Six-cylinder Posted November 19, 2019 Author Posted November 19, 2019 2012 my son tidied it up for me, the first thing he asked for was buckets! richardthestag, Skizzer, egg and 1 other 4
richardthestag Posted November 21, 2019 Posted November 21, 2019 On 11/19/2019 at 9:14 AM, Six-cylinder said: @richardthestag What should this nozzle be connected too, you can feel it sucking air? The engine is from a 1988 3.5 EFi with ZF Auto gearbox. Vacuum hose connects it to the black plastic vacuum ball that sits on the n/s inner wing. It operates the fresh air vent on the heater unit Skizzer, Six-cylinder and Mrs6C 3
ianbmw Posted November 21, 2019 Posted November 21, 2019 Vacuum hose connects it to the black plastic vacuum ball that sits on the n/s inner wing. It operates the fresh air vent on the heater unit I've blanked it for the time being.....its a bit of donkey being a pre 3.5 shell!Sent from my SM-A530F using Tapatalk Six-cylinder 1
richardthestag Posted November 21, 2019 Posted November 21, 2019 Does the heater unit have a solenoid and vacuum pipe on the passenger side? Fresh air flap on early cars with the metal heater units were cable operated. Early 80s it got more complicated for some reason, the 1990 LHD car I am doing has a metal unit with later controls on the front and vacuum operated fresh air vent. Six-cylinder 1
ianbmw Posted November 21, 2019 Posted November 21, 2019 Does the heater unit have a solenoid and vacuum pipe on the passenger side? Fresh air flap on early cars with the metal heater units were cable operated. Early 80s it got more complicated for some reason, the 1990 LHD car I am doing has a metal unit with later controls on the front and vacuum operated fresh air vent.Hang on there. My instructions are to make it MOT worthy, not for everything to work!Its abit of a bitsa....so I will check at the weekend.It needs a mot firstSent from my SM-A530F using Tapatalk Six-cylinder and Mrs6C 2
ianbmw Posted November 21, 2019 Posted November 21, 2019 It has aircon, if that makes a difference...Most 80s Land rover products do, it developes over timeSent from my SM-A530F using Tapatalk chaseracer, egg, Noel Tidybeard and 2 others 2 3
richardmorris Posted November 21, 2019 Posted November 21, 2019 32 minutes ago, ianbmw said: Hang on there. My instructions are to make it MOT worthy, not for everything to work! Its abit of a bitsa....so I will check at the weekend. It needs a mot first Sent from my SM-A530F using Tapatalk Defeatist Mrs6C 1
ianbmw Posted November 21, 2019 Posted November 21, 2019 Defeatist 13 years of Range Rover ownership has taught me to aim low and always be pleasantly surprised when you exceed your target Sent from my SM-A530F using Tapatalk Mrs6C 1
richardmorris Posted November 21, 2019 Posted November 21, 2019 19 minutes ago, ianbmw said: 13 years of Range Rover ownership has taught me to aim low and always be pleasantly surprised when you exceed your target Sent from my SM-A530F using Tapatalk Pessimists are happier than optimists. Optimists are always disappointed with some aspect of life, but pessimists are occasionally proved wrong. ianbmw, chaseracer, coupso and 1 other 4
Andyrew Posted November 21, 2019 Posted November 21, 2019 48 minutes ago, ianbmw said: Most 80s Land rover products do, it developes over time Sent from my SM-A530F using Tapatalk This is true, My disco has developed new tech all on its own Self cleaning deep soak carpets, automatic wipers that come on by themselves rain or shine, additional floor ventilation to help the self washing carpets air out, And a self emptying engine oil system. It's just last week upgraded to a self draining coolant system now aswell. richardthestag, richardmorris, Mrs6C and 1 other 1 1 2
richardthestag Posted November 21, 2019 Posted November 21, 2019 2 hours ago, ianbmw said: 13 years of Range Rover ownership has taught me to aim low and always be pleasantly surprised when you exceed your target Sent from my SM-A530F using Tapatalk 15 years of Range Rover daily drivers has taught me that they are nowhere near as unreliable as folk* would have you believe. Plus you can fix em with hammers and .... welders ? Mrs6C, Andyrew and Sudsprint 3
richardthestag Posted November 22, 2019 Posted November 22, 2019 23 hours ago, richardthestag said: 15 years of Range Rover daily drivers has taught me that they are nowhere near as unreliable as folk* would have you believe. Plus you can fix em with hammers and .... welders ? should keep my stupid fat mouth closed, 11 miles into a drive home and it shat a core plug! gah, no lasting damage but no idea why it shat Plus took 4h 30m from incident to get 11miles back to Devon base. still at least I can fix it by hammering another coreplug back into the hole, with more threadlock this time tho ? Sudsprint, Six-cylinder, ianbmw and 1 other 3 1
Bfg Posted November 23, 2019 Posted November 23, 2019 . I'm sure you know ..but just in case not ; core plugs (which were once good and properly fitted) tend to pop either because they are corroded and then the block's heat expansion allows them to let go, or else the head gasket's blown and pressure build up in the cooling jackets finds the easiest route out. richardthestag 1
richardthestag Posted November 23, 2019 Posted November 23, 2019 1 hour ago, Bfg said: . I'm sure you know ..but just in case not ; core plugs (which were once good and properly fitted) tend to pop either because they are corroded and then the block's heat expansion allows them to let go, or else the head gasket's blown and pressure build up in the cooling jackets finds the easiest route out. At the risk of hijacking 6c most venerable thread, yep know that, just replaced core plugs with new and done head gaskets, more on my RR thread later
ianbmw Posted November 23, 2019 Posted November 23, 2019 At the risk of hijacking 6c most venerable thread, yep know that, just replaced core plugs with new and done head gaskets, more on my RR thread laterIncorrect, Brexit causes core plugs to blow out Sent from my SM-A530F using Tapatalk
Momentary Lapse Of Reason Posted November 23, 2019 Posted November 23, 2019 10 hours ago, ianbmw said: Incorrect, Bullshit causes core plugs to blow out Sent from my SM-A530F using Tapatalk coupso 1
richardthestag Posted November 24, 2019 Posted November 24, 2019 jalapenos and pickled gherkins cause me to blow off stonedagain 1
Tadhg Tiogar Posted November 24, 2019 Posted November 24, 2019 8 minutes ago, richardthestag said: jalapenos and pickled gherkins cause me to blow off Excellent. Better out than in.
Six-cylinder Posted November 26, 2019 Author Posted November 26, 2019 Mrs6C says it just fell off! egg, 500tops and Mrs6C 1 2
Six-cylinder Posted November 26, 2019 Author Posted November 26, 2019 Onto what! It is now in for a spot of sparkly stick treatment. Mrs6C and Skizzer 2
hairnet Posted November 26, 2019 Posted November 26, 2019 when you wee yerself with excitement at piloting those the water has to escape somewhere
Six-cylinder Posted November 26, 2019 Author Posted November 26, 2019 Maseratis will be Maseratis! All the rubber fuel pipes have been replaced because of fears of further rubber hoses cracking and leaking, bearing in mind there are rubber fuel hoses in the plenum chamber feed by hot turbos. MOT is now completed with just minor stuff like washers and number plate lights. So the car rewards us by the drivers window packing up, motor turns so I suspect the drive cog/rack thing as we have had a problem with one before. Anyway I collected it today and it is good fun! Floatylight, Skizzer, MorrisItalSLX and 5 others 8
Six-cylinder Posted November 26, 2019 Author Posted November 26, 2019 Is any body free on Saturday or poss Sunday to help me get the Xantia ready for transporting? In spite of my good advice Mrs6C says I need to have a replacement Auto gearbox fitted to the Xantia V6 and I have found one so need to get it transported from Buckingham to Welwyn Garden City next week. Problem 1, my regular transport guy says I am too heavy, well he has a 1400kg max pay load and the kerb weight for the Xantia V6 is 1490 kg so I need to find someone else. problem 2, small trees have grow around the car and need chopping down to get the car out. problem 3, there is a dead Triumph Herald and bench that need moving out of the way. problem 4, it needs a quick wash off to make it look like it is worth saving. The good news is it started with a jump and has lifted on its suspension. Floatylight, Mrs6C, Sudsprint and 1 other 4
richardmorris Posted November 26, 2019 Posted November 26, 2019 You do know how to make these invites sound so appealing. I don’t think I’m free, sorry. Six-cylinder 1
richardmorris Posted November 26, 2019 Posted November 26, 2019 I could be persuaded / bribed* to come up and help on Saturday. Anything interesting needing a little exercise? I’ve a meeting at Warwick university next Tuesday so could stop back at yours on the way home. Mrs6C 1
Six-cylinder Posted November 26, 2019 Author Posted November 26, 2019 4 minutes ago, richardmorris said: I could be persuaded / bribed* to come up and help on Saturday. Anything interesting needing a little exercise? I’ve a meeting at Warwick university next Tuesday so could stop back at yours on the way home. Bi Turbo needs taking to storage?
richardmorris Posted November 26, 2019 Posted November 26, 2019 4 minutes ago, Six-cylinder said: Bi Turbo needs taking to storage? Via Coventry? Ha! Mrs6C 1
