Daviemck2006 Posted September 22, 2020 Author Posted September 22, 2020 A cording to the service book it had a belt at about 80k then another at 160k. Its now over 240k. The car is mint inside and good outside. It's obvious the left front wing has been replaced, it does not quite fit correctly but it is a pattern part. The front right seems solid, just very slight bubbling and a slight dent. If it was a grotty filthy thing in the past it certainly is not now! You would have no idea looking at the inside, and driving it that it was, even at the first belt change at 80k. The only fault I can find is the headlights are crap, the lenses faded. But 3000 grit then 6000 grit trapezoid discs then tcut should improve that.Sent from my SM-T585 using Tapatalk Tadhg Tiogar and Shirley Knott 2
Daviemck2006 Posted September 26, 2020 Author Posted September 26, 2020 It now has new timing belt, waterpump, tensioner, coolant and auxiliary belt. It's not home yet, when it comes home it will get oil and filters. Dan says the front brakes are ok for now or else he would have changed them, but it needs a track rod end and a wheelbearing. It shall get these items in the near future.Sent from my SM-T585 using Tapatalk Lacquer Peel, paulplom and GrumpiusMaximus 3
Daviemck2006 Posted September 28, 2020 Author Posted September 28, 2020 The car is home and oil, oil filter changed today and the wheelbearing and track rod ends investigated. I had it jacked up and both front wheels off. The wheelbearing is fine, the problem was the hub nut was slack. The drivers side TRE is knackered, and the rubber on the other side is split. So two new TREs ordered, will be put on and then the alignment done. The car is running amazingly well for 240640 miles covered. There doesn't look to be any rust underneath it for a 15 year old car either. Presumably because it has lived most of its life in the middle of England, not where it is now, about 500 metres from the North sea! It has another tyre fitted today too, I found a part worn fulda winter tyre the same as the other one on the front so that went on. I'm not usually happy with only two winters on the front and summers on the back, butmoney had to count, and I'm nearly at £200 of parts now so another £100 for two tyres just now was out of the question. This is supposed to be a cheap runner to save the Leon from the rigours of pizza life!Sent from my SM-T585 using Tapatalk Shirley Knott, Lacquer Peel and GrumpiusMaximus 3
Daviemck2006 Posted October 11, 2020 Author Posted October 11, 2020 The bora has just cost me an extra, and unexpected £3.89! I will be happy if that's the only extra money it costs. What cost £3.89 I hear you ask? Let's see how long it takes for someone to guess the correct answerSent from my SM-T585 using Tapatalk
Agila Posted October 11, 2020 Posted October 11, 2020 This? https://www.ebay.co.uk/itm/223746496094 VW BORA GOLF MK4 ELECTRIC WINDOW REGULATOR REPAIR KIT CLIPS FRONT RIGHT DRIVER
Daviemck2006 Posted October 11, 2020 Author Posted October 11, 2020 This? https://www.ebay.co.uk/itm/223746496094 VW BORA GOLF MK4 ELECTRIC WINDOW REGULATOR REPAIR KIT CLIPS FRONT RIGHT DRIVERNopeSent from my SM-T585 using Tapatalk
Agila Posted October 11, 2020 Posted October 11, 2020 Key fob related or mirror glass. Otherwise I'm out.
Daviemck2006 Posted October 11, 2020 Author Posted October 11, 2020 Key fob related or mirror glass. Otherwise I'm out.Mirror glass is the answer. Hardly the cars fault, parked on the high street outside my work whilst collecting deliveries. I'm quite surprised the culprit did not get the bosses landrover discovery as well as I was behind it!Sent from my SM-T585 using Tapatalk
Daviemck2006 Posted October 17, 2020 Author Posted October 17, 2020 The headlights of the bora are absolutely crap. I'm going to have a go at improving them. I'm intending using the da sander, first with 800 grit discs, then 1600, then 3000 trapezoid and then 6000 trapezoid discs. I think that should improve matters. Then I will have to think of what I can treat them with which will slow down the rate of them deteriorating again. Does this sound like a decent plan?Sent from my SM-T585 using Tapatalk
Zelandeth Posted October 18, 2020 Posted October 18, 2020 I usually just go at them with a rag and a reasonably aggressive cutting compound. As far as stopping them from going cloudy again quickly, just a really good coat of wax should help a lot.
Madman Of The People Posted October 18, 2020 Posted October 18, 2020 Once you remove all the yellow oxidation rom the headlights, go over them with a clear enamel spray. This will prevent you from having to repeat this tedious task again.
Daviemck2006 Posted October 19, 2020 Author Posted October 19, 2020 If it's not bad enough that I have fibromyalgia, have had 4 back operations and am in constant pain, I fell down the last two stairs today and landed on my arse and am now struggling to walk or even move. That's despite swallowing double the amount of prescription painkillers I usually take. If no better tomorrow a visit to the doc or to A&E may well be on the cards. I think there will be no fiddling with cars or delivering pizzas for a week or two. And daughters car needing an MOT within 3 weeks, for which it needs two new tyres which are ordered and hoping to get in the next day or two. I can manage to take it for the tyres for her, but going to my long time MOT man, 10 miles away and standing waiting while the test is being done may be past my abilities just now. Have to see what the next few days bring.Sent from my SM-T585 using Tapatalk
Daviemck2006 Posted November 8, 2020 Author Posted November 8, 2020 Daughters car got two uniroyal rain expert5 fitted and passed mot with advisories for both front discs slightly corroded. I was expecting that, and it's more from lack of use lately and her staying between me and the sea.I'm still off work since I fell, but will be back this coming week. I haven't seen the bora since I fell, my friend with the problematic golf 1.4 has a loan of it while a local garage is trying to fix it. The car sales place she bought it from is paying the bill to get it running then she is going back to Liverpool and they are taking it back and she can pick another car. That seems to be a good result for her.Sent from my SM-T585 using Tapatalk
Daviemck2006 Posted November 12, 2020 Author Posted November 12, 2020 And the bora has broken. The door handle on the inside of the drivers door seems to have disconnected itself from the door catch. It's still opening ok from the outside. Door card needs to come off for a look then.Sent from my SM-T585 using Tapatalk
sloth Posted November 12, 2020 Posted November 12, 2020 theres a mob on ebay that do glass headlight lenses for 15 quid a pair. easier than polishing the shits.
Daviemck2006 Posted November 12, 2020 Author Posted November 12, 2020 theres a mob on ebay that do glass headlight lenses for 15 quid a pair. easier than polishing the shits.Are the lenses easily enough changed? The lights are really poor, and it's now dark here at 4pm.Sent from my SM-T585 using Tapatalk
sloth Posted November 12, 2020 Posted November 12, 2020 yeah, heat gun around the edge, and the old ones pop off. i used marine sealant to wob the newies on with. these ones are placca but same same https://www.ebay.co.uk/itm/2PCS-Replacement-Plastic-Headlight-Lenses-Cover-for-VW-Jetta-MK4-Bora-99-04-UK/383477938279?fits=Car+Make%3AVW|Model%3ABora&epid=14041286121&hash=item594910f867:g:YPsAAOSw8gBeezOE
Daviemck2006 Posted November 12, 2020 Author Posted November 12, 2020 Well on a 15 year old car it wont matter if the lenses are glass just now and replaced with plastic. And for 15 quid it will save me hassle.Sent from my SM-T585 using Tapatalk
Patent Posted November 12, 2020 Posted November 12, 2020 Be warned the lights will still be poor after you restore the lens, just slightly less poor than before. My mum has one of these and the dipped beam is woeful
Daviemck2006 Posted November 12, 2020 Author Posted November 12, 2020 And the car has had an easier life the last month, I have been off the pizza runs for 4 weeks after a big fall. I am back to it tomorrow so back to hard work for it.Sent from my SM-T585 using Tapatalk
Tadhg Tiogar Posted November 12, 2020 Posted November 12, 2020 49 minutes ago, sloth said: yeah, heat gun around the edge, and the old ones pop off. i used marine sealant to wob the newies on with. these ones are placca but same same https://www.ebay.co.uk/itm/2PCS-Replacement-Plastic-Headlight-Lenses-Cover-for-VW-Jetta-MK4-Bora-99-04-UK/383477938279?fits=Car+Make%3AVW|Model%3ABora&epid=14041286121&hash=item594910f867:g:YPsAAOSw8gBeezOE Not sure you can change the lenses without removing the headlamps first.....which means removing the front grille and bumper to get at the bottom access screws and clips.
Daviemck2006 Posted November 12, 2020 Author Posted November 12, 2020 Hmmm I may just have a go with the orbital sander first then. If I knacker them then at least I know I can just replace the lenses.I have 1200 grit discs and 3000 and 6000 trapezoid discs. But first job will be fixing the door handle. That will totally do my head in doing a delivery shift and getting out and in the car god knows how many times in 6 hoursSent from my SM-T585 using Tapatalk
Tadhg Tiogar Posted November 13, 2020 Posted November 13, 2020 I would like to replace the lenses on the diesel Borat as well, but would prefer to do it when I get round to replacing the n/s/f wing panel, which also requires removal of the front bumper....
Daviemck2006 Posted November 13, 2020 Author Posted November 13, 2020 The cable connecting the door handle to the door latch has broken so until the new one arrives I've got no door card and opening the door with a bot of wire. At least I can get out lolSent from my SM-T585 using Tapatalk
Zelandeth Posted November 14, 2020 Posted November 14, 2020 22 hours ago, Daviemck2006 said: The cable connecting the door handle to the door latch has broken so until the new one arrives I've got no door card and opening the door with a bot of wire. At least I can get out lol Sent from my SM-T585 using Tapatalk Better than one day when I assisted getting one of the coaches on my school run back to the depot when the throttle linkage failed...I wound up dangling through the floor hatch with a bit of string (actually a shoelace) tied to the fuel pump to provide throttle inputs. The intention had been to shout instructions, but with my ear about 5" away from a Bedford Y series engine I couldn't hear anything else...so ended up going by ear on engine revs and memory of where the road went - up to and including managing double-declutching. Sounds like a story from the 60s, but this was 1999 I think! TKS 666T. That bus was nothing but trouble the whole time I knew it. Eventually catastrophically overheated and completely seized one day. Leaving it stuck in the dip just before the farm at Thorneybank...If it had made it another 100 yards they'd have been able to park up out of the way...rather than completely blocking the road. Daviemck2006, Leyland Worldmaster and GrumpiusMaximus 3
Daviemck2006 Posted November 14, 2020 Author Posted November 14, 2020 Better than one day when I assisted getting one of the coaches on my school run back to the depot when the throttle linkage failed...I wound up dangling through the floor hatch with a bit of string (actually a shoelace) tied to the fuel pump to provide throttle inputs. The intention had been to shout instructions, but with my ear about 5" away from a Bedford Y series engine I couldn't hear anything else...so ended up going by ear on engine revs and memory of where the road went - up to and including managing double-declutching. Sounds like a story from the 60s, but this was 1999 I think! TKS 666T. That bus was nothing but trouble the whole time I knew it. Eventually catastrophically overheated and completely seized one day. Leaving it stuck in the dip just before the farm at Thorneybank...If it had made it another 100 yards they'd have been able to park up out of the way...rather than completely blocking the road.I once drove Hays vanhool b10m from Aberdeen to huntly with a big nut wedged under the idle screw so it was idling at 1100 revs. No throttle just had to select an appropriate gear to get an appropriate speed.Sent from my SM-T585 using Tapatalk
Daviemck2006 Posted December 5, 2020 Author Posted December 5, 2020 The bora is keeping up its 500 miles a week average. I got it today for my deliveries and found that the back brakes are scraping. There is a new set of discs and pads in the boot. I have no idea if they are front or back. It will need the back wheels removed for a look see. I wont have time tomorrow and probably the weather wont be helpful. I will use it for work tomorrow evening, then hopefully on sunday get the pads and discs off it and hope the discs and pads I have are the correct ones. If they are not then it will be Monday before I can go brake bits shopping.Sent from my SM-T585 using Tapatalk
Daviemck2006 Posted February 1, 2021 Author Posted February 1, 2021 The bora still has not got it's new brakes. It is now on SORN due to a few reasons. The rover is doing what the bora did for now. It's too cold for me doing the brakes, needs pads and discs all round, and at least one track rod end. I have all the parts. The MOT is due in 3 weeks. I also have a slight lack of money right now. The Leon's MOT cost a fair bit with the headlight replacement saga, a service and two tyres, the Hilux is in a garage just now needing a bit spent on it too for its MOT tomorrow. It's not good having all the MOTs in one month in winter! The bora is going to be a keeper, as is the hilux so I want the MOTs to be split up a bit, so the bora can wait a few months as long as the rover behaves. The leon is going to be advertised for sale once things improve, ie covid restrictions lift, and I dont think the rover will be a keeper for long, just until the bora goes back on the road. The rover, being lowered and having the sports back box, is too low and suspension too hard riding for my liking, which is a pity as I do like it. It sends some bone jarring shocks up my spine, which is not good with me having had a few back operations. The rover is covering a fair few miles now, but not adding to its mileage as the speedo ain't working.Sent from my SM-T585 using Tapatalk
GrumpiusMaximus Posted February 2, 2021 Posted February 2, 2021 Good luck with the Bora and hope you're able to get the jobs done eventually. I like them and think they're quite smart cars, really! Certainly better to look at than my Golf Estate, even though they're essentially the same!
