Nice enough onion but seriously, 1,000,000 pence is silly, well ok 999,900 pence either way is pretty mental.
Makes me wonder what my Cossie will be...
It's pretty pointless to assess the value of one's car based on one daft dinglebrain inept to put the decimal point where it belongs.
"Just" and "paint" are mutually exclusive.
Poor choice of words on my part, On the plus side, it's already primed!
Here is a perfect example of everything I hate about "Classic Cars".
FULLY RESTORED AT GREAT EXPENSE INCREDIBLY RARE MOPAR WITH 318 V8 STUNNING CAR !
So someone took a '61 Dodge Dart Pioneer, hardly a car that justifies such an investment, and restored it within an inch of its life.
Needless to say that the colour selection was Auction Red with black naughahide inside.
Terrible.
Although this combination was probably even available, it just doesn't say early Sixties America to me.
And let's take a car of the era when Detroit spent a lot of money and effort on making the arguably nicest wheel covers ever made,
bin them and replace them with those fucking dogdishes:
Besides, Mopar hadn't painted wheels body colour for quite a while in 1961.
Then go ahead and ask Nineteen Thousand Pounds for it.
Nineteen Thousand? For a '61 Pioneer?
Imagine the cars you could buy with that money.
At first I thought this is a bit too expensive to list here.
http://www.ebay.co.uk/itm/1996-BUICK-ROADMASTER-5-7-LITRE-LT1-AUTOMATIC-36-000-MILES-/132196327434
Comes with the seminuclear LT1:
Then I checked what the alternative looks like:
http://www.ebay.co.uk/itm/CLASSIC-MINI-FULL-PANEL-RESTORATION-NO-RUST-ABSOLUTLY-MINT-/322520759342
I mean, seriously?
You're right, that sweet ass Mini knocks it out of the water.
No, it doesn't. Neither is it JRG, nor does it have those instruments that are too shitty even for a Pound shop.
If I wanted to pop £2k on a camper, this would be the one.
Mercedes 814 with Tail lift and Garage Workshop...2 double berths, shower, toilet, gas cooker etc...5.9litre non turbo straight six.
https://www.gumtree.com/p/campervans-motorhomes/mercedes-814-truck-motorhome-with-tail-lift-and-garage-workshop/1219334218
Phone No on the door is local to me but unbelievably I've never seen it.
Guest Breadvan72
Four wheel drive Sherpa crew carrier, £1500, via FB.
Staffordshire.
PM me for seller's contact number.
18618162_10154697743031483_937913829_o.j
18622798_10154697742471483_1386903982_n.
18575827_10154697742251483_947874443_o.j
  • Like 6
Guest Breadvan72
Check the MOT history of a vehicle
Registration number: TDP679Y
  • Vehicle makeFREIGHT ROVER
  • Vehicle modelSHERPA
  • Date first used18 January 1983
  • Fuel typePetrol
  • ColourBlue
MOT history of this vehicle
  • Test date24 April 2017
  • Test ResultFail
  • Odometer reading46,895 miles
  • MOT test number6837 7154 3237
  • Reason(s) for failure
    Windscreen washer provides insufficient washer liquid (8.2.3)
    Offside Rear fog lamp not working (1.3.2b)
    Rear fog lamp tell tale not working (1.3.1b)
    Power steering inoperative (2.3.3a)
    Offside Rear Suspension spring mounting prescribed area is excessively corroded outer and inner sill spring eye area (2.4.A.3)
    Nearside Rear Suspension spring mounting prescribed area is excessively corroded inner sill spring eye area (2.4.A.3)
    Offside Rear Suspension spring mounting prescribed area is excessively corroded lower 1/4 panel shackle mount area (2.4.A.3)
    Nearside Rear Suspension spring mounting prescribed area is excessively corroded lower 1/4 panel shackle mount area (2.4.A.3)
    Nearside Rear Brake pipe excessively corroded (3.6.B.2c)
    Offside Rear Brake pipe excessively corroded (3.6.B.2c)
    Nearside Rear rear brake binding (3.7.B.1)
    Nearside rear brake recording little or no effort (3.7.B.5a)
    Bonnet cannot be secured in the closed position (8.4.1)
    Service brake: efficiency below requirements (3.7.B.7)
    Rear Brakes imbalanced across an axle Axle 2 (3.7.B.5b)
  • Advisory notice item(s)
    front propshaft missing
    Nearside Front Tyre worn close to the legal limit (4.1.E.1)
    Offside Front Tyre worn close to the legal limit (4.1.E.1)
    both rear tyres cracked and perished
    Nearside Headlamp deteriorated but light output not reduced (1.7.5a)
    Offside Headlamp deteriorated but light output not reduced (1.7.5a)
    Nearside Suspension component mounting prescribed area is corroded but not considered excessive inner arch /chassis rail (2.4.A.3)
    Offside Front Suspension component mounting prescribed area is corroded but not considered excessive inner arch/chassis rail (2.4.A.3)
    Nearside Front inner sill/step area has some corrosion
    Offside Front inner sill/step area has some corrosion
http://www.ebay.co.uk/itm/1970-PLYMOUTH-FURY-2-2-door-V8-pillarless-coupe-fresh-mot-free-tax/232329403319
Auction Red paint - check
Terrible black interior - check
Daft asking price - check
I checked the location to figure out whether it looked familiar.
Broxburn. Ah, the central belt.
It probably is the one I saw at the Morris Leslie auction a couple of months back, in Perthshire. Auction Red indeed!
