Small Jump Start Pack - Recommendations
*I have used the search facility, but cannot find anything*
My shared underground garage here in Spain does not have any electrical sockets anywhere. I'm leaving my motorbike here in June and not coming back until September. I will be disconnecting the battery before I go, but concerned it will still go flat, as it seems TTADTS.
I won't have a car with me then, so looking at getting one of those small jumpstart packs. Can anyone recommend one that works reliably? Will have to be small as it will have to go in my hand luggage on the flight. Thanks all.
I had a Aldi jumppack it was good and reliable but quite heavy,so probably no use as inflight luggage.
I've got one of these cheapie ones:
$_12.JPG?set_id=880000500F
Had it a couple of years now and it's a decent enough bit of kit for the price - obviously given its size its cranking abilities are fairly limited, but it will start my 1.8-litre Toyota Carina OK, so should be fine for a bike.  My only complaint thus far is that the springs in the clamps are slightly feeble so sometimes need wiggling around to get a good connection on the battery terminals.
Check with your airline if you can take it on the plane - whatever type you choose. A big battery and wires could otherwise result in problems. My advice is try to get it in some written form ie an email - not just an 'it will be alright' on the phone.
^^^ Thanks-hadn't even thought of that.
I once spent a couple of uncomfortable hours with customs at JFK with some electronic kit I had on me (it was for filming).
I have a Hilka jump pack. Bloody ace.
You could always get it delivered to your place in Spain.  They charge up in a few hours with a standard phone charger so shouldn't be an issue there.
I have the dbpower one:
DBPOWER 300A 8000mAh Portable Mini Car Jump Starter, Emergency Battery Booster Pack, Power Bank with LED Flashlight for Phone Tablet and More, 2.5L Petrol Engine Max (Black/Yellow) https://www.amazon.co.uk/dp/B079LZJ8GK/ref=cm_sw_r_cp_apa_i_zBJWCb9ZQBFHN
It's brilliant. I would now buy a bigger one because my phone has a large battery and it'd be nice to get two charges from it. Jump starts all sorts without issues.
