dieselnutjob Posted May 1, 2021 Author Posted May 1, 2021 One of the harder parts was getting the starter motor off. Once you see these photos it's obvious, but when it's on the car it's very difficult to figure out because you just cannot see the bolts. The official Peugeot manual was no help, neither was the Renault 30 nor Volvo 740 / 760 Haynes manuals. However the Volvo 260 Haynes manual (number 400) had a beautiful photo of the starter motor which really helped. The struggle was figuring out how the forward end (near the oil filter) is attached. It's held on by the two slots that you can clearly see once it's off which is located onto the block with the two bolts shown here I didn't do much yesterday. This morning I just put all of the bolts into the right holes and made sure that all of the holes had a bolt. I know that this engine will be out for a while and I know that in a few weeks time I won't remember where everything is or where it goes. Burnside, Dead_E23 and spartacus 3
Tadhg Tiogar Posted May 1, 2021 Posted May 1, 2021 2 minutes ago, dieselnutjob said: ... in a few weeks time I won't remember where everything is or where it goes. This is a major reason why I never dare to get involved with DIY mechanical jobs.
spartacus Posted May 1, 2021 Posted May 1, 2021 @dieselnutjob, this is a 'go to' thread for me now, I'm loving the progress you're making on what was frankly a forgotten car. Please be careful working in that tight space, although I do understand it's all you've got.
dieselnutjob Posted May 1, 2021 Author Posted May 1, 2021 5 minutes ago, spartacus said: @dieselnutjob, this is a 'go to' thread for me now, I'm loving the progress you're making on what was frankly a forgotten car. Please be careful working in that tight space, although I do understand it's all you've got. yes it is a little tight but I am absolutely loving it. I haven't really had a proper weather proof enclosed space to work in before, and being able to just leave stuff where it is to have a break or even come back to it the next day is such a relief. The access road that the garage is on is now secure (there are security gates across all the entrances) so I don't have to worry that someone is going to nick my tools if I leave it open whilst I go away for 1/2 hour. In comparison four years ago I changed the turbo on the Jag on my front drive and I just hate working like that. Every time I needed a tool that I hadn't anticipated I have to go through the house to get it and being a busy road I just couldn't leave things for more than a few minutes. There was also the soul destroying feeling of a rain shower starting. spartacus, Burnside and mk2_craig 3
dozeydustman Posted May 2, 2021 Posted May 2, 2021 It's Saturday night, the wife is asleep, I'm drunk which is a very bad thing as I'm supposed to be on emergency callout as of 9am tomorrow and I've just discovered this thread. Who needs redtube or xhamster when there is a 604 on show? Asimo 1
dieselnutjob Posted May 2, 2021 Author Posted May 2, 2021 I posted a question on Aussiefrogs seven years ago about the PRV engine and finally got an answer. The post is here https://www.aussiefrogs.com/forum/index.php?threads/prv-v6-top-end-lubrication-mod.113300/ The oil pressure on this engine is maybe a little low, but then equally I was running it on fully synthetic oil (I think 5W40) and it's maybe too thin. Edit: let me clarify. On a normal idle the light doesn't come on. But if the idle is a bit low then the light starts flickering. Normal advice is that these "modern" oils are too thin for a classic, but according to the Renault Alpine folks the PRV engines were actually manufactured to pretty modern tolerances and they think that modern synthetics are good for them. So given how much work it is to get these engines out should I strip it down and check stuff? Or just do the obvious and easy (front and rear oil seals, rocker arms because I have some good ones). If I have to pull the front pulley to change the oil seal (and I do) then I could pretty easily pull off the timing cover and check out the chain and tensioners at the same time. I checked the compression last year and it was good on all six. There's no blue smoke from the exhaust but I can't tell what oil consumption is like because it leaks out of the engine so fast.
carlo Posted May 2, 2021 Posted May 2, 2021 What a great thread, could get me addicted to Autoshite again. As a form of encouragement here's a picture of it in action when I met you at the National in 2014 Angrydicky, Soundwave, Datsuncog and 3 others 6
dieselnutjob Posted May 2, 2021 Author Posted May 2, 2021 I have been chatting on WhatsApp with someone in CPUK and he has convinced my not to worry about the oil galleries. He said the same thing that I was kind of thinking, which is that drilling out galleries should only be done in the context of a total stripdown so that swarf can by properly cleaned out. However I am going to have a go at getting the rocker arms off. On one side the shaft can easily be slid out but on the other I think it has to go either through or past the camshaft drive sprocket and the timing cover definitely has to come off. I just found out that Deloreango has plenty of stock of timing cover gaskets so that settles it.
Magnificent Rustbucket Posted May 2, 2021 Posted May 2, 2021 I've always loved the 604, particularly the earlier ones. 500tops 1
Asimo Posted May 2, 2021 Posted May 2, 2021 When you put the rocker / cam covers back be careful with the gaskets. The chap I sold my PRV-engined Alpine to (it was in bits) called me in a panic when he got it back together and running because of a loud knocking from the top end. I had told him the engine was sound - as it was. To cut his long story short, he had been sold the wrong gaskets, they were too thin and as a result the rockers were knocking on the covers. The same pressed-steel covers your engine has. somewhatfoolish 1
Tag2664 Posted June 4, 2021 Posted June 4, 2021 Keeping my eye on this one as my Tagora has much of the same gear underneath it. Isopon, RoadworkUK, Dick Cheeseburger and 1 other 4
carlo Posted June 5, 2021 Posted June 5, 2021 16 hours ago, Tag2664 said: Keeping my eye on this one as my Tagora has much of the same gear underneath it. Do pictures of this Tagora exist on here? I would kill to have one. Talbot 1
Tag2664 Posted June 5, 2021 Posted June 5, 2021 I don't think so, I was a member here years ago but don't think I posted any pics. Until now! Soundwave, Isopon, Talbot and 23 others 26
brownnova Posted June 5, 2021 Posted June 5, 2021 15 minutes ago, Tag2664 said: I don't think so, I was a member here years ago but don't think I posted any pics. Until now! A right hand drive Tagora!!!!! Be still my beating heart!!! Please start a thread on this, I’d love to know more!!!! dozeydustman, Isopon, 500tops and 3 others 6
carlo Posted June 7, 2021 Posted June 7, 2021 On 6/5/2021 at 3:50 PM, Tag2664 said: I don't think so, I was a member here years ago but don't think I posted any pics. Until now! You're not the previously titled Boobydoo are you? With BEA83Y?
JimH Posted June 8, 2021 Posted June 8, 2021 Sigh. What happened to calm cars? Cars that were styled in a less is more sort of a way with each of their three boxes styled in proportion, a low waistline and plenty of glass so people can see how well dressed you are. 604s, Fiat 130s, Lancia Trevi (honourable mention to the why the bloody hell did they not build it Gamma Scala), the Mk2 Granada. Why can't we have these things back? Imagine how clean and tidy they would be with modern production and design. Wouldn't it be so much nicer than some pre-crashed, stumpy bonneted Darth Vader helmet with a roofline close to the stars. somewhatfoolish, Talbot, DSdriver and 3 others 5 1
JimH Posted June 8, 2021 Posted June 8, 2021 Apols for being off topic but bugger me, isn't this a looker? The sort of car that forces you to dress better. Magnificent Rustbucket, Datsuncog, brownnova and 2 others 5
dieselnutjob Posted June 8, 2021 Author Posted June 8, 2021 I have always liked the look of the Fiat 130 two door coupes, but whilst googling for images of it I found a four door version. wow Crackers, brownnova, Datsuncog and 1 other 4
dieselnutjob Posted June 8, 2021 Author Posted June 8, 2021 This is a funny read https://www.aussiefrogs.com/forum/index.php?threads/604-is-it-the-coolest-euro-ever-made.87074/
Tadhg Tiogar Posted June 8, 2021 Posted June 8, 2021 1 hour ago, dieselnutjob said: This is a funny read https://www.aussiefrogs.com/forum/index.php?threads/604-is-it-the-coolest-euro-ever-made.87074/ There's enough cool in there to make a dent in global warming.
dieselnutjob Posted June 10, 2021 Author Posted June 10, 2021 The 604 was used as a goon car in Never Say Never Again Magnificent Rustbucket 1
Tag2664 Posted June 10, 2021 Posted June 10, 2021 On 6/7/2021 at 4:55 PM, carlo said: You're not the previously titled Boobydoo are you? With BEA83Y? Nope, not me.
somewhatfoolish Posted June 10, 2021 Posted June 10, 2021 Phwoar, 604 and a Tagora. There can never be too much soft and squidgy barge action.
Magnificent Rustbucket Posted June 18, 2021 Posted June 18, 2021 On 6/8/2021 at 11:55 AM, JimH said: Apols for being off topic but bugger me, isn't this a looker? The sort of car that forces you to dress better. This to my eye at least has a slight overtone of the Peugeot 505 - another elegantly styled big Peugeot - particularly around the rear pillar and in the relationship of the glass to the body. I like quite a few of Paolo Martin's creations, not just the 604. The 104 was especially neat, the 130 particularly elegant - andd the Camargue remains one of my favourite cars. A friend of my late father owned a Camargue in the early '80s. Riding in a Camargue was such an event even the normal Shadow felt ordinary after it. And who could forget the Ferrari Modulo from Top Trumps?
Richard_FM Posted June 18, 2021 Posted June 18, 2021 I remember the Ferrari Modulo was in the Usbourne Supercars book. I think it was built around a 512 sportscar chassis.
Richard_FM Posted June 18, 2021 Posted June 18, 2021 On 6/8/2021 at 12:30 PM, dieselnutjob said: It's a shame Fiat never but either into production, there was also a convertible show car.
dieselnutjob Posted July 29, 2021 Author Posted July 29, 2021 I started looking into rust in the engine bay, which can only be fixed now with the engine out. This is the drivers side "chassis" rail that runs along the bottom of the inner wing. you can see some holes where the metal has become so thin that holes have formed and this is view of the same rail from underneath I also made the mistake of poking at some loose underseal on the wheelarch / splash guard thing Minimad5 and adw1977 2
