Six Cylinders Motoring Notes - The last 3 days.
5 hours ago, Six-cylinder said:
I have just been given this book by my sister in law, how many do we own!
Books, or sisters-in-law? :)
Anybody going to Brackley Classic Car show this morning?
I will be there in our Alfa 156 V6 Sportswagon. I was going to take the Volvo V70 T5 but it has flat battery and deadlocked itself so the only way in to release the bonnet is through the the boot and I need help with that.
To be sure it's mine look on the driver's side for the dented front wing and door, also the rear door is the wrong shade of silver!
  • Six-cylinder changed the title to Six Cylinders Motoring Notes - Anybody going to Brackley Classic Car show this morning?
Sadly not as we've got guests here till this afternoon.  The New Year's Day Stoney one is the only thing I'll likely be to over the festive period.
I was thrown out of the Brackley Classic Car show for being to young!
Apparently there is a minimum 25 year old rule and I had to park in the street out of the display area.
It was a good show and would have been very hard to pick which of these cars to drive home.
  • Six-cylinder changed the title to Six Cylinders Motoring Notes - I was thrown out of the Brackley Classic Car show for being to young!
If you had taken the ZX, you would have been allowed in! :-)
This evening in the dark and rain ianbmw came round to help me and crawled through the V70 to release the bonnet catch so I could charge the battery.
I put the battery on charge and the hazards started flashing, but the remote would not switch them off or unlock the door deadlocks. Yes the battery was also flat in the remote. New battery in the remote and we will see what a night of charging does for the main battery.
the ponton and the truck behind it please
been 20 years since someone called you a young man no?? :D
Bristol or Dino I think for me? I actually wasn’t too far away in Oxford but in the modern car.
Seriously, treasure that moment. :)
  • Haha 4
You or the car?
On 12/25/2022 at 7:23 PM, hairnet said:
youtube it :P
Ah!
Today we have been back working on the Saab engine.
Timing gears on, sump on, heads on, rockers on, valve clearances done, flywheel on and clutch on.
Then we hit a stop! We were getting ready to refit the inlet manifold and Adrian suggested we unbolt the thermostat housing as steel screws in an aluminium housing is a recipe for disaster. Sure enough one of of the bolts snapped! I now have a job to drill out a steel bolt in an alloy manifold.
  • Six-cylinder changed the title to Six Cylinders Motoring Notes - What is growing in my Thermostat!
Frustrating to get so close but run into more jobs needing done, but at least you found that gunk before it caused overheating rather than after.  Seems good progress is being made though.
I assume there's not just a spare manifold amongst the spares you could swap over to allowing the snapped bolt to be dealt with at your leisure further down the road is there?
20 hours ago, Six-cylinder said:
an orangeman?
if ya see a fleg or a flute or a drum run like fook :D
Does beg the question about the state of the pipes you can’t see.
I have had the heads of it and there was no gung in them, all rubber pipes are being replaced and the water pump is being replaced. The only worry is the radiator and the heater which I will have try flush them out.
1 hour ago, Six-cylinder said:
ah, it's about the same strength as I make tea half the time then
I reckon this is a case of stuck thermostat + aluminium + mixed brands of antifreeze + time so all the silt is on one side - the manifold wasn't as bad as the pipe. Whatever it is  should be dissolvable though...
This is where distance is annoying as that flange would fit a small ultrasonic cleaner and I'd chuck it in there with half a dishwasher tab.
On 12/17/2022 at 12:37 PM, Six-cylinder said:
My pick of your year, @Six-cylinder
After a pretty dismal last half of 2022 and not being on here much I'm hoping to finally get to a FOD in 2023, be even better to have a ride in something French and hydro :)
We own 6 Hydro Citroens, 4 of which are on the road. The XM is out and about while the others have been put in undercover storage for the winter.
12 minutes ago, Six-cylinder said:
We own 7 Hydro Citroens, 5 of which are on the road. The XM is out and about while most of the others have been put in undercover storage for the winter.
FTFY
LOL, you know you have a problem when you're not even sure how many cars you own anymore!
  • Haha 3
