tooSavvy Posted October 28, 2020 Author Posted October 28, 2020 Today I was wanting a blast of 'super toasty' up onto the screen, to clear fogging.... The 'up to screen only' lever is great but I'm not getting really hot air 😕 The set up is a bowden cable/slap across Blue:Red lever..... this moves the bleed flap [heater core always hot] to mix air for hot/cold. It would seem some sort of loss is jamming it short of full HOT. Diagrams and the web forum describe a fairly simple test/check + fix. This time of year it is at the top of the list...... Â
tooSavvy Posted October 29, 2020 Author Posted October 29, 2020 My mudflaps arrived..... Softly flexible and just the job! Ordered a dizzy cap + rotor (megga cheep, with promo code too).... I'm going to research the cost of a set of Hi Energy leads. 3 NGK in the works. Sparks are crucial to safe/reliable running. *if it ever stops raining I will drop the oil 😕 Â
barefoot Posted October 29, 2020 Posted October 29, 2020 This thread needs many, many more pictures. I'd particularly like to see the seats, the gear selector, the air con button, the view from the driver's seat, the view from the back, and the boot/opening. tooSavvy 1
tooSavvy Posted October 29, 2020 Author Posted October 29, 2020 I remember a rally commentator being told (by a Finnish co driver) "Well, as long as I'm not looking out the rear window we're doing OK!" Hannu Mikkola [sooo sideways] may have been the driver.
tooSavvy Posted October 29, 2020 Author Posted October 29, 2020 On 29/10/2020 at 13:25, barefoot said: This thread needs many, many more pictures. I'd particularly like to see the seats, the gear selector, the air con button, the view from the driver's seat, the view from the back, and the boot/opening. ...... heres a piccy, on account. *these rust away on Micras/Sunnys I believe 😕
tooSavvy Posted October 30, 2020 Author Posted October 30, 2020 Mudflaps on.. check YaY..!! 500tops, Jim Bell, DoctorRetro and 1 other 4
tooSavvy Posted October 30, 2020 Author Posted October 30, 2020 Heater issues were less than taxing...... The white plastic lever is quite plainly hanging off the side of the heater, under dash, and likely thwacked by a foot!! I flipped the lever to cold, which moved the Pin as far away from the pivot point as poss >> flicked White arm over Pin, pin into Track >>> flipped lever to hot and it fully returned + locked the flap combo onto 'Super Toasty Warmest' Result...... BeEP, rainagain, Shirley Knott and 2 others 5
tooSavvy Posted October 31, 2020 Author Posted October 31, 2020 Moar piccies..... ? Pesky rear swing arm location.... MOT mans dream....
tooSavvy Posted November 1, 2020 Author Posted November 1, 2020 Hmmm.... Made an interesting discovery! The 3potta G10 has a 'bolt on' bottom pulley... that is... it is removable from the Timing Belt bottom sprocket. https://www.onlinecarparts.co.uk/ashika-8914356.html If I d.i.y. the timing belt/tensioner, I don't need the fabled WindyGun/CrankBolt loosening grief *likely be 'cut 3/4 width of old belt..strip away & thread on new belt..cut last 1/4' >>> reassemble! Neither toothed wheel has a guide lip = slip on FTW! Jim Bell 1
Dirk Diggler Posted November 1, 2020 Posted November 1, 2020 And a G10 is non interference Jim Bell 1
tooSavvy Posted November 1, 2020 Author Posted November 1, 2020 43 minutes ago, Dirk Diggler said: And a G10 is non interference Roulette is, my default..... *ToMM© N.I. Dirk Diggler 1
tooSavvy Posted November 2, 2020 Author Posted November 2, 2020 Reversing out of a bay, today, I realise my Hi-Line red brake light is off... It gets 'slammed' every time the hatch closes so mebbies the bulb has popped... I have a stick of LEDs which I could reconfigure to two rows and 'lash up'. Liking the LED on ToMM© so much >>>> Yeah, plan formingÂ
tooSavvy Posted November 3, 2020 Author Posted November 3, 2020 So then..... Hows my motor for 22yr young 😕  ...... not tooShabby lol rainagain and Shirley Knott 2
tooSavvy Posted November 3, 2020 Author Posted November 3, 2020 @7:45.... Draining, while simultaneously refilling with new ATF, guarantees the whole tranny is refilled with fresh. I'm not going to replace the filter/drop oilpan as the box is likely in good shape >>> the oil is just bloody ancient !!
tooSavvy Posted November 4, 2020 Author Posted November 4, 2020 Yes! LopSided 'comedy hour' C.B.A. lol
tooSavvy Posted November 4, 2020 Author Posted November 4, 2020 The passenger door mirror (powered) has been rattling around in the shell since I got the car.... Won't fall out though 😕 I have found the axis motor locator tabs are snapped off (well, half are missing...) so FCUKIT 2pack Poondies epoxy has been splurged about + location/pressure wedges until fully hardened THAT should fix the barsteward..... YaY..... It Has Jim Bell 1
tooSavvy Posted November 5, 2020 Author Posted November 5, 2020 Watch JRGo! >>>> Does My Car!! What a hoot
tooSavvy Posted November 6, 2020 Author Posted November 6, 2020 Young fella brayyed on my door = left package on doorstep.... Oil Filter have 4.5L 10W40 @HomeBargains Just need a bit of warm + dry day.
tooSavvy Posted November 7, 2020 Author Posted November 7, 2020 ........ so then, oil filter jobbie! Bloody filter was nigh welded on = strap wrench & Charles Atlas shoulder got it moving 😕 Full and, at my annual, set for 12 months. *nope.... No Leaks Underneath!! rainagain, Lacquer Peel and Shirley Knott 3
tooSavvy Posted November 8, 2020 Author Posted November 8, 2020 I've had two guys, on Geoforum, tell me 10W40 oil is wrong for my car..... Someone is reading my posts!!
tooSavvy Posted November 9, 2020 Author Posted November 9, 2020 IF.... The guy collects the 4x old wheels, then the cash will have covered all my *servicing costs... *yeah, we don't pay garages Â
DoctorRetro Posted November 9, 2020 Posted November 9, 2020 Goals? https://m.facebook.com/marketplace/item/3256536867777371/ tooSavvy 1
Agila Posted November 9, 2020 Posted November 9, 2020 15 minutes ago, TheDoctor said: Goals? https://m.facebook.com/marketplace/item/3256536867777371/ I'd be all over this, if only I had some roads that I felt deserved punishment. I suppose the m62 can annoy me at times. tooSavvy 1
tooSavvy Posted November 9, 2020 Author Posted November 9, 2020 Goals?? Starts 1st time, every time! .... to that end I have just had the postie drop off my A/filter & 3 BPR6ES plugs. On the shelf (pending fitment) are Dizz cap & rotor arm... Just ordered a plug wire kit. Oil & filter done now so sorted for 6k (likely just annual refill). Croozinn around atm.... Luvvinnitt *cambelt & full tranny rinse/refill future tasks. Â Jim Bell 1
tooSavvy Posted November 10, 2020 Author Posted November 10, 2020 Mild Modding of Timing Belt Cover.... 😕 .... Yes, deffo having a piece of that action!
tooSavvy Posted November 11, 2020 Author Posted November 11, 2020 Ooof! £13.40 inc del. Supressed 7mm & moulded ends to shroud plug in head recess. Â
tooSavvy Posted November 12, 2020 Author Posted November 12, 2020 I did all the 'top engine' service.... Plugs look unused + filter is clean.... New diz cap, rotor & leads....  Everything is mintty  rainagain 1
tooSavvy Posted November 15, 2020 Author Posted November 15, 2020 When I find the jumper socket (to disable auto advance by ECU) I will 'dial in' a few extra degrees initial advance... Suzuki are a bit conservative on factory setting 5° .... being mindful of pinging!! Looks very clean in there.....
tooSavvy Posted November 16, 2020 Author Posted November 16, 2020 The 'correct' rotor arm arrived earlier. Just spent 5mins swapping it out... CarPartsInMotion who supplied the original [wrong part No] >>> from their web listing >>> won't exchange FOC return. Return postage is basically £3.50 for £4.50 refund 😕 https://live.staticflickr.com/65535/50595336357_a1f92bb87a.jpg I ordered Left one, Car has Right one... They don't accept liability for MY error as I didn't ring them, to confirm it was the correct part for my car.... Like you WOULD when it says in listing 'fits 1.0i Swift! ' .......
