The photos are almost worthy of Billy, but I bet this is a lovely thing to waft around in.
That Toyota Crown is giving me the horn ... shame I have zero money.
Wuz, they are.Really wafty.
Mine  (ex Doobie-too) just sailed straight through its test, without even checking it over.
Happy days
This is going to make someone utterly miserable and poor.
  • Advisory notice item(s)
    rear brake fluctuating, but not excessively (3.7.B.3)
    Rear coil spring corroded (2.4.C.1b)
    Front Lower Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
    Front coil spring corroded (2.4.C.1b)
    Front Brake hose slightly deteriorated (3.6.B.4d)
    Brake pipe slightly corroded (3.6.B.2c)
    Rear Brake hose slightly deteriorated (3.6.B.4d)
    Wing mirror covers missing
    O/S/ Mirror cracked but still gives good view to rear
    Drivers door lock mechanism not working but can be unlocked from inside.
    Rear brake discs corroded
    Under-trays fitted obscuring some underside components
    Front brake discs corroded
    Rear stabiliser arm bushs deteriorated
    RUN! RUN AWAY!
I've never seen one of these L200s with a 'car bra' before. It begs the question at which point you finally take them off?
I'm one of those people who take great delight in peeling the protective plastic cover off stuff at the earliest convenience, so it wouldn't last long on my watch. Just put it back on before selling to hide the stone chips and everyone's happy
http://www.trademe.co.nz/motors/used-cars/mitsubishi/auction-1083768124.htm
Jon, have you bought that Land Rover yet?
I reckon the double skinned safari roof is worth most of the purchase price ;)
Not sure if these Colt saloons were ever sold in the UK? Steps on the Tredia's toes somewhat but you see more of those than you do these (which isn't saying much; they're hardly on every street corner)
http://www.trademe.co.nz/motors/used-cars/mitsubishi/auction-1081838896.htm
No they weren't. Having the Tredia and Lancer saloon at the same time was baffling enough.
They are an odd concept. Probably best at trapping dust and grit underneath which merrily scrubs and scratches at the once shiny paint.
