Retroshite
I paid a visit to the original foadwerx in Gateside earlier today after a friend mentioned it had been part demolished.
46243591101_c80370b680_c.jpgDSC_0049 by srblythe, on Flickr
46243596721_35f4727936_c.jpgDSC_0046 by srblythe, on Flickr
46192886432_8063b7fcc8_c.jpgDSC_0040 by srblythe, on Flickr
46192892152_411a7a674f_c.jpgDSC_0025 by srblythe, on Flickr
It's still an excellent place for photos.
Clogged up hydraulic tappets.
Change oil and filter.
Run for an hour.
Run for an hour.
I'm told a dob of ATF in the oil will help shift clag like that, although I've never tried it. It's not likely to do any harm at any rate even if it doesn't work.
And here it is back in 2015
16604458954_f7fd2050a9_c.jpgDSC_8535 by srblythe, on Flickr
17201769532_8bcc0b9fda_c.jpgDSC_8536 by srblythe, on Flickr
16995210227_e45f736e27_c.jpgDSC_8551 by srblythe, on Flickr
17231726946_567a11c1a7_c.jpgDSC_8722 by srblythe, on Flickr
16604340965_97a21ca468_c.jpgDSC_6548 by srblythe, on Flickr
16469181651_91be2645d9_c.jpgDSC_6136 by srblythe, on Flickr
I dread to think if the cars would have lasted without being vandalised had we stayed, it's really gone downhill since.
I would love to own a place like that! More photos please to record its remaining features for posterity!
Top photos! The form and colour of the Peugeot really set off and are set off in turn by the backdrop.
Here's the layout of your current place in the 1950s/1960s compared to now. There were railways and sidings all over the place.
Aye anybody could have gone down there and nobody would havesad to see it's going now as it was great for photos, creepy as fuck at night though
https://youtu.be/0__CUqiXXYo
Am not quite up on my BMW's but I think that is an M40 engine, the same as they used on the early E36 it was carried over I believe. The engine has a spray bar above the cam, same as a pinto. When the holes in the bar get blocked the cam and upper timing gear gets no lubrication and then sounds like that. If you catch it early you can rescue it. That sounds a bit past it, my mine clattered for a few seconds on start up and mine needed cam and followers to cure it.
Having spent most of the last couple of weeks working on the Visa I've pretty much neglected all of my other cars.
46082737322_e0eb0fcc2e_c.jpgRJC_5775 by srblythe, on Flickr
32264177658_a96c10b657_c.jpgRJC_5780 by srblythe, on Flickr
44447868220_298c856eff_c.jpgDSC_0059 by srblythe, on Flickr
44447867190_5e2f0b94e5_c.jpgDSC_0061 by srblythe, on Flickr
44495920380_b55b0262dc_c.jpgRJC_5926 by srblythe, on Flickr
Now that it's finished and heading back to the previous owner I should really be focusing on the other projects but instead I'm away to look at a small 1980's 5 door hatchback in gold with a beige interior.
I may be remembering this wrong but I seem recall RBJ of this parish running an m40 sans oil for around 100 miles without it dying.
Fuck man, well done. That looks impossibly nice.
It's probably going to be a shed but for £200 it's worth a look.
Sent from my G3311 using Tapatalk
That is definitely gold... Looks an interesting car
Deffo worth a look at that money man. How bad can it be?!
That 323 is a belter. My late grandfather had a run out Javelin in the same colour. Champagne i think its called.
Is that Axmister carpet on the wheel ?
It looks more like the bit of carpet you get round the bottom of old people's toilets.
Hopefully not as saturated with stale piss.
That is caramac. I think you ought to festoon it with giffer stuff like those shit seat covers and some Monroe static strips.
I went over to Airdrie this morning to look at the Mazda, we had been discussing on the way over why it hadn't sold yet as it's been up for sale for a good few months and had run out of mot in the summer and hadn't been in for another one.
Anyway, we got there and the wee 323 was sitting in the corner, it hadn't been started in months and had no fuel in it. I did bring my own fuel which had been drained out of the Mercedes when I was changing the fuel filter.
I poured as much as I could in the car, a lot of it ended up spilling down the side of the car.
The seller didn't know anything about the car, it was a customers car that he had ended up with for some reason, he tried to start it but the starter motor would only catch occasionally and when it did fire he still couldn't get it going. He ended up draining the battery.
We got a booster pack on it and I eventually got it started, I poured some fuel into the carb and discovered that there was no air filter fitted.
I handed over the cash, insured it and jumped in.
It died a minute or so after driving it.
I had to stop and go through the whole process of trying to get the started motor to engage while feathering the throttle and getting the choke right.
I got it going again and set off for home.
There's a bit of steering wheel wobble and the tracking is out, it wasn't particularly pleasant to drive at lower speeds but a motorway speeds it was manageable.
I drove it 40 or so miles and it coped reasonably well, I had to leave the choke on all of the way, I imagine the lack of air filter wasn't helping it run correctly with no choke.
Everything was going fine until I got off the motorway and it died on the slip road.
I got it going again and it ran like crap for a couple of miles, I had to use my left foot on the brake while keeping the revs up and holding the choke out, if I let go of the choke, the lever wanted to pull back in.
I stalled a few more times before I got home.
46324781441_10ea0eb857_c.jpgRJC_5934 by srblythe, on Flickr
46324778011_3ca2449d95_c.jpgRJC_5935 by srblythe, on Flickr
46324785101_b86f5d5fd8_c.jpgRJC_5933 by srblythe, on Flickr
32452872948_f205cf2843_c.jpgRJC_5937 by srblythe, on Flickr
32452870798_1bcd8602a4_c.jpgRJC_5938 by srblythe, on Flickr
45601463984_3afdaabcf3_c.jpgRJC_5940 by srblythe, on Flickr
45601461074_97cac7184b_c.jpgRJC_5941 by srblythe, on Flickr
46324761021_5a16e66853_c.jpgRJC_5943 by srblythe, on Flickr
32452860868_ec6a9f94eb_c.jpgRJC_5950 by srblythe, on Flickr
It needs a bit of work but I think it's pretty cool. Can't wait to cover it in old giffer tat.
Double brown. Winning.
Looks bloody lovely does that. I can just imagine Norman and Gladys picking this up from their local Mazda dealer in 1983 and immediately fitting a tartan rug and a colostomy bag holder for those ‘incidents’. You are living the dream Shite Knight.
Didn't that belong to that guy who used to have a similarly old Accord, and then a Carina II in Edinburgh? I'm sure I've seen it in the same spot on Flickr...
It was his girlfriends we believe, I owned the accord and carina II x2 after the guy in Edinburgh had them
