I thought Rover P4.
 Front RR, rear Daimler Majestic, windscreen and scuttle probably Daimler, centre body very badly home made. Probably on a RR chassis I like the doors best (L H side only).
Tempted to break that Delta HF Turbo and rob the engine for my Dedra, which appears to have suffered badly from HGF.  I mean, a hole in the roof has to be fairly terminal in one of these, no?
Isn't the Dedra a 2l 8v? The same as the early Themas. The Deltas like that were 1.6l and considerably lower on power than 2l turbos.
So they were - I never realised that.  Thank you, I owe you a pint for saving me from much embarrassment and expense.
... and you must buy that Flavia.  I will be in London fairly briefly at the end of next week and could potentially go and look at it for you, if nobody more local and competent puts their hand up.
Aye, wheels on that Favorit look very much like Mk1 Scirocco rimz.  Bet you'd make a chunky* profit on your £140 if they are.
I miss bready!!!
Where'd he go ? Piston'eds ?
Old school Ford tax 2050.
It runs perfectly but failed its MOT on the following items:
1. Offside rear shock absorber has a fluid leak.
2. Offside front (floor) subframe mounting prescribed area is excessively corroded.
3. Offside rear (sill) suspension component mounting prescribed area is excessively corroded.
4. Offside (sill) seat belt anchorage prescribed area is excessively corroded.
http://www.ebay.co.uk/itm/2000-FORD-KA-MILLENIUM-YELLOW-/161430637518?pt=Automobiles_UK&hash=item2596040bce
A cool motor though, I wouldnt spenfd £500 to buy it but I would cheerfully spend ages welding it up
Can anyone think of a more useless bit of information than 'X people are viewing this item per hour' what is anyone supposed to do with that? Is there any use for it at all? If so what?
