'good solid truck, ran out of mot'
MOT history of this vehicle
  • Test date 1 May 2015
  • Test Result Fail
  • Odometer reading 162,251 miles
  • MOT test number 2681 9182 5484
  • Reason(s) for failure
    Brake pedal spongy (3.3.B.1b)
    Nearside Front Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
    Offside Front Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
    Nearside Rear Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
    Offside Rear Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
    Front Brake pad(s) less than 1.5 mm thick (3.5.1g)
    Front brake disc in such a condition that it is seriously weakened (3.5.1i)
    Offside Rear rear brake binding (3.7.B.1)
    Offside Front Track rod end ball joint has excessive play (2.2.B.1f)
    Battery insecure (1.9.1)
    Brake performance not tested (3.7.A.1)'
Check out this ridiculous heap of whale dump
http://www.ebay.co.uk/itm/mg-zs-180-/201730994660
You know thats nothing more than a total guess at how many power horse brakes its got
Come on. Bollz, everybody knows that a Monster Energy sticker is worth at least 20hbp
currently has a beer barrel and memrobila on the roof will add photo easily removed!
Shame the rest of the vandalism isn't. Fucking dubber spacktards.
Here's a Project Deprive ZT powered by a turbo Kettle - few issues but an MOT'd runner.  £300 BIN, which I reckon is a bargain, despite the daft spoiler.
That MG ZT looks like a cheap chinese die-cast toy
http://www.ebay.co.uk/itm/1981-MITSUBISHI-MOTORHOME-CAMPER-CAMPERVAN-CHASSIS-CAB-SPARES-OR-REPAIR-/391635465498
FFS look at the state of this hopeless turd.
a previous owner has took the back apart and started rearranging but never finished.
Oh yeah the old 'previous owner' chestnut
http://www.ebay.co.uk/itm/1981-MITSUBISHI-L300-MOTORHOME-CAMPER-CAMPERVAN-SPARES-OR-REPAIR-/391632194625
What!!!! He's got two of these shitters!!!! Imagine having to look at that every time you come out your friggin front door. Here's another:
http://www.ebay.co.uk/itm/spares-or-repair-campervan-/142185239653
/have started to do roof and rear floor /rear lights dont work /best thing to do is come and have a /   look this will need towing away or a transporter /
This needs/crushing its /fucking obvious
  • Like 7
Wonder what the reserve is on this little beauty?  Depends if the owner thinks a Freight Rover is a "classic" or not I suppose.  2-litre O-series power, so should be an easy job to fit an MG Montego Turbo engine and turn it into the ultimate DRIFT WPN.
From that Renault 4 Ad
 I'm sure as this is a Renault 4 there will be some work to be done for the MOT. Welding etc. Please bear this in mind when bidding.
Yeah,
  • Test date6 November 2015
  • Test ResultFail
  • Odometer reading111,059 miles
  • MOT test number6260 6445 0650
    rear Brakes imbalanced across an axle Axle 2 (3.7.B.5b)
    Front passenger door cannot be opened from outside the vehicle (6.2.B.1b)
    Windscreen wiper does not clear the windscreen effectively (8.2.2)
    Exhaust system not adequately supported (7.1.1)
    nearside Front constant velocity joint gaiter damaged to the extent that it no longer prevents the ingress of dirt etc (2.5.C.1a)
    nearside front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
    offside rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
    offside Track rod end ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.2.C.1c)
    offside front Tie bar/rod damaged and seriously weakened (2.4.G.1)
  • Test date3 November 2015
  • Test ResultFail
  • Odometer reading111,038 miles
  • MOT test number9045 3804 4067
    offside Rear position lamp(s) not working (1.1.A.3b)
    nearside rear Stop lamp not working (1.2.1b)
    nearside outer Front constant velocity joint gaiter damaged to the extent that it no longer prevents the ingress of dirt etc (2.5.C.1a)
    offside front Track rod end ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.2.C.1c)
    nearside front Exhaust system not adequately supported exhaust support cotton reel broken(insecure) (7.1.1)
    nearside front Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings chassis/outer sill excessively corroded and holed (6.1.B.2)
    offside front Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings chassis/outer sill excessively corroded and holed (6.1.B.2)
    nearside rear Body or chassis has an unsatisfactory modification, seriously affecting its strength within 30cm of the body mountings body/chassis by rear bumper mount under rear wheel arch (6.1.B.2)
    offside front Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings front wing / cross member excessively corroded and holed (6.1.B.2)
    offside front Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings rear of inner wing/ chassis corroded and holed (6.1.B.2)
    offside rear Suspension component mounting prescribed area is excessively corroded inner wing / suspension mount area corroded and holed (2.4.A.3)
Didn't someone on here buy that and take it back?  The house looks familiar.
Edit - I was thinking of Angrydicky's abortive purchase of this -
