http://www.ebay.co.uk/itm/1995-skoda-estate-favorit-GLX-1-E-flairline-car-1300-cc-/122492345288?hash=item1c851cdbc8:g:wJcAAOSwrhBZFZtp
mot failed due to exessively harsh inspector ,horn wrong sound ,too harsh
Oh Rly?
MOT history of this vehicle
  • Test date30 August 2016
  • Test ResultFail
  • Odometer reading58,585 miles
  • MOT test number7901 3527 5807
  • Reason(s) for failure
    Nearside Front brake disc in such a condition that it is seriously weakened (3.5.1i)
    Offside Front brake disc in such a condition that it is seriously weakened (3.5.1i)
    Parking brake lever has no reserve travel (3.1.6b)
    Offside Front Steering system lock to lock check exposes a seriously damaged brake pipe (2.2.D.2b)
    Steering rack has had excessive heat applied (2.2.C.1e)
    Nearside Front Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.2)
    Offside Front Suspension arm rubber bush deteriorated resulting in excessive movement (2.4.G.2)
    Nearside Rear wheel bearing rough when rotated (2.6.1)
    Offside Rear wheel bearing rough when rotated (2.6.1)
    Nearside Front Upper Coil spring mounting damaged and seriously weakened (2.4.C.3c)
    Offside Front Upper Coil spring mounting damaged and seriously weakened (2.4.C.3c)
    Nearside Rear Wheel bolt(s) loose (4.2.A.1e)
    Rear fog lamp not working (1.3.2b)
    Nearside Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
    Offside Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
    Nearside Front Windscreen washer provides insufficient washer liquid (8.2.3)
    Offside Front Windscreen washer provides insufficient washer liquid (8.2.3)
    Horn sounds harsh or grating (1.6.2e)
    Nearside Rear Exhaust has a major leak of exhaust gases (7.1.2)
  • Advisory notice item(s)
    Non obligatory mirror damaged ()
    Items removed from drivers view prior to test ()
    Nearside Rear exhaust bracket damaged
    Centre exhaust bracket damaged
Thank God that these are the other side of the globe
performed faultlessly over 750 miles in 3 days, even sitting in traffic the temp gauge sat perfectly in the middle and never budged, also used no oil or water.
Is that meant to be some sort of achievement?
I've done more miles in the same time in an older car, several times, and it too performed faultlessly... plus I didn't need to beat it senseless with the ugly stick and beg money for charidee.
I saw a similarly-adorned X-Type in the scrap yard a few weeks back. That's where this one belongs, and the person selling it.
Aaaah, charity banger rallies. How hilarious*
Here's my ZX Volcane banger rally car. Enjoy, don't have a heart attack now.
Favorit watchlisted for the original blaupunkt radio!
