1951 Pontiac Chieftain
As a rugrat the kitchen had a cuboid radio with a big dial on the front perpetually tuned to Radio Scotland; it was powered by a PP7 or possibly PP9 which never seemed to need changing. In those days it was essentially radio 2 with a scottish accent, Jimmy Mack spinning discs and dinner was eaten to the sound of 'Take the floor' with Robbie Shepherd, or 'Eastern echoes' which to this day I associate with dinners I don't like, even though I can't remember what the dinners I didn't like were.
Google search suggests it was a Boots Supertone 7, like this only black rather than red.
You made me go look for radios.
I recall having a radio in the kitchen as a child. Grundig Party Boy (what a name).
Phil
That's not too bad. Just do it one component leg at a time and you will be fine.
If the leads are all wrapped as well as soldered I would just snip one leg, solder the new one in, snip the second one, solder replacement in.
Component count is low enough it shouldn't take too long really.
Normally I would agree. The legs aren't wound on, but there's plenty of through-hole and to-chassis connections that I am a little concerned my iron won't have enough heat in for.
That and there's a bunch of resistors that need the two components above them removing before they can be liberated.
There aren't too many though, no.
Phil
As a kid we had a radio in the kitchen as well.
When we went out in the Bedford HA van it slipped into a cage fitted under the dash and it became the car radio.
IIRC being a portable meant no Wireless Licence needed!
Phil
The Irish grandparents had a 208 version on the kitchen windowsill for as long as we went visiting so at least 35 years
Uncle Shay might still have it somewhere
I went to make a start on the radio, and discovered that my VTVM has died.
Yay for setbacks. Not that it really mattered, because at that point work called and I got stuck doing somebody else's job for 2 hours.
Phil
vacuum tube volt meter...
ill say thats a first for me
very interesting :)
Incredibly high input impedance, so you can measure delicate circuits without collapsing the voltage present.
Phil
Bad contacts found, remedied and calibration procedure completed again. We are back in business.
Phil
  • Like 15
What a fab gizzmo.... No TV repair guy would be without one [bitd]?
Even today, still cheaper to pick up than a high-end Fluke, particularly a high-impedance meter.
--Phil
found out that the radio the gparents had and think shay still has was a yacht boy
which insane people on ebay want 75 or 90 quid for :o
phil may i ask - would it be possible to have something posted from GA to philtowers please
catfish and sweet potato pie and other southern delicacies as payment (and gratitude)
thanks yall
Sure thing. So long as it's not an entire car or a pottery garden model of the statue of liberty that's fine
so if it was pre 60 youd not mind :D
thanks yall
ps RAODTRIP IS OAN!!!!!!!!!!!
thanks yall
Me no. The wife, yes.
hang on youve had shonky reno for a long time
anything else is improvement no>??? :D
Doesn't mean she likes the car. She'd rather I got rid of it.
The Chieftain is acceptable
Building up a list of components that I need to repair this radio. Thankfully I have a number of the parts on the shelf, as it were.
Phil
$53 in new parts.
Still need to grab another radio of the same vintage to thieve a power transformer from.
Phil
$53 in new parts.
This
Phil
What you needing? Just seems worth asking as it's quite possible I've got stuff in stock you'd be welcome to. Postage for small stuff over to there isn't too bad really (unlike posting this way!).
Vibrator supply transformer, 12V to whatever rectifies to 250VDC through a gas rectifier.
The rest of the components I'm just gonna shotgun and upgrade a little- new carbon comp for the RF section, metal film for the IF and AF stages.
Phil
Nixie toobs!
If the car didn't already have a clock in, I would have retrofit it with a nice Nixie tube clock. Because jet age.
Phil
Good example of how old stuff stops working properly. These two resistors are an important part of the oscillator circuit.
6.8 MegOhm - blue gray green
On the Meg scale, reading about 1.5 Meg (blue arrow, top measurement arc)
This claim is backed up by the digital meter
Moving along to its neighbor
Orange orange yellow - 330kOhm
On the 100k scale, needle around about 470k.
This radio wouldn't have worked worth toffee.
Phil
  • Like 6
Roll On.... :/
I'm planning to fit my 'plip locking kit' today :)
12v live wire
Ground wire
Control Open
Control Lock
Common Ground
.... try not to set fire to anything.
*I have a 12v test screwdriver + croc & a meter, so going Loaded For Bear lol
Correction >> preliminary venture into Cable Jungle :( phale!
Muchho loombindings mean industrial strength crowbar wielding to exhume my traces... Doh :/
Phil
I caught 'Goldfinger' on the tellybox the other night; nice nixie counter on the nuclear bomb at the end.
Close! It's actually a light pipe based incandescent display. Uses clear plastic sheets with etched digits on one side with a lamp mounted to either the side. Visually very similar and unlikely to be told apart other than by a display tech nerd...like me...as they look very alike.
Big giveaway? Colour. If it's white it's not Nixie based.
Have seen them in a few bits of test gear but never as widely as Nixie's. Easier to drive, probably a bit cheaper...but more power hungry, hotter running and of course less long lived. No use where having a digit potentially failing could be a safety issue obviously.
  • Like 6
I rode in an elevator that had etched side-lit numbers in a little window for the floor you were on.
That's the only time I've ever seen them in use. They have one advantage over nixies, and that's intensity of the digits- neon ionization reaches a maximum useable limit quite quickly.
On the other hand, the clock I have has one really neat feature- it uses PWM to change the intensity of each number: net result is each digit can fade into the next. Watching at a slight angle is mesmerizing because the numbers jump back and forth as they change.
Phil
