busmansholiday Posted January 26, 2019 Posted January 26, 2019 If you want s diesel, and as this says straight 8, what about a Gardner 8LXBT. Mind you, it might stick out a bit at the front LightBulbFun and PhilA 2
Inspector Morose Posted January 26, 2019 Posted January 26, 2019 Hmm, diesel. Six pistons. Forced induction. Of the period. Got to be one of these then.
PhilA Posted January 27, 2019 Author Posted January 27, 2019 I am waiting for the nickel test...Once it's all back together, running and tuned up I'll see if I can balance a nickel on it. Phil LightBulbFun and Roobarb 2
PhilA Posted January 27, 2019 Author Posted January 27, 2019 Turns out switched off, I can't even balance a nickel on it. Best I can do is lean it against a head bolt. Phil alf892, Squire_Dawson, Asimo and 8 others 11
hairnet Posted January 27, 2019 Posted January 27, 2019 Can't get them here, not going to import one either. Shame on you. Phil1.6 hdi or 1.5 as it is now outta connect theres prolly more transits in usa in 5 years than pontiacs built
bigstraight6 Posted January 27, 2019 Posted January 27, 2019 Is it bad that I just thought about refitting this car with a big six turbodiesel if this engine goes pop?There's enough room to...PhilAs much as I like Diesel engines, no! I’d be inclined to source a spare engine which should be straight forward enough over there with all those fantastic treasure trove junk yards that you have, you could have hours of fun taking it apart and rebuilding ready to go in the car as and when. I’ve been on the lookout for a spare engine for my Zodiac for that just in case scenario for a number of years, not so easy....
PhilA Posted January 30, 2019 Author Posted January 30, 2019 Haven't done much recently. Jacked the car up onto stands tonight, didn't get very far as it was a lesson in safe working around jacked up cars for my niece. Also physics and stuff. Took a look and the screws that hold the U shaped section on are hidden behind the damn ventilation ducting and I don't really want to pull all that out. I may end up drilling the rivets out and refitting with nuts and bolts. Phil mrbenn, LightBulbFun, somewhatfoolish and 2 others 5
Tomtation Posted January 30, 2019 Posted January 30, 2019 Really enjoyed reading through this! Eleventy million points for ingenuity and escutcheons. Also has inspired me to tinker and plan some upgrades* to my BX GT that has been languishing unloved. Also bloody gorgeous car, all curvy and shiny! PhilA and LightBulbFun 2
PhilA Posted January 31, 2019 Author Posted January 31, 2019 Undid the wheel and pulled it off on the driver's side. Big old brakes! Brake line is chafed. Going to need to address that. I think I might be able to reach up behind the ventilation pipes and undo the bolts that hold the U shaped section in. Ran out of time tonight. Phil LightBulbFun, Burnside, mrbenn and 4 others 7
PhilA Posted January 31, 2019 Author Posted January 31, 2019 A question: Based upon experience, what would be the best method of removing the old semi-dry, semi-tarry underseal from up under there? Some of it is still slightly ok, the rest is flaky and dry in sheets. The flaky stuff should come off with a scraper to leave surface rust behind. If I'm in there I might as well clean, treat and re-seal the metal. Phil koala27 and Inspector Morose 2
Rocket88 Posted January 31, 2019 Posted January 31, 2019 If it's dry, paint scraper................Once you start using trying to use any method that generated heat, the bloody stuff starts to go gooey, and then becomes a nightmare Squire_Dawson 1
Squire_Dawson Posted January 31, 2019 Posted January 31, 2019 On mine, where the underseal has still been in condition like this, I have left it be and just worked around it. If it doesn't come away easily its more trouble than its worth. Could try spraying a small area with penetrating oil/WD40 though and see if that softens it. Rocket88 1
Rocket88 Posted January 31, 2019 Posted January 31, 2019 Black bed liner makes a good protective coating.........
PhilA Posted January 31, 2019 Author Posted January 31, 2019 If it's in good condition still then it may just get coated over, but I would like to get some rust treatment up underneath to try slow the corrosion. Overall it's pretty good but there's a few places it's setting in. Unsurprising, given the age and the location (seams under the wings). Phil purplebargeken and LightBulbFun 2
Momentary Lapse Of Reason Posted January 31, 2019 Posted January 31, 2019 A question: Based upon experience, what would be the best method of removing the old semi-dry, semi-tarry underseal from up under there?Some of it is still slightly ok, the rest is flaky and dry in sheets. The flaky stuff should come off with a scraper to leave surface rust behind. If I'm in there I might as well clean, treat and re-seal the metal.PhilGet off as much of the old underseal as will come off with scrapers, solvents such as standard thinners to get the rest off, treat the rust, paint and patch in with a modern underseal and then underbody wax over the whole under wing area. HTH
Squire_Dawson Posted January 31, 2019 Posted January 31, 2019 Tbh with steel as thick as this it won't give much grief unless woefully neglected, and even then if the body was hanging off it would still be safe thanks to the separate chassis. mat_the_cat and mercrocker 2
PhilA Posted January 31, 2019 Author Posted January 31, 2019 I'm just trying to stop the rust from coming up through from underneath. It's done it in a few places. Phil tooSavvy and LightBulbFun 2
PhilA Posted February 1, 2019 Author Posted February 1, 2019 Based upon that, and previous experience with positive results, now I've cleared a bunch more space up under the hood I think I'll wheel the car outside, jack it up and pressure wash up under the arch and the rest of it that is all caked in a mixture of old grease and dirt as a starting point. The weather isn't forecast to be that great for the weekend, plus I'm on call so I'm rather limited in what I can do and where I can go this weekend. I've my eye on a nice folding crane of 2-ton flavor at Harbor Freight, which if in stock, may be purchased this weekend if the stars align. I need then to see if my old lifting chain is still hanging from the carport at the mother in law's- I have one at the house that hasn't been outside and it's still in good shape. I'm figuring lifting from the head bolts (it's a method in the service manual) should see the engine and 'box out. https://www.harborfreight.com/2-ton-capacity-foldable-shop-crane-69514.html This being the device in question- on full extension it's good for 1000 lbs (engine + box is 860 lbs), think it should be up to task. --Phil egg, LabRat and purplebargeken 3
busmansholiday Posted February 1, 2019 Posted February 1, 2019 ^^^^ Either that, or when he pops his head back under the bonnet (or whatever it's called over your side of the pond), it's going to drop on him resulting in in hour long episode of CSI.
PhilA Posted February 1, 2019 Author Posted February 1, 2019 Thankfully the hood is spring loaded and falls to a bit of a droop. I put the rod in because the springs are a bit tired. Phil
PhilA Posted February 2, 2019 Author Posted February 2, 2019 All I managed to do was clean the threads on the lug nuts. Time ran out again. Tomorrow maybe. At least the wheel is easier to put on now. Phil Edit: Found the 20% off coupon for Harbor Freight. Hopefully they have one of those cranes in stock! somewhatfoolish 1
PhilA Posted February 3, 2019 Author Posted February 3, 2019 Today started out foggy. It cleared a bit so we head to town for a bit of shopping. Got back, pushed the car out of the garage and fired up the pressure washer. Many years of crap removed. It would appear the suspension is also caster- and camber-adjustable. Cleaned the garage, swept out and vacuumed up.Pushed the car back into the garage, wiped it down a bit and put the big fan on it to dry it out. It was at this point the pressure washer quit running. I had loaned it to the mother in law because she hired a handyman and he needed to borrow it to clean the outsde of her house.Turns out the fuel tank had a lot of crap in, which had blocked the filter up solid, and the carb was clogged with fine black powdery muck. Spent 40 minutes cleaning that out, then the rest of the afternoon's light cleaning up. A bit of progress. Happy with that. Phil purplebargeken, paulplom, Squire_Dawson and 9 others 12
PhilA Posted February 3, 2019 Author Posted February 3, 2019 Oh, and on a slightly more sour note, some mouth-breathing monkey applied so much torque to one lug stud that they sheared it; I discovered the wheel is similarly ruined on one lug hole. So, replacement wheel required on top of a new stud. Ugh. I can see this as moderately common though. Reverse thread on the left side of the car, moron! GM was like that all the way to the seventies. Phil Junkman 1
Momentary Lapse Of Reason Posted February 3, 2019 Posted February 3, 2019 Shame when idiots swing on things instead of thinking! Do your wheel (lug) nuts have any obvious markings on them for thread direction? The wheel nuts on my pre-war cars have LH or RH clearly marked on the top.And the nuts are brass/bronze so the thread in the nut will fail before the stud fails.
PhilA Posted February 3, 2019 Author Posted February 3, 2019 I didn't see any. Like much of the manual in the car, the engineering practises that were considered the norm, and therefore didn't need explaining have since been lost, because you don't get to just pick from Chevrolet, Chrysler or Packard any more. The nuts are steel; 15/16" so you can put some seriously big torque on them. Phil
somewhatfoolish Posted February 3, 2019 Posted February 3, 2019 Oh, and on a slightly more sour note, some mouth-breathing monkey applied so much torque to one lug stud that they sheared it; I discovered the wheel is similarly ruined on one lug hole. So, replacement wheel required on top of a new stud. Ugh. I can see this as moderately common though. Reverse thread on the left side of the car, moron! GM was like that all the way to the seventies. PhilAny chance of building up the wheel with weld and grinding it back? Or are rims easy to get?
PhilA Posted February 3, 2019 Author Posted February 3, 2019 Rims are moderately easy to source because they were common to a lot of models, basically the bog standard GM 15" car steel wheel. The studs and nuts are harder to get because every sod breaks the LH threaded ones. It's halfway tempting to get a set of RH studs and do the left side of the car with them and keep all the lugs standard thread. Phil tooSavvy 1
PhilA Posted February 3, 2019 Author Posted February 3, 2019 I have a crane. Phil mercedade, DeeJay, egg and 8 others 11
PhilA Posted February 7, 2019 Author Posted February 7, 2019 Progress has been at a standstill recently due to puppy and kids and other household stuff, but tonight I went out (it's not all hot and muggy. Some parts of the engine bay haven't dried out since I pressure washed it, that's how saturated the air has been).I jacked the car up a little, extended the crane out to maximum to see where it sits on the top of the engine when fully pushed in. It's close to plug 6 which is almost where it needs to be. I pulled the crane out, twisted the handle of the jack and CLONK. Handle goes limp and it doesn't lower the jack. I push the handle down, slot a small screwdriver in the release UJ and lowered it down. The disc with the square cutout has fallen off! Doesn't even show any real signs of having been welded on well. Looks like they ground it back a bit heavily. Fired email off to seller via Amazon. Said the rest of it is fine, if that's covered just send a replacement lower half of the handle and I'll call it quits. Can't see why not, that's defective manufacture. Huzzah setbacks. I need a welder. Phil somewhatfoolish and DeeJay 2
