Asimo Posted April 8, 2019 Posted April 8, 2019 I failed a long time ago at repairing a vibrator-supplied car radio The vibrator had extra contacts for synchronously mechanically rectifying the HT. I think I remember it being a Phillips. Very large and heavy, must have cost a fortune to make. Lots of lead and lots of cadmium. LightBulbFun 1
PhilA Posted April 8, 2019 Author Posted April 8, 2019 From what I read, this is a Sylvania design manufactured by Delco. Philips just made some really weird stuff. Including all the way through into the seventies. Phil LightBulbFun 1
PhilA Posted April 9, 2019 Author Posted April 9, 2019 Most excellent. eBay just lightened my wallet again. 12V variant of the radio (Buick fitment) won. Shipping thing reckons it'll be here by the 15th. It's been a long while since I bought a "bid" item, normally I hunt for the BiN items because I abhor bid sniping software. Phil LightBulbFun, danthecapriman, Lacquer Peel and 3 others 6
PhilA Posted April 9, 2019 Author Posted April 9, 2019 That's not too bad. Just do it one component leg at a time and you will be fine.If the leads are all wrapped as well as soldered I would just snip one leg, solder the new one in, snip the second one, solder replacement in.Component count is low enough it shouldn't take too long really.What has helped is sitting down, going through the parts list, identifying each bit and getting a much better idea of where what part of the schematic is on the chassis. The next thing is this one's 7C5's for the AF stage, which are Loctal base and a different pinout to 6V6's.Why would you want to transpose pins and have it so that if you plug a 6V6 in (like it says is a valid option) that the heater is across the plate and cathode pins on the 6V6? How silly. That would be very very bright for a fraction of a second... Phil LightBulbFun 1
Frogchod Posted April 9, 2019 Posted April 9, 2019 All this talk of old radios has made me wish I'd stayed awake during electrical and electronic principles at college.Even if I did stay awake I doubt I'd remember relativly obscure stuff from 1982 I do remember sniggering at "thermionoc emissions" then I glased over, thinking I'd never need or want to know about valves.I did stay awake long enough to work out v=I x r ,but that's about it.... Btw, great thread LightBulbFun and PhilA 2
PhilA Posted April 10, 2019 Author Posted April 10, 2019 Well, more fun trying to determine what tubes I need to get; 14C5 for the power output stage. Spent a bit of tonight sitting down comparing the two circuits. The 1956 circuit has been economized a little (probably in the name of reliability- a transformer is more reliable than a vacuum tube), the tone circuitry has been minimized down to a capacitor and a variable resistor and the phase inversion circuit has been replaced with a center tap transformer. The tuner potentially looks to be identical, so hopefully if this frame is in better shape it may be able to be transplanted. We shall see! Phil somewhatfoolish, LightBulbFun and mat_the_cat 3
Snipes Posted April 10, 2019 Posted April 10, 2019 All this talk of old radios has made me wish I'd stayed awake during electrical and electronic principles at college.Even if I did stay awake I doubt I'd remember relativly obscure stuff from 1982 I do remember sniggering at "thermionoc emissions" then I glased over, thinking I'd never need or want to know about valves.I did stay awake long enough to work out v=I x r ,but that's about it.... Btw, great thread Lol 3 years later and all I can remember is 2πfl. Inductive resstance something something. Oh and 1/ 2πfc, inductive capacitance something something. PhilA and Frogchod 2
PhilA Posted April 10, 2019 Author Posted April 10, 2019 I've found the transmission overhaul manual for this particular gearbox variant. Sitting reading through it, it's quite the complicated contraption. I think best things first will be to hook the engine to the crane, wheel the assembly outside and clean the outside of it thoroughly with degreaser and a toothbrush. The manual repeats over and over and over CLEANLINESS INSIDE THIS GEARBOX IS VITAL. I understand that, but evidently a single particle of dirt can cause havoc. Fun times Phil
tooSavvy Posted April 10, 2019 Posted April 10, 2019 Don't confuse your bands with your disc pak... Rockinn, Bro PhilA 1
PhilA Posted April 10, 2019 Author Posted April 10, 2019 Tonight we are back to the oily bits, if not just for a short while. Weather's a little warm right now compared to how it was Sunday (9c Sunday, 27c today).This evening was spent making it all a little more clean. I need to get some proper engine degreaser, rather than using carpet shampoo...Phil scdan4, LightBulbFun, RayMK and 3 others 6
PhilA Posted April 11, 2019 Author Posted April 11, 2019 My radio made a rest stop in Barstow, TX. Maybe it'll be here by the weekend. I can't see it wanting to stay in Barstow, TX. Barstow, TX. From Google Street View... There's not much in Barstow, TX. It's Big Sky country. Phil somewhatfoolish, LightBulbFun, tooSavvy and 3 others 6
Zelandeth Posted April 12, 2019 Posted April 12, 2019 When looking for something totally unrelated I stumbled across a photo of the bench meter which lives on my currently buried workstation. Simply because Nixie displays make everything better. mat_the_cat, LightBulbFun, PhilA and 2 others 5
PhilA Posted April 13, 2019 Author Posted April 13, 2019 Radio overshot and checked in all the way up in Memphis, TN. Could be worse; that's FedEx's southern hub. Tonight I had a little time so restarted on stripping the engine back down again. Turns out someone actually forked out some money- the starter motor is stamped 12V. Thorough cleaning has begun. Gearbox so it's clean to take apart, engine so it's clean to paint. Phil danthecapriman, paulplom, purplebargeken and 4 others 7
PhilA Posted April 13, 2019 Author Posted April 13, 2019 So I check the tracking on the radio and FedEx have had a sudden bout of efficiency. The delivery date had changed from Monday to 2:53am YOUR PACKAGE IS ON A TRUCK FOR DELIVERY TODAY Typically today I have to go to town with the missus to go shopping for upcoming wedding. Oh well. It's due to rain. Hopefully they'll leave it tucked up in the porch out of the weather. I might leave a plastic bag for it with a note. My life, reduced to a scrubbing brush and checking FedEx. Woo. Phil purplebargeken, LightBulbFun and richardthestag 3
hairnet Posted April 13, 2019 Posted April 13, 2019 Thunderstorms in Texas Moto GP not running not cos rain but thunder and lightning Phil you reckon it's be fun skateboarding down that??
PhilA Posted April 13, 2019 Author Posted April 13, 2019 Depends on what's off to the left of the picture, out of shot. A big pile of pillows, maybe fun. Spectator parking lot not so much Phil
hairnet Posted April 13, 2019 Posted April 13, 2019 motogp happening after 3 hours unfortunately the pace car isnt a 72 cutlass its a shit modern bmw PhilA 1
PhilA Posted April 13, 2019 Author Posted April 13, 2019 Yeah, they're leaving the classics at home these days. Either that or they do a 22 1/2 mph parade lap Phil
PhilA Posted April 14, 2019 Author Posted April 14, 2019 I arrived home from shopping. There was a box waiting. Fragile fragile fragile! It states. Pop the top of the box open. It's like Christmas. Looks in pretty good shape overall. Popped the back off on the bench. All looks pretty good, but oh, what's this? One of the power output tubes has succumbed to FedEx. Shame, but I hadn't planned on using those tubes anyway. The tuner, as suspected, is the same and is in good shape. Serviceman notes on the top "Pops on and off". Bad capacitors, then. Notes show it was purchased in 1956 by a gentleman by the name of Snyder in Pomona, CA. That would explain the lack of rust then. More to follow! Phil mat_the_cat, LightBulbFun, mercedade and 3 others 6
PhilA Posted April 14, 2019 Author Posted April 14, 2019 Pulled the front off also. Similarities in the design become apparent. Simplification of the design to save on parts, also evident. Looks like it went into the radio shop for repair and never left. It's got all the original Delco Radio capacitors inside. There's a few subtle differences but overall this be good. I think the tuner coil housing will be being transferred also. Phil mat_the_cat, tooSavvy, Scruffy Bodger and 4 others 7
PhilA Posted April 14, 2019 Author Posted April 14, 2019 Thermionic glow. Powered it up gently and we do see B+ of 220 Volts so that part of its working. Without this tube though- nada. For those of you who want to see what the inside of a 12V6GT looks like. I also redact the blame of FedEx- there was a spider inside the tube, all crispy and read. That's been broken a while... Phil somewhatfoolish, tooSavvy and LightBulbFun 3
PhilA Posted April 14, 2019 Author Posted April 14, 2019 Because it didn't go pop or smoke up. It's operating in single ended class B output there with a single tube but that's not bad for being peered up for the first time in probably 40 years. Phil tooSavvy and LightBulbFun 2
PhilA Posted April 15, 2019 Author Posted April 15, 2019 Radio scrapyard begins. That's big old tin of spam there is the power transformer. Unfortunately I'm going to have to carefully undo it because there's a big paper capacitor inside that needs to be changed (that particular one is known for going up in smoke, in that position in the circuit because it never gets changed). I looked and I think the two chassis are actually interchangeable in the frame. Must resist putting in the simpler one because it's simpler to work on... Phil somewhatfoolish and LightBulbFun 2
PhilA Posted April 15, 2019 Author Posted April 15, 2019 Hmm. Two schools of thought on the design of the circuit. Perhaps the later model isn't such a bad design after all. Lower quiescent current, for sure. Now I'm torn. I may swing the new chassis in there after all. More research to follow. The power transformer had to come out regardless, for that capacitor. Phil LightBulbFun 1
PhilA Posted April 15, 2019 Author Posted April 15, 2019 Okay, doing a little reading and the choice of circuit design makes sense now. The '51 is a higher fidelity design (haha on an AM radio) with a phase splitter circuit driving the output transformer in AB1, which ultimately gives good frequency response, down to the speaker and output transformer choice being the deciding factors on how it sounds. The later version uses a phase splitter transformer. This provides very low input impedance so you can drive the tubes in class AB2 and really push a lot of volume- make it loud at the behest of distortion figures. Which, in the application of car audio doesn't really matter. So Design 1 runs a bit hotter but technically is a a cleaner circuit. Circuit 2 robs a little fidelity to provide punch. I don't need a loud radio. Phase inverter tube circuit it is. Particularly with high quality input such as Bluetooth. I need to check if the loudspeakers are the same impedance because the '56 sounds better than the '51, I think being stored in a drier environment has helped the cardboard cone to stay more supple. Phil LightBulbFun and Asimo 2
Snipes Posted April 15, 2019 Posted April 15, 2019 That whole post could be complete psuedo science nonsense and I literally would have no idea. I suspect Phil might be well be trolling us by posting nonsense and waiting to see if anyone sports it. I believe this may similar to what cool internet kids call "smurfing" I KNOW YOUR GAME MATE. Edit; LBF or SiC may know but are probably in on the joke. IT'S A CONSPIRACY I TELL YOU. LightBulbFun, PhilA, DeeJay and 2 others 5
tooSavvy Posted April 15, 2019 Posted April 15, 2019 ^^^ ah, Radio Nerd Alert. I'm slightly in awe... During WW2 young lads yomped about carrying 'field radio packs' and being very important for allowing rapid *effective deployment of assets.Fixing #hit like this, in a wood/in the rain, miles from anywhere was like Voodoo... Came home and promptly sent rockets/aircraft off to blue horizons & built electric guitars/amps. *footsoldiers have their own opinion of High Command. PhilA, somewhatfoolish and mercedade 3
LightBulbFun Posted April 15, 2019 Posted April 15, 2019 all very awesome stuff! I love a good thermionic device restoration although sadly I dont know enough to comment much useful, other then its Awesome! so I just go round liking every post (but luckily I do know enough to know whats going on, for the most part anyway!) PhilA 1
PhilA Posted April 15, 2019 Author Posted April 15, 2019 Well, I was doing a little reading and research between circuit phase inversion and transformer phase inversion. Seems there's two schools of thought going on here. Some people prefer a transformer design, claiming superiority because it has a very low input impedance and means you can run in class AB2 ("grid current") mode and make the very most of the capabilities of the power output tubes. Using a circuit to do the same is a cheaper alternative because it uses a few electronic components. It however recreates a more honest representation of the original signal with less distortion, class AB1. Blah blah blah electronics. The '56 radio is louder and uses a more reliable method of phase inversion. Phase whatnow? I am going to make the assumption most of you know how a loudspeaker recreates sounds from an electrical current. Connect a battery across a speaker and it pushes out, turn it around and it pulls down the opposite way, right? Okay good.So the principle of the audio output stage is the same. A single tube (or indeed transistor) can only push the speaker in one direction, much like connecting a battery one way can make the speaker push out and then return under the spring of its suspension to it's resting position.While this works (single-ended operation) it is far from hi-fi audio. A lot of cheap transistor radios use this design (see: cheap) because it's simple and doesn't require many electronic components.So, what's done is to take the audio signal, split it into two paths, and by some mechanism turn the signal on one path "upside down"- that is, alter it's phase by 180 degrees. That is then fed into two tubes (or transistors) and that means then that the circuit can both push AND pull on the loudspeaker, meaning that instead of the speaker cone having to bounce back under it's suspension when it's in a negative position, it's actually being put there by an electrical current (push-pull configuration). Okay, right. Uhm. Imagine a swing in a park. You stand on one side and give it a push. It swings away from you, then back again. At the point where it comes back to you is the only time you can push it and control how high it swings.Now add someone on the other side- you push to them, they push to you. Between you, there is much greater control over the swing's position. That's open-ended versus push-pull operation.The person on the other side needs to be doing exactly the opposite to you (push when you would be pulling) and the way to do that is what's being decided on here. Got it? Good. Phil shedenvy, Frogchod, paulplom and 4 others 7
