bezzabsa Posted May 17, 2018 Posted May 17, 2018 if you're a regular on yootoob, check out Hoovies garage , his latest vlog was about the RS turbo capri - fox body 2.3 turbo...looks gorgeous..goes like a scalded sloth ie slooowwwwllyyyyy LOL do check out the interior and colour scheme though https://www.youtube.com/watch?v=sKzdm8Ek_XM Joloke and danthecapriman 2
PhilA Posted May 17, 2018 Posted May 17, 2018 I'm going to go down to the other auto parts place tonight, check see if they have the fuses in for the dash for you. Phil Joloke, egg and eddyramrod 3
PhilA Posted May 18, 2018 Posted May 18, 2018 4 amp AGA fuses will be here Monday, they're coming in from a different store. Phil Joloke and eddyramrod 2
Guest Hooli Posted May 18, 2018 Posted May 18, 2018 Short in the parking circuit? I'm not sure if that'd make sense in the wiring though. Sent from my SM-G900F using Tapatalk Joloke 1
Junkman Posted May 18, 2018 Posted May 18, 2018 Only thing stumping him is why it blows wiper fuses everytime you turn off the wipers? Why would they blow on turn off doesnt make any sense? When you turn off the wiper, electrickery is still being fed to the parking circuit, otherwise it wouldn't park.Once the wiper parks, i.e. disappears underneath the bonnet, it strikes an interrupter and the electrickery is truly switched off.In this case, I suspect that it doesn't interrupt properly, but grounds it out, thus puts juice to earth and blows the fuse. Joloke 1
PhilA Posted May 18, 2018 Posted May 18, 2018 Where? This bit. It does connect the black/pink wire to ground once it closes- if it's touching the red wire section anywhere once it closes it'll pop the fuse. Or if they've hacked it then it may be connected wrong and that explains In the meantime disconnect the red wire to the motor and it shouldn't pop the fuse, it just won't self park. Phil Joloke 1
PhilA Posted May 18, 2018 Posted May 18, 2018 You know when the motor is just not connected to a power source at all should you get continuity between the Black and Red?Only when it isn't parked. In the park position no, the red and black/pink should be disconnected from each other and the black/pink should be connected to ground. Phil
PhilA Posted May 18, 2018 Posted May 18, 2018 Wont disconnecting the black do the same thing?Its a bit harder to didconnect the red at the motor end and disconnecting the red at switch end cuts all the power to the motor Only if the issue is in the wiring harness to the car, disconnecting the black/pink would show if the problem is inside the motor.With the black/pink disconnected if it blows the fuse when it reaches the park position and you switch the switch off its connecting the red feed to ground Edit: thinking about how it's wired, disconnect wiper motor at the plug going to it. Ignition on, wiper switch selected to OFF. Measure for voltage between battery - (ground, vehicle body) and the black/pink wire going to the harness. If there's voltage there then that's the problem, the wiring needs to be traced back and corrected.Might save a few fuses checking that first. Phil Joloke 1
MorrisItalSLX Posted May 19, 2018 Posted May 19, 2018 Might end up needing a new motor afterall This might be the most sensible solution at this stage, better to get a brand-spanker than to keep dicking around with a dodgy one. Then you can confidently use the big rubber JOB DONE stamp. Joloke 1
PhilA Posted May 19, 2018 Posted May 19, 2018 Red to black connected in the park position correct. Drawing that much current? Yeah. Looks like maybe the internal windings are breaking down, it's getting "lazy". Drawing massive current under load isn't good. Dim bulb tester is a good idea yes Phil Edit, wrong of me. When NOT parked the red and black should be connected. Joloke 1
Cavcraft Posted May 20, 2018 Posted May 20, 2018 so don't be tempted to use tippex. Phil I think it's spelt T-I-P-E-X correct me if I'm wrong. Lacquer Peel and dome 2
JeeExEll Posted May 22, 2018 Posted May 22, 2018 Wow !!!Fantastic, you've done it Christine and Joloke 2
danthecapriman Posted May 22, 2018 Posted May 22, 2018 Nice one Jo. Great news! Now get some plates nailed on and get it out in it! eddyramrod, Joloke and Christine 3
Guest Hooli Posted May 22, 2018 Posted May 22, 2018 Main works to get done once its back in get the dash working,plactically everything else has been done but as we speak all that works is Fuel Gauge Temp Gauge Seatbelt Warning Light Its a typical 70's Ford abysmal flexible printed cicuit design cluster with a sprung endge connector,renound for reliability (not!) Just hope it just the cable and not my speedo head or drive eaten itself............................ I run a bike for years with just a main beam & oil pressure light. Instruments are for pussies Joloke and danthecapriman 2
danthecapriman Posted May 22, 2018 Posted May 22, 2018 Main works to get done once its back in get the dash working,plactically everything else has been done but as we speak all that works isFuel GaugeTemp GaugeSeatbelt Warning LightIts a typical 70's Ford abysmal flexible printed cicuit design cluster with a sprung endge connector,renound for reliability (not!)Just hope it just the cable and not my speedo head or drive eaten itself............................I don’t mean to blow my own horn, but... Full house on mine, all working! Probably more luck than anything tbh! Joloke 1
Guest Hooli Posted May 22, 2018 Posted May 22, 2018 twat-navs show speed if you've got one, means you can use the shitey-stang while sorting those bits out. Joloke and danthecapriman 2
danthecapriman Posted May 22, 2018 Posted May 22, 2018 If you’ve got an mot now, and it’s now exempt from future ones why bother!? Your days of ‘having’ to fix anything on this car are over!Get some US style plates instead of U.K. ones and that fixes the speed camera/ANPR issue too. Joloke and They_all_do_that_sir 2
Guest Hooli Posted May 22, 2018 Posted May 22, 2018 Does that really solve the camera issue? Joloke 1
danthecapriman Posted May 22, 2018 Posted May 22, 2018 Does that really solve the camera issue?I guess so? Wrong shape, font and colours. Camera can’t read it. Joloke 1
Guest Hooli Posted May 22, 2018 Posted May 22, 2018 I guess so? Wrong shape, font and colours. Camera can’t read it.It just surprises me as OCR in scanners etc copes easily enough with different fonts & sizes. Joloke 1
danthecapriman Posted May 22, 2018 Posted May 22, 2018 It just surprises me as OCR in scanners etc copes easily enough with different fonts & sizes.I don’t honestly know. I’ve never tried it but the old bill don’t seem to like those US style replica plates on the road. I’d assumed that was why as they’re in a unique style and font that’s not used here.Although they do seem able to read other European plates so maybe. It was meant more as a dumbass comment really, same as not fixing the speedo! Joloke 1
Guest Hooli Posted May 22, 2018 Posted May 22, 2018 No worries mate, I just wondered if you'd proved it with your yank tank or 'owt. danthecapriman and Joloke 2
bezzabsa Posted May 22, 2018 Posted May 22, 2018 phone with GPS speedo .. sorted... get out there and do some 5.0 growling !!!! Joloke 1
