt!
Expand
my 07 engine failed as was the mazda lump not the zetec................
  • 3 weeks later...
  On 11/06/2018 at 15:21, egg said:
Following the PAS fluid change on the Mazda, I thought I'd do the same on the Base. This needed it more, and steering does seem a bit smoother. However, my siphoning technique (thanks Chrisfix) wasn't quite as effective at getting the old stuff out on this car.
Expand
Almost seven years later, thought I'd siphon off some more PAS fluid. Was a bit low actually, now steering silent as a fish etc.
  • egg changed the title to '93 Mondy thread - (very) partial PAS fluid change
Bit of damp in the engine bay, wonder if same as happened last time I did this, new fluid is causing PAS pressure switch that runs over the engine to spray/leak. And yes I did bleed it with turning lock to lock with the cap off.
Expand
I take it this is an age related issue caused by perished PAS pipes as none of mine ever suffered that problem?
Expand
Think so Warren, it's been on my list to change the rusty pipes along the subframe since I've had the thing, too.
