I quite like the look of the RX4's - if I didn't detest driving Meganes's I'd consider one for a winter hack.
FSO ambulance = awesome
This looks like just another tired old Scimitar, right?
WRONG!!!
ENGINE IS 1.8 TURBO FROM A SIERRA, ALSO SAME FITTED TO ESCORTS AND ESCORT VANS
And look, the advantages just keep on coming
STARTS, DRIVES
CHASSIS HAS 6 SMALL PLACES THAT REQUIRE WELDING FOR TEST
BRAKES WILL NEED FRESHINING UP OR REPLACING
THIS CAR WAS STOOD IN A FIELD SINCE 2004
ok, it's not all a bed of roses, but at £250 what do you expect?
In other news.
http://www.gumtree.com/p/cars-vans-motorbikes/citroen-c5-2005-mot-tax-64000-miles-only-950-grab-abargain/111224327
the car need hydrolic suspension pump
I didn't realise these still ran hydraulic suspension.
They did, but a different system from previous models. They have conventional brakes and PAS, the PAS shares the fluid reservoir with the suspension but it has its own pump. The suspension pump is electric and there are buttons where traditional hydro Citroens had a lever. Although it sounds like a recipe for disaster it actually seems quite robust- the spheres last a decade or more too.
This one is comically overpriced though, a runner is barely worth what they are asking.
That's lovely, but I wonder what occured for the previous auction to be stopped early?
http://www.ebay.co.uk/itm/300776099513? ... _cvip=true
The seller said that they'd be ending the auction early to send the car to auction!
Presumably one other than eBay, which apparently didn't work out, hence it's return.
On 12-Sep-12 at 14:36:43 BST, seller added the following information:
PLEASE NOTE WE PLAN TO SEND THIS ITEM TO AUCTION BY THE 15/09/12, I WILL HAVE TO END THIS LISTING TO DO SO PLEASE CHECK BACK TO FIND IT AGAIN IF YOU WISH TO BID. IF YOU WOULD LIKE TO MAKE AN OFFER OR ARRANGE TO VIEW BEFORE PLEASE CONTACT ME ON 01243 585373, OR VIA E-BAY
Right, not a bed of roses - it was a field. He's quite clear about that.
that B is seriously cheap at that price as its a '67 model
you get plenty of rubber bumpered ones at that price
70-73's all hover about £1500-£2200
but most 60's B's are £3500-£5000 unless a roadster
RAF blue Aggro VP with mysterious problems. £200
Not sure of the exact problem with it now. Things to look at will include: the cooling system and radiator fan, a loose connection somewhere in the electrics, the gasket seal (needs replacing). I can explain more over the phone if it will help
http://www.ebay.co.uk/itm/Austin-Vanden ... 232294d4b1
Suitably bizarre punctuation-free advert, hopefully written by someone more into their trucks than computers :)
http://www.ebay.co.uk/itm/1984-OPEL-SEN ... 0796097866
This guy's keen on telling us this is the best Senator 2.5 left, its almost certainly got the best tidemark if nowt else.
I have not seen the others but i can say this is the best example left.
Fair enough, I have never entered an actual race but I can say i'm definitley the fastest 100m sprinter in the world. TWAT
