What's the story with that dealer?  All the stuff always seems impossibly cheap. And there seems to be new cheap stuff all the time. How can he make a living? Is it a scam? Who's in Kirkcaldy?
Most stuff seems to have next to no mot. The Rover looks good tho.
the mark 2 MG ZT above in kirkaldy looks ok,
but,
BUT its an 1800 kettle....
WCPGW....
shame cos the mark 2 MG ZT is a  nice looking motor.
http://www.ebay.co.uk/itm/1999-ROVER-75-CLUB-WHITE-2-0-V6-SUPERB-BODY-DRIVES-FAB-SPARES-REPAIRS-MANUAL-/272099783711?hash=item3f5a69341f:g:w4oAAOSwZG9WkSUJ
This has to be the one I went to view a few weeks back, but was on the Wirral then and the description wasn't as good as it is now.
I have paged Mr_B.
They have loads of shite that lot in Kirkcaldy. I presume they've got some bulk deal from a main dealer.
I've been tempted to get a shitter or two from that seller! Best was a Proton Persona 1.3 Coupe, £500 (if memory was correct) and at the time had 9 months or so MOT. Sadly Just as I was away to call and ask I seen it'd been sold....typical.  :?
This 'Barn Find' RX7 (FB) as a project, yous for £2,200. I would tempted...but last time I bought a classic Jap car that needed work done I regretted it.
http://www.ebay.co.uk/itm/Mazda-RX7-FB-first-gen-1983-barn-find-garage-find-/301842621885?hash=item464738e5bd:g:U5gAAOSwHaBWhUxW
The ever popular* Vauxhall Vectra. This one a 1.8 Sri estate - £165 with test tim March
http://www.ebay.co.uk/itm/Vauxhall-l-Vectra-sxi-estate-/262232013785?hash=item3d0e3efbd9:g:fAEAAOSwYIhWkO3V
SXi so not quite so "sporty" and a slippy clutch. Looks nice.
I do like these Carltons. Facelift mk1 I think that is? I recall there was an immaculate blue one on VODC which they couldn't give away. Few years ago now.
Wow this looks a lot of bang for your buck. 5.0 AMG for under 2k!
Not when you read the MOT list
Reason(s) for failure
Service brake: efficiency below requirements (3.7.B.7)
offside front Headlamp aim beam image obviously incorrect (1.8.A.1b)
Parking brake lever has no reserve travel (3.1.6b)
nearside front lower Suspension arm ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.4.G.2)
offside front lower Suspension arm ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.4.G.2)
nearside front Front wheel bearing has excessive play (2.5.A.3c)
offside front Front wheel bearing has excessive play (2.5.A.3c)
offside rear Front wheel bearing has excessive play (2.5.A.3c)
offside rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
offside rear Tyre has a tear, caused by separation or partial failure of its structure (4.1.D.1b)
nearside rear inner Drive shaft which forms part of the suspension coupling gaiter damaged to the extent that it no longer prevents the ingress of dirt etc (2.4.G.4e)
offside rear inner Drive shaft which forms part of the suspension coupling gaiter damaged to the extent that it no longer prevents the ingress of dirt etc (2.4.G.4e)
nearside rear Brake lining(s) less than 1.5 mm thick (3.5.1g)
nearside rear Additional braking device leaking oil BRAKE PIPES (3.6.I.6)
Advisory notice item(s)
nearside front Track rod end ball joint has slight play (2.2.B.1f)
offside front Track rod end ball joint has slight play (2.2.B.1f)
nearside rear outer Body has slight corrosion (6.1.B.2)
nearside rear inner Body has slight corrosion (6.1.B.2)
offside rear inner Body has slight corrosion (6.1.B.2)
centre rear Body has slight corrosion (6.1.B.2)
front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
One owner Astra Sri with a chav tastic interior. Correct me if I'm wrong but should this have trims and they are Cav Sri 130 alloys?
Hey there you with the sad face
Come round to my place
And live it up.
http://www.carandclassic.co.uk/car/C697349
(Now dropped to £1250, by the way, which probably hasn't improved the Paranoid Android expression.)
Edit:  LOL at
Asking price is set to sell, as is taking up too much room at the moment.
Yeah, I can see it's effin RAMMED in that semi-derelict concrete yard of yours.
