So much WANT for that Acclaim. And to save the 1.3 Golf base from morons. This is torture.
(No want at all for the Lagunas, mind.)
ABS Sensors often control speedos nowadays and traction control, not sure about tyre pressure monitors though.
On the BINI, the abs sensors know if the wheels are traveling at different speeds, which they would do if they were at different pressures. Supposed to be accurate to about 5 psi, but when ours came on due to a slow puncture leak on the rim it was 8 psi different.
http://www.ebay.co.uk/itm/CLASSIC-MINI-1000-1977-/172157737801?hash=item2815669b49:g:D6gAAOSwQoFWQSLb
'If the winning bidder would like to put wide arches, a centre exhaust and a "Mini owners do it..." sticker on, I'll come round your house, remove the subframe with your sawn off knob and stick the bastard right up your council'
Is this the one which was parked on a drive on the Sealand Road for years Billy?
I haven't touched it since I found it... Passed MOT no probs... 8 months MOT
I call bullshit on your garage find claims seller!!
Q: Anything at all?
A: Yes, anything.
Q: OK, I want two lapwing chicks peeping out of a hole in the passenger side and two huge clysters filled with screenwash on the driver's side.
     On the bonnet, I would like to have an oak spider swimming in barf and on the bootlid, I want a beige cycling helmet with legs and tail.
A: Not a problem...
http://www.ebay.co.uk/itm/MORRIS-MINOR-2-DOOR-1969-2-OWNERS-FROM-NEW-V5-IN-MY-NAME-/262371316475?hash=item3d168c92fb:g:tV4AAOSwGYVXBAU3
'please don't expect to have this done in a weekend'
I wouldn't expect to have it done in a lifetime.
Forget the Iveco, this fella is even braver
http://www.ebay.co.uk/itm/2003-Renault-Scenic-RX4-Privilege-1-9-dci-Full-black-leather-FSH-4x4-/231903795137?hash=item35fe8b17c1:g:cz4AAOSwOfxXBASF
'I'm not saying I'll be happy to see this go, but I've got Van Morrison outside with his fiddle ready for the big moment'
Mega things these, used to be worth their weight in gold.
http://www.ebay.co.uk/itm/Ford-Transit-190-Hi-Cube-LWB-1998-Twin-Rear-Wheels-relisted-due-to-time-waster-/191842721443?hash=item2caab79ea3:g:3eYAAOSwxcRW-Qik
'It will probably fail the MOT this year'
Gooner ABS Roulette anyone?
Is that right? Another gr8 design feature if that's the case.
Saw this. Won't be TPMS, as that doesn't use the ABS on the gooners. Plausible that wheel spinning did it - this is a favourite trick on Saab 9-3.
I'd expect it to clear after a couple of starts+drives.
These do suffer ABS pressure sensor failures like VAG+others of the same era - all use the same crap Bosch modules. Requires the ABS valve block replacing. Not actually too big of a job and known working second hand parts can be swapped in too. I believe the VAG repair kit works too.
Looks nice and I know sod all about them, but twenty bleeding grand for a LHD one in Spain?
http://www.ebay.co.uk/itm/1982-Range-Rover-Classic-2-Door-3-5-V8-LHD-Left-Hand-Drive-In-Spain-/222076364626?hash=item33b4c86752:g:uNwAAOSwZ8ZXBCTZ
'Also Whattsapp'
NOTHINK M8, HW R U?
