1980 Austin Princess - Headlights Arms Race
First week of new job completed (it's a part time role) and it's been surprisingly okay.  The hospital is an absolute nightmare to navigate because it's about five million years old with a thousand buildings randomly bolted on, but I find myself navigating by hastily repaired bits of floors and walls since the NHS never has enough money to make anything look nice.  I've really only been doing training this week, with a little bit of actual work, it takes a while to get through all the security guff and get set up on the various systems.  It is at least familiar work, some of what I've done is exactly what I've done in previous roles just with a slightly less clunky computer system these days.  I can't say whether or not the work is difficult yet as I've not done enough of it, we'll see how I fare a few months down the line.
I've been commuting in the Princess, which surprisingly I can get insured to do for a few extra groats a year.  My commute is only about 4 or 5 miles, an annoying distance that's not quite short enough to walk, and just too far to be sensible on public transport (only one bus every hour for the route, not ideal) so it's not particularly arduous, and schools are off at the moment so it's also not as busy as it might be in the morning.  It's not really any more mileage than I'd normally do, if anything it's a little less, so the Princess has been no bother so far.  You just get in, start it, and off you go.  I did get a NOS fuel cap for it because I've started getting a bit of fuel leaking past the old one even when it isn't brimmed, the new one has a much more pliable seal so hopefully that'll deal with that problem.
The only challenge I've so far faced is rejigging my usual schedule.  I've been self employed working from home for such a long time I've had my routines well established, now I have to shuffle things like gym times and shopping times to accomodate the new job.  I'm not falling behind on anything yet so again, this is something to check a few months down the line.
The nice thing is if this does all work out as I hope it does, I will be able to be financially independant, have some financial security and still be able to pursue my artwork career alongside the NHS job.  For me, having two very different jobs is actually preferable, and only having to travel for work three times a week is a more manageable level of stress etc. than doing so full time.  I'm hopeful this is the start of a good chapter of my life.
Hope the new job goes well, I keep an eye out for the princess whenever I pop into town!
  • Agree 2
4-5 miles,I would definitely be bicycling that and keep the princess for when it's hammering it down
I'd like to, just got to get the funds together for it. (it's only 4 months since moving in to this place and it wiped me out financially).  Other thing I need to find out is where I'd put a pushbike at the hospital, so far I've not seen a single person cycling in.
Found a few minor problems today that need addressing.
- Squeaky front brake.  This is intermittent, and when mine is doing it I hear other newer cars doing it too so I'm not worrying about it too much.  Front driver's side disc brake is the culprit here, nothing is getting hot, even the caliper is cold enough to touch after a drive, it just seems to pick the most embarrassing moments to make horrendous squeaking noises.  Interestingly, if you turn the wheel even slightly left or right, the squeak immediately stops.  It's a rotational noise, it doesn't correlate with bumps in the road, and it changes with speed.  There is a chance it could be CV related except for the fact it's not clicky and it's intermittent, and if it were CV I'd expect turning one way would make it quieter and the other wouldn't, so it's probably not that.
- Coolant Overflow - I have an additional coolant overflow pipe on my radiator top hose because of the way it's put together, it isn't necessary since I have an overflow bottle.  However, lately I've noticed it's letting a bit of coolant out when it shouldn't, not because the car is overheating, just because of where the overflow is located means the coolant is getting pushed out on its way around the system.  I need to blank this off with something, might just weld up the outlet since it's mild steel.  Related to this, at some point I need to revert the thermostat and top hose arrangement to factory now I have the parts, which is likely a garage job rather than a me job since I need a glued-in-pipe removing.  These problems all started because the original cast waxstat housing disintegrated.
- Knocking - something, somewhere, is occasionally knocking on deceleration.  I can feel it through the accelerator pedal but I can't hear it, and haven't been able to detect play in the balljoints or similar at home.  It could be a track rod end again on the way out and since I have to replace the steering rack boots anyway, it might just be time to do the TREs while I'm in there.
Squeaky front brake isn't a dragging caliper, it's a very slightly warped disc.  Solid discs on the Princess and they are prone to warping for some reason.  It'll probably self clearance and probably already is which is why the problem is intermittent.  I haven't done any particularly hard braking so I'm not sure why the disc has warped but it's not the first time it has on this corner so I guess it's just a thing it does.  Can't detect any play in the bearings or TREs either so maybe they're okay too.
Upper engine tie bar rubbers, if felt both on and off the gas?
No tie bars on this one, just four rubber donut engine mounts.  No clonk on acceleration, and no clonk on deceleration that I can replicate, it's anotherintermittent one.  It might be a tired engine mount, that said, or maybe one of the bolts has back out a tiny bit and needs retorquing?  Something for me to check.
17 minutes ago, High Jetter said:
If you feel it, shirley mounts
Is she around on Saturday night?
Always 😁
I tried to get that intermittent clonk to happen and now it resolutely refuses to do it, typically.  Brake disc is also self-clearancing so I'm not worrying about that either since there's not much I can do about it.  Might end up buying another pair of new brake discs, they're not too bad to replace if I remember rightly, just expensive for what they are.
Got the sill fully welded yesterday, so that's a job that's almost done.  Need some time and energy so I can get it painted, cavity-waxed, undersealed, etc.  It's in paint so it's fine for now.
Also found a small section of failed weld under the back seat on the passenger side and a tiny little crack.  Very well hidden since you can't see it without either removing the back seat base or getting fully under the car.
That highlighted another small repair I was unaware of to the rear axle mount on the same side which I need to get a finger sander to do since the smallest tool I have for cleaning back to good metal is too big to get in the narrow gap. I can get in with the welder, just not anything that will sand or cut metal that I currently own.  I've been wanting an excuse to get a finger sander anyway, so this is as good a one as any.
After that, as far as I'm aware, the only welding remaining is cosmetic stuff and I believe I have every panel I need to do it all.
I also addressed the overflow issue, couldn't weld it because it's actually brass for that piece not steel, so I've wired a bolt and sealant in place until I can get a proper plug for it.  Later I'll find someone able to revert the current top hose set up to the factory waxstat set up, for now it'll have to do as is.
Today is all about doing as little as possible.  It's been a heavy week for me with all the reorganising of work schedules, deadlines, landlord visit, welding the car... I need a day to myself.
Do these have an upper engine tie-bar? If so, the 'clonk' could be movement in the bushes.
Nope, just four rubber donut mounts, no tie bars.
rubber doughnuts arent as nice as the sugar ring kind from m+s.... and warp factor approved brakes, thats one fast princess!
good to hear your getting settled there fella, wonder if you could get one of them ebike people to send you a bike to review (and keep) on the old youtubes? know that a certain french and australian ford youtuber managed it, although his channel may be slightly larger than yours... i do think he should send some traffic your way! come on ian, shout out the amazing princess and other crafts and hobbies channel out there! @dollywobbler
I just got off the phone to someone who has a pushbike for sale and some welding that needs doing, we may be figuring out a game plan.
I might have also figured out that knocking noise.  The brakes have been clearing up of their own accord but I did notice that the knock happens only on coasting deceleration and usually when the brakes are dragging a tiny bit so perhaps what I'm feeling is just the disc knocking on the pads and that's why I can't find any play anywhere.  Engine mounts seem healthy and tight so I don't think those are the culprit either in this instance.  Car doesn't have droplinks or stay bars or anything like that and the front end suspension is double wishbone, what bushes I can see all look fine.  No anti-roll bars either.
partial dissasemble maybe check the torque of the caliper bolts? and caliper carrier?
Pretty sure the mystery knock is the front driver's side caliper now.  The brake has started to clear up of its own accord and on coasting deceleration I could hear the brake and feel the knock at the same time when they did appear, and that does make quite a lot of sense as to why I couldn't find any play in anything.  A dismantle and re-grease of the caliper would probably be a good idea when I have time.
The new fuel filler cap I bought recently also seems to have cured a very long term issue.  The car always barfed fuel out when it was a hot day and the tank was full.  Recently I brimmed the tank and it's been hot enough for the barfing to occur and I'm pleased to report a lack of barfage.  I've also seen no evidence of leaking in general use which the old cap had started to do recently.
Generally the car is running a lot better, starts easier in the morning, and is generally just easier to live with.  I've been taking longer routes home when possible on slightly faster roads and that certainly seems to have helped.  The run to the Humber Bridge meet definitely did the car a lot of good so I suspect a lot of the very short journeys I'd been doing had been causing a bit of built up in the passages that have now been blown out.  Car doesn't seem particularly stinky either so I'm hoping when I tuned the carb I got it about right.  It certainly drives a lot better than it has in a while.  That one noisy valve is quietening down of its own accord too, which I'm told is a thing that happens when you do the clearances, so I'm leaving that alone to see if it gets quieter still and prevents me having to pull the head apart yet again to try and find the perfect sized shim since I'm yet to find anyone willing to do the job for me.
On the welding front, I've got a horrible bit of upside down bad access work to do at the back which I need a finger sander for, bit skint at the minute so that's going to have to wait a little longer.  I might do some of the cosmetic welding in the meantime instead, just to get it done and get the space back that the new panels are currently taking up.
I am making progress on the car this year, pretty good progress too on a lot of jobs that have been deferred for a long time.  I'm avoiding getting any more projects if I can at all help it.  A second car might happen to assist with the house move but it won't be a project, it'll be something I can just use to move house with and figure out what to do with afterwards.  I don't really need two cars aside from the convenience of having a working car while I'm fixing the broken car.  And of course we all know how bad I am at getting a second car that isn't a project and then ending up with three cars to look after because I bought another car to deal with the two broken ones...
Back from the local garage, recommended by a friend, and pleased to say they treated the Princess like any other car, which is good.  The ball joint boots are now done and while I wouldn't normally need to provide the kit, I had bought them intending to do it myself and just couldn't get things apart, so they were happy enough to fit what I provided.
I also got them to look at the squeaky brake since it had decided to play up again today so I stood the best chance of them finding out what that is.  Mechanically, it's all functioning properly.  Discs and pads are healthy, pistons retract properly, but they did mention the squeaky side is a bit stiffer than the non-squeaky side and advised to keep an eye on it.  There's nothing apparently wrong to fix so nothing could be fixed.  It at least gave me peace of mind that there's nothing about to go dangerously wrong there.  The only thing I  can think is that maybe a front hose is less than perfect internally, or it's time to do another brake fluid bleed and refresh.  I don't know.  There's nothing apparent to fix so I just have to ignore it for now I guess until something goes wrong, just old car stuff.
The other nice thing about the garage is they didn't point out anything dangerously amiss on the car and they didn't make any noises like they didn't want me to go back with it, so I might have actually found a pretty decent garage to use.  Their hourly rate is £50, which seems sensible, and the work done - 2 lower ball joint boots, grease, and front brake dismantling and inspection - was £90 which also doesn't seem totally unreasonable for a job I literally could not do myself.
If ever you need anything done of a more “ involved” nature, I know of a cracking garage in Brigg
Which do you use? There's a few I used in Brigg
10 hours ago, Rocket88 said:
Engineering place called Drury and Boston
On island carr opposite Maptech, they took over the unit that used to be my gym, ive heard good things
Did they inspect the pads in caliper off fashion on that knocking wheel? If that one side is knocking, but nothing seems amiss, maybe the pad delaminated from the backing? I’ve had this happen on 159, and “well there is something really wrong” moment didn’t occur until it fully delaminated and felt like failed tripod joint after it started sticking the caliper.
I assume they had them off so they could check the pistons were retracting properly, I'm not sure you can test that with the calipers on.  Hopefully they would have then seen any delamination occuring.  I will say after I got the car back from the garage the brake behaved a lot more normally and the squeakiness when it appeared wasn't as severe and quickly went away again so I wonder if it just needs a bit of exercise?  I've got a nice run coming up next week, should be a pleasant evening's drive, that'll help I'm sure or give something an opportunity to go very wrong on an unlit Lincolnshire A road in the middle of nowhere.
It could be a partially collapsed brake hose,I've had that on a reliant kitten where one front brake literally wouldn't retract,took ages to locate the fault,the hose had collapsed inside and so pressure would open it up and put the brakes on,but it would close up after so fluid couldn't return. Does sound like they are just right from lack of use previously though.
I've noticed since the garage visit that the squeak is much reduced and when it does appear, it's a lot less loud than it was.  Seems to be working itself out and the brakes themselves don't feel like they're dragging or pulling my sideways when I use them.  I'm also not getting that knock that I was now, that seems to have gone.  I'm also not getting any weirdness with the pedal, it returns normally, and doesn't behave strangely like sinking abnormally or going really hard.  Brakes aren't getting hot either, or at least, they're not getting unusually hot.  It's just an embarrassing occasional noise now that I'm having to put up with for a bit.
If any of that changes, I'll of course look at replacing the hoses although they weren't done that long ago from memory.
I do apologise for the very text heavy updates lately, taking photos and video and stuff is more than I have energy for lately.
Things have been going well until a couple of days ago when my work pc shat itself without warning.  Looks like the motherboard or graphics board have failed.  Fortunately my hard disks are okay.  Unfortunately I'm now in the process of setting up a new work station so I can get things going again and have lost half my income until that's done.  Luckily I'd just finished paying for a second hand laptop that I got as a back up machine and while it's not perfect, it will hopefully allow me to do the basics until I can afford a new PC (about £2k).  Repairing my old PC isn't really an option, it's upgraded as far as it can go, is 8 years old, and not really up to what I need it to do and hasn't been for a couple of years now.  The house move ate up my PC replacement fund which is why I hadn't replaced it.
In better news, I've been working on building my new social circle and found myself heading over to Market Rasen yesterday, somewhere I've not been in a very long time.  Pretty nice run out except for my satnav chucking me down a road that seemed to be sliding off into the neighbouring fields and ended in a broken bridge, so that was an adventure.  Some of the roads are a very unpleasant type too, with undulations and adverse camber that tries to throw you into the ditch or oncoming traffic so even when I wanted to I couldn't do the speed limit safely because I was spending all my effort just keeping the car in a straight line.  Manual steering can be a bit of a chore at times like this.
On faster roads I found myself unwilling to go over 60mph even when I could, mostly because I just didn't know the roads that well.  The car is capable, I just wanted to respect my limits as a driver on roads I didn't know.  The drive home was done at gone midnight and that's when I was reminded how dark Lincolnshire is.
Most of the drive home was done on pitch black roads with nasty bends, that alarming road surface previously mentioned, and me being quite tired.  I was incredibly grateful for the LED headlights recently installed, they made the drive home much safer and allowed me to keep the speed up to a respectable level where on the old halogens I would have been crawling along at 30mph or so I'm sure.  They light up road signs and sharp bend signs well in advance so my forward planning was hugely improved and made the drive much more relaxing than it might have been.  I think I've got the alignment somewhat sorted too, nobody flashed me or drove evasively.
In recent years I've not had need to go on roads that are over 40mph and it shows in my driving now.  I've lost a fair bit of confidence and while the car is perfectly capable I definitely need to do more faster driving to build that confidence back up again.  I've never enjoyed motorway driving so I'm glad there isn't really any of that to do in Lincolnshire, it's almost all A and B roads, but it does mean it takes longer to get anywhere.
The run out does seem to have made that intermittent squeak go away so hopefully the brakes just needed the exercise.  There is also an occasional clonk unrelated to the brakes but that could just have been the road surfaces to be honest, some of the compressions I hit were pretty nasty even at lower speeds and I know I scraped the exhaust once on a particularly nasty section of road, even though the car isn't that low.
Finally, since adjusting the carb my urban fuel economy is back up to about 26mpg now which I'm happy about.  Didn't seem to use much on the run out yesterday, so hopefully that's back up in the mid to high thirties again.  New windscreen should be arriving soon too, providing there are no delays, and I'm looking forward to that and getting the roof painted.
Ref roads…. It may be flat up here, but some roads are really bad for badly repaired subsidence. Cambers can be hazardous as well
