michael1703 Posted December 4, 2016 Posted December 4, 2016 Ask the mot tester if he'll tweak it for you, he'll probably give up and let it through forddeliveryboy, oldcars, DeeJay and 8 others 11
Guest Hooli Posted December 4, 2016 Posted December 4, 2016 Do it yourself, takes an hour or two driving about to get it how you want. When I did mine I buggered about loads to get less response for small pedal movements & then lots of grunt over half throttle. Made it ideal for offroading so I could creep over stuff carefully & still boot it up the road & chase/overtake V8s.
Dave_Q Posted December 4, 2016 Posted December 4, 2016 Just do the opposite of this: https://www.pug306.net/index.php?pageid=boschtuning Max fuel down and screw in the throttle stop for lower max revs as others have said, but it's almost certain that chompy fitted a modified LDA pin for on-boost performance. Whilst it doesn't make much boost being revved while stationary you probably need to turn the pin to make it less smoky overall. PS is the loudness fail a new one? I've got zero chance of ever getting my impreza through another test if a moderately louder than standard exhaust is a fail now.
beko1987 Posted December 4, 2016 Author Posted December 4, 2016 Great info chaps, thanks! May have a go at the weekend, will do some reading In the week about it. Lda pin, that's the one, yes I think that's been played with. I'll try and get hold of that diesel magic potion too, sod it it can't hurt! Citrojim from the French car forum invited me round for tea and lexia next year so will take him up on that, he mentioned checking that the fuel pump and equipment were in harmony or something, probably not the main issue I have, but will be nice to see him again. Will see how it goes this week to work and back, and get the exhaust ordered tomorrow morning so it all comes in the week
scaryoldcortina Posted December 4, 2016 Posted December 4, 2016 The loudness fail isn't particularly new, it's been around since the 2012 revisions. It's not widely used though, and there is an option for advising it as "louder than standard, but not excessive" which is usually the best route for performance systems.
Guest Hooli Posted December 4, 2016 Posted December 4, 2016 My tame MOT tester always tells me not to start my Bonnie when it's there for testing, that way he can't fail it on noise
beko1987 Posted December 5, 2016 Author Posted December 5, 2016 Would adjusting the LDA screw help at all? Or should I not seeing as it's modified? I did have another idea, back the throttle cable off a notch or two
Lacquer Peel Posted December 5, 2016 Posted December 5, 2016 Take it to a tester who's less of a fud.
oldcars Posted December 5, 2016 Posted December 5, 2016 LDA? Not familiar with thatLess Diesel Attitude
twosmoke300 Posted December 5, 2016 Posted December 5, 2016 Take it to a tester who's less of a fud.who will fail it on loads that the first tester missed! Richard, The Moog, scdan4 and 2 others 5
beko1987 Posted December 5, 2016 Author Posted December 5, 2016 Yea I'm not taking it elsewhere now, mainly because I get a free retest... Plus hopefully the guy will see all the work I've done and maybe be more lenient when he knows I'm not just a clueless idiot (well I am, but a clueless idiot who has a good support network on this place and the FCF!) I'll fix some advisories too and see if they come off, as he said it would be a full test he does (but for free as he used the 'free retest' to fix his handbrake fuckup), so the brake pipes are fixed and I'll workout what bulb he says is not orange enough and change it. No idea what the oil leak is about, will ask him about that and another advisory is for a wheel bearing (although would that have happened because the suspension wasn't in high? How do I diagnose a dodgy wheel bearing as he would have done?) So a new exhaust and stop it chucking smoke out will hopefully be enough, and I don't mind what I do to stop it chucking smoke out! May look elsewhere for next year though. The Meriva flew through with one advisory though, but it's a more common petrol car. Maybe I need a diesel friendly place? Any Aylesbury shiters know of anywhere?
The Moog Posted December 5, 2016 Posted December 5, 2016 Honestly I struggled to get the car through last time with a friendly garage. The straight through exhaust and boost turned up is the challenge, its not really a marginal issue. I turned the fuel right down and then the idle up but still squeaked through. The boost shouldnt be a problem as it isnt under load so much when it is tested, i think so I wouldnt play with that. As Vulg said the fact it has no rust is pretty good, so overall for a 20 year old car it is not a bad fail. I work on about £200 a year to get a car through, which I reckon this should be. beko1987 1
beko1987 Posted December 5, 2016 Author Posted December 5, 2016 It has rust, but not structural. When he came in and said "it's not good" I was fearing rampant rot, subframe hanging on by 1 bolt etc, was almost relieved when he said what it actually was! Hopefully a new exhaust will help alot of things, then turn the fuel down, pull up around the corner from the mot station and rev the fuck out of it and see what happens! I can't do much else. If it passes though, thats a £120 mot, which won't be so bad, especially since I wanted a new exhaust anyway The Moog 1
bub2006 Posted December 5, 2016 Posted December 5, 2016 From grin thread, don't know why I posted it there. I do know he said something about the internals of pump having a land rover pin. I know he also turned fuelling up and did something inside. Turned diaphragm down maybe?? I believe he also did something to the waste gate rod of turbo.
beko1987 Posted December 5, 2016 Author Posted December 5, 2016 And that's all why I don't want to go playing with it, it all works very well! Just the damn smoke. Hopefully knocking the fuel down a bit will help, would removing the (quite dirty) air filter achieve anything?
Lacquer Peel Posted December 5, 2016 Posted December 5, 2016 Yes, removing the air filter is a good trick for getting smokey diesels through emissions tests.
Dick Cheeseburger Posted December 5, 2016 Posted December 5, 2016 Couldn't you find out exactly what fuckery has taken place within the derv pump by asking VLG for CS contact details, since it were he who improved* it?
bub2006 Posted December 5, 2016 Posted December 5, 2016 I didn't think the exhaust was honestly that bad. You met me in Newquay Terry, did it seem loud? I'm sure I've heard much worse
beko1987 Posted December 5, 2016 Author Posted December 5, 2016 Couldn't you find out exactly what fuckery has taken place within the derv pump by asking VLG for CS contact details, since it were he who improved* it?I could, but I lack the skills and money to buy standard parts to fix it within a week, so need to make the best of what I've got. A damn good thrashing on the way home yielded little smoke, which is promising. Bloody hard to thrash it though when it gets to 70 in 3rd and then I'm up behind someone/in a 30 stephen01 and Dick Cheeseburger 2
Dick Cheeseburger Posted December 5, 2016 Posted December 5, 2016 I didn't think the exhaust was honestly that bad. You met me in Newquay Terry, did it seem loud? I'm sure I've heard much worseIt wasn't deafening, but definitely noticeably louder than a standard setup. The turbo spooling whistle was much more noticeable too
beko1987 Posted December 5, 2016 Author Posted December 5, 2016 It's louder now than when I saw it at shitefest and when I bought it, the welds are failing. When it puffs out smoke at startup a puff of it came from underneath!
SiC Posted December 5, 2016 Posted December 5, 2016 Temporarily attach a DPF filter into the exhaust system? oldcars and beko1987 2
DodgeRover Posted December 5, 2016 Posted December 5, 2016 Just bung some forte in it to bring the emisions down it's only a tenner and it does work or chuck in a couple of gallons of lamp parafin ((not for road use obviously) not kerosine) beko1987 1
vulgalour Posted December 5, 2016 Posted December 5, 2016 I'm sorry, but you're all wrong. All he needs to do is put VW badges on it. Job jobbed. stephen01, Eddie Honda, oldcars and 4 others 7
Guest Hooli Posted December 5, 2016 Posted December 5, 2016 From grin thread, don't know why I posted it there.I do know he said something about the internals of pump having a land rover pin. I know he also turned fuelling up and did something inside. Turned diaphragm down maybe?? I believe he also did something to the waste gate rod of turbo. Like I said earlier, remove the cap & turn the diaphragm anti-clockwise a bit. Because of the shape of the pin that'll stop it adding as much fuel as the boost increases & reduce the smoke. That should do it, as I doubt it's getting to full boost with no load so the max fuel screw on the back of the pump won't be doing much.
MikeKnight Posted December 5, 2016 Posted December 5, 2016 I helped Chompy take the protective metal shell off the fuel pump to allow for tweaking, which required judicial use of a hammer and cold chisels. So I apologise in advance. The Moog, beko1987 and SiC 3
Richard Posted December 6, 2016 Posted December 6, 2016 What are the limits nowadays, Google has failed to provide the answer.
twosmoke300 Posted December 6, 2016 Posted December 6, 2016 3.5 turbo 2.5 naturally ashmatic Dave_Q and beko1987 2
beko1987 Posted December 6, 2016 Author Posted December 6, 2016 Ah mine failed that bit quite badly then! I'll get the exhaust fitted, move the throttle cable 2 notches and see what it chucks out when revved with no load and go from there then. It wasn't smokey once warm this morning, and I caned it up to 80/over 4.5k in 3rd onto the M40 up the hill before stokenchurch, had to turn the rad fans on to bring the temperature down a bit so it was working hard.
