ianbmw Posted October 27, 2019 Posted October 27, 2019 Crikey that engine bay looks complete! I think we will give the chassis a good clean up and lick of paint before fitting the new tank.....it seems logical before its hidden by the tank.First start up video is a Must! I may or may not dance if it doesSent from my SM-A530F using Tapatalk
Six-cylinder Posted October 27, 2019 Author Posted October 27, 2019 4 minutes ago, ianbmw said: First start up video is a Must! I may or may not dance if it does My guess is it will take weeks before we get it started so maybe we could advertise for a video operator, interview, appoint and train somebody for the role! eddyramrod and Saabnut 2
ianbmw Posted October 27, 2019 Posted October 27, 2019 My guess is it will take weeks before we get it started so maybe we could advertise for a video operator, interview, appoint and train somebody for the role! It may take weeks for BP to stock pile enough fuel for it to run!Sent from my SM-A530F using Tapatalk
Six-cylinder Posted October 27, 2019 Author Posted October 27, 2019 1 minute ago, ianbmw said: It may take weeks for BP to stock pile enough fuel for it to run! Sent from my SM-A530F using Tapatalk That is only because you have used up Europe's entire stock of petrol in a week in your Range Rover!
Zelandeth Posted October 27, 2019 Posted October 27, 2019 Bet I could coerce that into starting in a couple of hours assuming nothing critical is missing/stuffed beyond bodging... Being injected makes it a little more difficult as a high pressure feed is needed if you're going to do more than drip feed it (which is bloody awkward on a V8), but I've got a HP pump so it's not impossible something could be cobbled together to run it from a can in the absence of a fuel tank. Running well is a different matter...but I'd bet I could get it to show signs of life... This used to be my Sunday afternoon game at a friend's farm. Dig a set of keys out the filing cabinet, find which long forgotten car out back it belonged to and see if I could get it going. Weren't many that foiled me... almost invariably due to dead electronic ignition systems or immobilisers I lacked the fob for. LightBulbFun 1
LightBulbFun Posted October 27, 2019 Posted October 27, 2019 8 minutes ago, Zelandeth said: Running well is a different matter... well that's a challenge for you then, could you get @Mrs6C Model 70 to actually idle? (then that means we could drive it!)
Zelandeth Posted October 27, 2019 Posted October 27, 2019 15 minutes ago, LightBulbFun said: well that's a challenge for you then, could you get @Mrs6C Model 70 to actually idle? (then that means we could drive it!) Can't be that difficult... challenge accepted if she wants me to take a look at it. Know my way around these cars reasonably well now. I'd probably just pull the carb off and bring it back here to be pulled apart and thoroughly cleaned. That's probably all she will need. Would do the fuel pump at the same time as it's probably as full of gunk as the carb. Been looking for a proper test run for the new ultrasonic cleaner... LightBulbFun and Mrs6C 1 1
Mrs6C Posted October 27, 2019 Posted October 27, 2019 5 minutes ago, Zelandeth said: Can't be that difficult... challenge accepted if she wants me to take a look at it. Know my way around these cars reasonably well now. I'd probably just pull the carb off and bring it back here to be pulled apart and thoroughly cleaned. That's probably all she will need. Would do the fuel pump at the same time as it's probably as full of gunk as the carb. Been looking for a proper test run for the new ultrasonic cleaner... Well volunteered! The carb. is off already and at home in the garage, waiting to be cleaned... if you'd like to give it a go then please be my guest! @Andyrew has very kindly taken the manifold home to weld the air cleaner support strut back on as it had succumbed to fatigue and cracked across at the base... The handbrake return springs have arrived, too. @Six-cylinder bought a pair, so I'll put the one into stock. LightBulbFun 1
LightBulbFun Posted October 27, 2019 Posted October 27, 2019 your also welcome to do REV's at the same time if you want to (and im happy to accompany you for a weekend or something if you want, anything towards getting anyone's Model 70 im game for! I would like to get REVs fuel tank out at some point so we can see what it needs, and have it fixed ahead of when the rest of the work on REV is done, so the fuel tank is not holding everything up, as the fuel tank is the one "big thing" im worried that might take a little bit of time etc to sort out etc)
Zelandeth Posted October 27, 2019 Posted October 27, 2019 More than happy to drop by tomorrow to grab the carb and bring it back here for some TLC. Do you have a carb gasket set among the spares stash? If not I'll do my best to keep the original in one piece. Really need to get myself some more gasket paper so I can just make new ones when needed. Mrs6C and LightBulbFun 1 1
LightBulbFun Posted October 27, 2019 Posted October 27, 2019 3 minutes ago, Zelandeth said: More than happy to drop by tomorrow to grab the carb and bring it back here for some TLC. Do you have a carb gasket set among the spares stash? If not I'll do my best to keep the original in one piece. Really need to get myself some more gasket paper so I can just make new ones when needed. checking the spares stash list I dont see any gaskets sadly, but might be worth having a root around the boxes still (as a side note, iv been wondering, whats an "engine bar"?)
Mrs6C Posted October 27, 2019 Posted October 27, 2019 30 minutes ago, Zelandeth said: More than happy to drop by tomorrow to grab the carb and bring it back here for some TLC. Do you have a carb gasket set among the spares stash? If not I'll do my best to keep the original in one piece. Really need to get myself some more gasket paper so I can just make new ones when needed. That would be great, many thanks! Let me know what time would suit you and we'll have the kettle on! I don't remember seeing any gasket sets with the spares, but it's possible we have some gasket paper. I will enquire of @Six-cylinder! LightBulbFun 1
Zelandeth Posted October 28, 2019 Posted October 28, 2019 I'll aim for 1400 if that works for you? Should give me plenty of time to get the dogs walked etc. I'll drop you a PM if I'm running late. LightBulbFun 1
Six-cylinder Posted October 28, 2019 Author Posted October 28, 2019 11 hours ago, ianbmw said: Crikey that engine bay looks complete! I think we will give the chassis a good clean up and lick of paint before fitting the new tank.....it seems logical before its hidden by the tank. First start up video is a Must! I may or may not dance if it does Sent from my SM-A530F using Tapatalk What sort of paint do I need to buy?
richardmorris Posted October 28, 2019 Posted October 28, 2019 3 hours ago, Six-cylinder said: What sort of paint do I need to buy? The very expensive and extremely rare sort. Mrs6C 1
ianbmw Posted October 28, 2019 Posted October 28, 2019 What sort of paint do I need to buy?Owning plenty of rusty Land Rover products means I come with my own supplies!Sent from my SM-A530F using Tapatalk Mrs6C 1
Six-cylinder Posted October 28, 2019 Author Posted October 28, 2019 23 minutes ago, ianbmw said: Owning plenty of rusty Land Rover products means I come with my own supplies! Sent from my SM-A530F using Tapatalk What you have got some left! Mrs6C 1
Six-cylinder Posted October 28, 2019 Author Posted October 28, 2019 I collected our Metro today after having a few bits attended to before it gets put away for the winter. Fuel leak from the gauge sender unit, exhaust blow manifold to down pipe and poor running at idle all now sorted. It runs really well and looks good. I had the paint rectified on the front wings and I now have the MG graphics, but I think I am going to wait until spring now before fitting them. This is how it had ended up before we got it. Sudsprint, Tickman, privatewire and 23 others 25 1
LightBulbFun Posted October 28, 2019 Posted October 28, 2019 wow thats come a long way since that bottom picture! looks really nice (did ya get the weather strip problem sorted out in the end?)
richardmorris Posted October 28, 2019 Posted October 28, 2019 3 minutes ago, LightBulbFun said: wow thats come a long way since that bottom picture! looks really nice (did ya get the weather strip problem sorted out in the end?) He happened to be parked next to a few other identical cars with good weather strips at Milton Keynes museum..... Six-cylinder 1
Six-cylinder Posted October 28, 2019 Author Posted October 28, 2019 3 minutes ago, LightBulbFun said: wow thats come a long way since that bottom picture! looks really nice (did ya get the weather strip problem sorted out in the end?) I have not managed to find any replacements at the moment.
bezzabsa Posted October 28, 2019 Posted October 28, 2019 would a discovery V8 tank fit the RR? as there seems to be a glut of V8 series 1 &2 disco's being broken lately on FB market place
Six-cylinder Posted October 28, 2019 Author Posted October 28, 2019 1 minute ago, bezzabsa said: would a discovery V8 tank fit the RR? as there seems to be a glut of V8 series 1 &2 disco's being broken lately on FB market place I have managed to find a s/h tank, ianbmw is planning to help me 9/10 Nov with fitting it. bezzabsa and Floatylight 2
bezzabsa Posted October 28, 2019 Posted October 28, 2019 Cracking!!! miss mt 4x4's .. but can't justify one now theres only me!! 3 Range Rovers 2 V8's 1 300Tdi softdash.. 5 discoveries inc V8 200 & 300 Tdi 110 Turbo diesel 90 Turbo diesel freelander diesel 8 assorted Series Landies 2 Pajero's 2 Lada Nivas Saabnut, Six-cylinder and chaseracer 3
richardthestag Posted October 29, 2019 Posted October 29, 2019 forgot that yours would be a steel tank. I might have lobbed in a complete plastic tank from a 1990 onwards RR or any of the Disco 1s The pump sits inside and it doesnt have half of the pipes and stubs that will leak Anyways there should be no issue with fuel as my Blue RR is off the road for the next week or so Six-cylinder 1
Momentary Lapse Of Reason Posted October 29, 2019 Posted October 29, 2019 3 hours ago, richardthestag said: <snip> or any of the Disco 1s The pump sits inside <snip> No in tank pump on the diesel Disco1s. hth
Six-cylinder Posted October 31, 2019 Author Posted October 31, 2019 Winter is coming, I SORNed 7 cars today. egg and The Moog 2
LightBulbFun Posted October 31, 2019 Posted October 31, 2019 3 minutes ago, Six-cylinder said: Winter is coming, I SORNed 7 cars today. Looks like ya missed one (on a more serious note regarding winter, have Dolly and REV been covered up with anything? im just a little bit concerned about their wellbeing over the winter given that I dont think there entirely water tight LOL)
Mrs6C Posted October 31, 2019 Posted October 31, 2019 39 minutes ago, LightBulbFun said: Looks like ya missed one (on a more serious note regarding winter, have Dolly and REV been covered up with anything? im just a little bit concerned about their wellbeing over the winter given that I dont think there entirely water tight LOL) No paperwork back from the DVLA yet. I did wave at everyone in the building the other day when I passed it, but it didn't make any difference... Car covering is on the list of jobs to do before the winter sets in, small blue three-wheelers included... LightBulbFun and egg 2
Zelandeth Posted October 31, 2019 Posted October 31, 2019 50 minutes ago, LightBulbFun said: Looks like ya missed one (on a more serious note regarding winter, have Dolly and REV been covered up with anything? im just a little bit concerned about their wellbeing over the winter given that I dont think there entirely water tight LOL) I wouldn't worry too much as they're not that we'll sealed, water can get back out again. Far worse in a normal car where any water getting in will tend to get trapped. egg and LightBulbFun 2
