Make it into a convertible.
I knew the front of a Jowett Javelin reminded me of a car from a computer game. Turns out it's the Broadway from GTA San Andreas.
  • Like 11
There must be £1000's worth of stripes. Which is the buy it now price. Bargain I say!!!
quote :
MOT is due 18th October 2017 which is my reason for sale. I have another car that i use regularly and to be honest don't have the time or Money to put it through another test. Here are the advisories;
  •  Nearside Rear Upper coil spring corroded (That's not a Problem)
  • Offside Rear Upper coil spring corroded That's not a Problem
  • Nearside Rear Suspension component mounting prescribed area is corroded but not considered excessive That's PROBABLY not a Problem
  • Nearside Front Subframe mounting prescribed area is corroded but not considered excessive That's PROBABLY not a Problem
  • Offside Front Subframe mounting prescribed area is corroded but not considered excessive That's PROBABLY not a Problem
  • Nearside Rear Brake pipe slightly corroded I'd get that sorted. I like having brakes
  • Offside Track rod end ball joint has slight play I'd get that sorted. It's hardly a problme
