Retroshite
How do you weld up the sill with all the wiring behind it? Do you need to remove the interior and move the wiring and then put it all back?
We need to weld lifting pads to the deck head inside the reactor which enable components to be lifted out..
Also there is an insert cut into the side of the submarine to allow access into the reactor, we will have to weld it back on at some point to ensure the sub will float.
Sent from my F5321 using Tapatalk
Makes sense cheers.
Why do they need to float when being dismantled though? That makes me think they're cutting it into 2ft squares, lobbing it in a transit & weighing it in.
Looking forward to seeing this soon, well bought and by the sounds of it better than the red one
Makes sense cheers.
This the old knackered Polaris submarines that have been lying at Rosyth for decades? Cant believe theyre finally going! thought theyd just let them sit as they didnt know what to do with the waste.
It's a 20 year contract and there's quite a few submarines to dismantle.
Currently working on swiftsure, the plan is to remove the secondary nuclear waste, weld it up and put it back in the sea then at some point later bring it back to remove the primary waste then weigh the rest in at Henry's grays...
Did you  know Harry at the dockyard Foad  ....  'arry Rogers from Chatham ?
 He retired shortly after Kursk disaster ...
More SDP info can be found here https://www.gov.uk/government/collections/submarine-dismantling-project
Found this photo on the net of a similar sub down at Rosyth, this is a pretty similar setup to the current Submarine apart from it doesn't have a massive hole in the side of it.
This link is a bit more informative http://www.scotsman.com/news/politics/when-will-rosyth-s-nuclear-submarines-finally-be-scrapped-1-4369308
Very carefully. Thankfully the carpets just lift up but I might need to remove the drivers seat to get better access. The wiring you can see is the tubing for the central locking system so hopefully I can pull it to the side when welding.
Welding started, it's not pretty but will hopefully get it through an mot and into use. 3062889eec1ef0e956025c2b8442fcc4.jpg90c8ba55dfe9613e857c7a456661e2ef.jpga9738209521947cfa1ad80c543c773df.jpg20b07297d750fcb97796630c6e6ef5fb.jpg
It drives really well, I didn't see the red one, but for £350 this one was bargain of the century.
A bit more grinding, some primer, Filler and paint and it will be done. 515ec4d61f84dbf90296169fe548b272.jpg
Just about finished...
37089209875_fdaa298bcd_c.jpgDSC_0034 by srblythe, on Flickr
37089209165_42c046dbb4_c.jpgDSC_0036 by srblythe, on Flickr
36900742596_228d1071c7_c.jpgDSC_0037 by srblythe, on Flickr
36900741386_5961e832a4_c.jpgDSC_0038 by srblythe, on Flickr
36900740036_67813fa02b_c.jpgDSC_0041 by srblythe, on Flickr
Spent a bit of time chasing and filling holes so there's still quite a bit of weld to grind off, I had to rebuild some of the inner arch but thankfully the majority is done. I've run out of 1.2mm wire so have been trying to get to grips with the 0.8 stuff, I'm not sure which one I prefer to be honest.
36900739496_3e9222dcd1_c.jpgDSC_0045 by srblythe, on Flickr
Tomorrow I'll tackle the front jacking point and get it in for an mot asap.
Nice work. I'm interested to know why you normally choose 1.2mm wire to weld panels. I weld everything from 0.8mm sheet up to 3mm plate with 0.6mm wire without a problem but as I'm self taught with a MIG I'm wondering is there a technical reason that the bigger wire could be better?
I just use whatever I can acquire for free.
How they stamp a broad arrow on a 1.2 mm wire ?? Did you know Harry , foad ?
Harry? There's a Harry that's in the middle of retiring in my department but other than that I don't know any other Harry's in the dockyard.
He left-  took early retirement  after Kursk went down 2000 ..was troubled by it ..having been doing subs all his life. He would have been a collar ,in the office up there , started as apprentice at Chatham on Polaris subs ,worked his way to the  top. When Chatham dockyard closed he had to move with his family (and the subs) to Rosyth. Nicest and funniest bloke i ever knew..
Dead now, but i think of him nearly every day , my older cousin.
:shock:  :shock:   You youngster !
In 1963, Our  'arry shared a dressing room with Paul McCartney,at the  Invicta Ballrooms Chatham..best band competition.. Amazingly a band called  The Beatles won..
  No one ever  remembers who came in second place   :-(   ...but he could play a mean lead guitar !!   :-D
Made it to the Mot but the brakes have stopped working...
Got a very small list to work through and it will have an mot. 7f54465ac3b1b023431655ff2c905705.jpg
Badass
37103910525_861171bb53_c.jpgDSC_0127 by srblythe, on Flickr
Ball joint ordered for tomorrow but think I might need new calipers as well as the new brake lines up front. I'll be replacing the front wings at some point too.
Driving to and from the mot with no brakes wasn't much fun, I used the handbrake to slow down and drove at 20 everywhere. I'm hoping to get it sorted and in for the free retest shortly.
This thing is looking TEH DOGZ BOLUCKS
I really must get myself a W123, but maybe a slightly less rusty one...
In most cases I would agree with DO NOT PAINT, but in this case, I think it needs painted so it can display the level of class it really is.
V5 for the W123 landed
37086219391_37eabc45ce_c.jpgDSC_0353 by srblythe, on Flickr
I'm guessing that's possibly another reason it was so cheap, the garage would have picked it up for salvage.
