Slowsilver Posted October 19, 2019 Posted October 19, 2019 5 hours ago, Six-cylinder said: This gave the VP1500 a chance for a run out and while it took quite a bit of cranking to start it from cold, it ran very nicely and restarted easily several times while running errands. Funny you should mention this. The one small problem with the Maxi is the length of time it needs to be cranked for before it will start when it has been left unused for more than two or three days. It always starts eventually but takes 30 seconds or more of continuous cranking before it will fire. After it has started once it will restart straight away, even if left long enough to need the choke again, or even the next morning. It has a fairly new battery but I am concerned that when the weather gets colder and it is left for say a week there may not be enough charge in the battery to crank it for this length of time. Fortunately it lives in a garage with power, so I bought a trickle charger to leave connected to it just in case. Maybe this is a common problem with the E series engines but so far I have been unable to find any reference to it elsewhere.
Zelandeth Posted October 19, 2019 Posted October 19, 2019 (edited) My Skoda was always bad for that. Figured out it was because the fuel was draining back to the tank - always had planned to put a none return valve in the line (guessing the one built into the pump is a bit weak), but it never made it to the top of the to do list. If I manually primed it and filled the float bowl with the handle on the pump she would fire instantly. The carb sits on top of the exhaust manifold in that too so on a warm day or after a fast run it would boil the fuel in the carb off pretty quickly too (guessing the additional volatility of modern fuel doesn't help there) which might make a cold start harder too if the lines *and* the float bowl are empty. If there's fuel in the bowl it will usually start on that and run long enough to prime things, likewise if there's fuel waiting in the line to refill an empty bowl...but if they're both dry it will take a fair bit of cranking before she will go. Edited October 19, 2019 by Zelandeth bloody autocorrect
Noel Tidybeard Posted October 19, 2019 Posted October 19, 2019 our old 1500 super needed one good crank with full choke then would start on second crank ax wheel trim- the black ring isn't still in the wheel is it- i have seen that on psa dustbin lids before
Essex V6 Posted October 20, 2019 Posted October 20, 2019 I have had the same issue with my 3.0S Capri for the last few years. Leave it for any longer than a couple of days and it takes heaps of cranking to fire up. Restarts immediately thereafter Six-cylinder 1
SiC Posted October 20, 2019 Posted October 20, 2019 Does the VP + Maxi have a mechanical fuel pump? Can certainly imagine them requiring a fair bit of cranking to get fuel back up. I know the electric fuel pump on my MGB helps it going within 10 seconds, even if it's been sat a long time. Six-cylinder 1
catsinthewelder Posted October 20, 2019 Posted October 20, 2019 Guilty ? Smallest one is looking forward to the next FoD meet even more ? Six-cylinder 1
Six-cylinder Posted October 20, 2019 Author Posted October 20, 2019 4 minutes ago, catsinthewelder said: Guilty ? Smallest one is looking forward to the next FoD meet even more ? PM me your address and I will post it back.
Six-cylinder Posted October 20, 2019 Author Posted October 20, 2019 9 hours ago, Noel Tidybeard said: ax wheel trim- the black ring isn't still in the wheel is it- i have seen that on psa dustbin lids before I have checked the wheel and it is not there. Does anybody have a PSA 13 inch fitting ring they can sell me?
Slowsilver Posted October 20, 2019 Posted October 20, 2019 2 hours ago, SiC said: Does the VP + Maxi have a mechanical fuel pump? Can certainly imagine them requiring a fair bit of cranking to get fuel back up. I know the electric fuel pump on my MGB helps it going within 10 seconds, even if it's been sat a long time. Yes they do. I thought this might be the problem as all the BL stuff I have owned with electric fuel pumps has started promptly even after standing for a long time. The valves in the pump should prevent the fuel from leaking back but I thought they could be a bit leaky so I fitted a new fuel pump but no improvement. Even if they were they would only drain the feed pipe to the carb, not the float chamber. I took the top off the float chamber after it had been standing for a week and it was about half full, which I think should be enough to start it, although I topped it up from a fuel can anyway but it still took the same amount of cranking time to start. Six-cylinder 1
Six-cylinder Posted October 20, 2019 Author Posted October 20, 2019 @catsinthewelder is trying to repair the Jingling ATV's broken engine casing that connects to gearbox, his chosen method of repair is to plant the gearbox and wait for the casing to grow. He assures me that the secret of success is watering with EP80 oil! Skizzer, LightBulbFun, TooManyPeopleMovers and 4 others 7
dean36014 Posted October 20, 2019 Posted October 20, 2019 Chris, did you have any experience with Texalarms back in your Citroen days? I've just removed the system from my zx as I get getting random alarms going off. It seemed a shame to remove it as it had an immobiliser function too. I was quite surprised to find it piggy backed into the citroen wiring using the correct plugs. They are two little dip switches on the side of the control box that I have no idea what they do and wondered if you remembered the system at all?
Six-cylinder Posted October 20, 2019 Author Posted October 20, 2019 1 hour ago, dean36014 said: Chris, did you have any experience with Texalarms back in your Citroen days? I've just removed the system from my zx as I get getting random alarms going off. It seemed a shame to remove it as it had an immobiliser function too. I was quite surprised to find it piggy backed into the citroen wiring using the correct plugs. They are two little dip switches on the side of the control box that I have no idea what they do and wondered if you remembered the system at all? Sorry I don't remember any Texalarms although I was selling Citroens when your car was born. dean36014 1
dean36014 Posted October 20, 2019 Posted October 20, 2019 Looking in to it a bit it seems they were dealer fit alarms. They seem to be the company that made Cobra alarms.
Six-cylinder Posted October 20, 2019 Author Posted October 20, 2019 I remember Tex alarms from when I was selling Motor parts, but that was the early 1980s.
Six-cylinder Posted October 25, 2019 Author Posted October 25, 2019 It's Friday so shopping, AX is my favourite shopping car but next to the other shopping cars it just keeps shrinking! adw1977, 500tops, egg and 6 others 9
Ben_O Posted October 25, 2019 Posted October 25, 2019 I can't believe how much smaller the ax is to the 107 next to it! Dick Cheeseburger and 500tops 2
Six-cylinder Posted October 25, 2019 Author Posted October 25, 2019 4 minutes ago, Ben_O said: I can't believe how much smaller the ax is to the 107 next to it! And the Zoe made the 107 look small.
quicksilver Posted October 25, 2019 Posted October 25, 2019 On 10/19/2019 at 6:05 PM, Six-cylinder said: Today Mrs6C came out with me as spotter, yes spotter we were looking for the lost AX wheel trim. The good new is we found it but the bad news was the plastic ring with metal band that pushes into the wheel is still lost. This gave the VP1500 a chance for a run out and while it took quite a bit of cranking to start it from cold, it ran very nicely and restarted easily several times while running errands. I hope I did not get caught by Quicksilver's stasi police this time! No posh Allegros seen on Saturday. I think I saw the AX again on Sunday though as it whizzed past while I was getting off the bus. That little car seems to be getting plenty of use - I guess it's ideal as a town car.
Six-cylinder Posted October 26, 2019 Author Posted October 26, 2019 What a wet miserable day, the only car related thing I have to report is the postman has bought the brake return springs I ordered for Mrs6C's Invacar. They has only taken 16 days to travel from China, seems good to me. LightBulbFun, egg, Mrs6C and 1 other 4
Zelandeth Posted October 26, 2019 Posted October 26, 2019 That is quite an eye opener seeing the 107 next to the AX...107 never felt big when I owned mine, though it was like a bloody TARDIS. Never figured out how they managed to fit so much space into such a relatively small footprint...still reckon that they're really cleverly packaged motors. If I was looking for a daily modern runaround I'd definitely have another one without a second of hesitation. Especially the generation after that where they had addressed pretty much all the shortcomings I found with mine. Mostly the seats weren't comfortable, the gearchange felt like it was made by Fisher Price and there was an annoying flat spot at 4500rpm on full throttle. The Auto I had as a rental (2015 I think) very much felt like the same car - but far more grown up. Sadly lost the big glowing bit of dash around the heater controls which I thought looked really nicely different on the earlier cars.
Six-cylinder Posted October 26, 2019 Author Posted October 26, 2019 I test drove the C1 2007ish, I could have bought a pre reg, delivery mileage for £6k from Stoney Stratford Citroen but the road noise on the A5 duel carriage way was appalling. I bought a Fiat 500 but that was not great in other ways.
Zelandeth Posted October 26, 2019 Posted October 26, 2019 The road noise is quite intrusive, though it was far better when I replaced the stock tyres with some made of rubber rather than plastic. Reckon a bit of Dynamat in a few places would have helped a lot. LightBulbFun 1
Six-cylinder Posted October 27, 2019 Author Posted October 27, 2019 Failure to proceed from the Allegro today, smoke from the wire between solenoid and starter itself. Post on the back of the starter wobbly, but I have run out of time now because I have another mission to attend too with somebody else! Mrs6C 1
NorfolkNWeigh Posted October 27, 2019 Posted October 27, 2019 On 25 October 2019 at 12:47 PM, Six-cylinder said: And the Zoe made the 107 look small. A friend has bought 2 Zoes to use as courtesy cars for his garage business, had a play in one of them yesterday. There is not a lot of space inside , thats for sure. The last time I drove an AX it didn't feel as cramped, admittedly that was 30 years ago and I'm quite a bit bigger now. Anyway 50 mile range is pretty useless and at 1500kg is probably twice the weight of an AX
richardthestag Posted October 27, 2019 Posted October 27, 2019 Hi Chris For used RR bits to do the LHD conversion I have been using Tim Hammond in Yorkshite Landie Journo and serial RR licker What he doesn't know about 1980s RR doesn't need to be known plus he has a barn full of parts, I have his number if you want it. He trades through ebay https://www.ebay.co.uk/itm/Range-Rover-Classic-Spares-Large-Amount-Of-Parts-In-Stock-Breaking/113889706501?hash=item1a845b0205:g:dD0AAOSwjMBcftB6 Six-cylinder and Mrs6C 2
richardthestag Posted October 27, 2019 Posted October 27, 2019 On 9/30/2019 at 12:55 AM, Zelandeth said: Like far too many times for Atlantic Garages Del Lines' Stag Estate read upon it here https://www.pressreader.com/australia/classics-monthly/20190701/281586652104213 Six-cylinder and Sudsprint 2
Six-cylinder Posted October 27, 2019 Author Posted October 27, 2019 1 hour ago, richardthestag said: Hi Chris For used RR bits to do the LHD conversion I have been using Tim Hammond in Yorkshite Landie Journo and serial RR licker What he doesn't know about 1980s RR doesn't need to be known plus he has a barn full of parts, I have his number if you want it. He trades through ebay https://www.ebay.co.uk/itm/Range-Rover-Classic-Spares-Large-Amount-Of-Parts-In-Stock-Breaking/113889706501?hash=item1a845b0205:g:dD0AAOSwjMBcftB6 My friend @ianbmw has been very busy lately and progress has been limited to buying a replacement fuel tank as one of the retaining tangs for the fuel gauge sender had rotted away and would not seal. Weekend 9/10 November has been allocated to fitting the fuel tank and trying to get it started so we can see what it needs. I am going to need a new centre console that fits the old dash but accommodated the ZF Auto that has been fitted . I am told no UK car had this arrangement but some overseas cars did. Thanks for the lead for getting parts. richardthestag 1
richardthestag Posted October 27, 2019 Posted October 27, 2019 need a yootoob vid of the grand 1st start up ?
Six-cylinder Posted October 27, 2019 Author Posted October 27, 2019 9 minutes ago, richardthestag said: need a yootoob vid of the grand 1st start up ? Beyond my capability, but this is how it is now. richardthestag and Mrs6C 2
