Tickman's stuff.
I hope the price is going up or you might fix yourself all the way to the poor house!
On 4/28/2020 at 12:46 PM, Tickman said:
Batteries, oil and general supplies a bit more organised.
oooh vintage T12 fluorescent fixtures...
pretty obscure ones too! im not actually sure which make/model they are exactly, I have seen that lamp holder style before but i cant quite place my finger on it
(is the tube for the 3rd fixture still around somewhere?)
got any pictures of the control gear might give me a clue as to what they are exactly :)
I shall get some pictures for you next time.
That is the plan, adding value.
thats Much appreciated :)
and if you find them surplus to requirements please if possible hold onto them for me rather then chucking them out!
(or using them to weld up a car as I have heard some members using old fluorescent fixtures for! I dread to think what vintage fixtures have been butchered over the years!)
So where were we, oh yeah with this mess.
So time to do the taper off of the sill under the wing.
Now the side of the inner sill to close off, from this.
To this.
Now the front which is in the arch area.
That is the easy side of the panel welded in, the other bits after a quick break.
  • Like 17
That panel is now fully welded in but it doesn't look any different unless you climb underneath.
I've patched a couple of holes in the wing and front and added some filler ready to be rubbed off at a later date.
I think a few days break from it are now required.
Until sometime next week...
  • Like 8
That looks like a W30 MR2 door hovering above your bench. Random!
I could position the bits to have the driver's side all line up.
Have you broken one?
Yep an O2 plate one.
Got mats?
At least a temporary reprieve however I have responded to someone elsewhere where the price is £2000
Plodding on with Sonic.
This corner of the wing didn't exist earlier, I've put in enough metal to keep the strength and then added a surprisingly small amount of filler so far.
I've also added 100mm to the bottom of the wing here.
Not looking too bad in comparison to what it was like before.
Getting there slowly.
Fantastic work, it's going to be very easy to sell or very tempting to keep by the time you're finished. The way you're cracking on I can see some colour matched aerosols getting bought and the buffing mop coming out before lockdown is over ?
Being on the special list my lockdown is going to last a little longer than others.
Current plan is get it good enough to get out of the way so I can concentrate on the Minor.
I might as well enjoy it for a while too.
Plodding along after the weekend off as it was Chuck's 21st.
I've been applying filler and sanding it off.
More of the same.
Then I had a bit of a reshuffle to get Gwen into the firing line.
I'm going to strip the seats and stuff from inside before I ruin them while working on it. Then I shall do my best to avoid vibration white finger.
Encouraging update, and I never tire of seeing your workshop.  Looks a great set up!
I am jealous of the space. My garage is strictly car storage only unless you are working on the front or the back.
Front drum brakes are so cheerfully arcane. Great work.
I'd completely forgotten this was old enough enough to have drums all around!
More Toledo progress.
Yesterday I got the paint code, 96 which is Sapphire blue, and phoned the local paint shop who supplied the mixed can for the GSR. I did another collection by phoning him while outside and he took payment and brought them out and put them in the boot. Very helpful indeed and recommended.
I also got some masking tape so started on the car when I got to the unit. After masking I put a bit of primer on to see how it was.
As I'm such a perfectionist* this was deemed to be acceptable so I carried on with primer on the rest, of course I ran out so out came the Lidl stuff from the cupboard which seems good stuff. This is about as accurate as the previous colour match I had used.
Happy enough with that so far, time for some colour.
First decent coat done.
Lunch had now so time for some more.
Very far from exceptional but I'm happy with the way it is going.
Away man, it's all the one colour:)
  • Haha 3
