PhilA Posted March 6, 2019 Author Posted March 6, 2019 Apparently for the year and the plant it was made at, it should be the same green as in the picture above of the engine with the zoomie pipes. They changed the color almost arbitrarily, it seems. Phil
MorrisItalSLX Posted March 6, 2019 Posted March 6, 2019 Paint it pink with yellow sunflowers just to annoy the, suspected bearded, purists.
cort1977 Posted March 6, 2019 Posted March 6, 2019 For goodness sake, they should be pleased that the car is owned by someone making such a good job of it. As ever, much better to have it on the road being enjoyed and inspiring the next generation of enthusiasts than mouldering in a shed whilst the owner worries about the right shade of green. Skizzer, mat_the_cat, Burnside and 3 others 6
tooSavvy Posted March 6, 2019 Posted March 6, 2019 ^^ I have had 1 '+vote' for choosing red vac pipe for my "blingfest"... One in the eye for the Boring Bloo school.... Up Theirs!! brandersnatch 1
Junkman Posted March 6, 2019 Posted March 6, 2019 Sadly the valve count is the only one that's correct. PhilA 1
PhilA Posted March 6, 2019 Author Posted March 6, 2019 For goodness sake, they should be pleased that the car is owned by someone making such a good job of it. As ever, much better to have it on the road being enjoyed and inspiring the next generation of enthusiasts than mouldering in a shed whilst the owner worries about the right shade of green.That's kinda where I am with it, too. I'll take it to the scrapyard, have it fragged and sent on the slow boat to China to become paperclips if I so see fit. It's my car. Phil Burnside, Rocket88, STUNO and 3 others 6
Momentary Lapse Of Reason Posted March 6, 2019 Posted March 6, 2019 That's kinda where I am with it, too. I'll take it to the scrapyard, have it fragged and sent on the slow boat to China to become paperclips if I so see fit. It's my car. Phil Too Bloody True!
hairnet Posted March 6, 2019 Posted March 6, 2019 is it gonna get used - yes does it matter what paint goes on anything? - no no gonna be concours is it ffs fk them post pics of ford woodys on their page
busmansholiday Posted March 6, 2019 Posted March 6, 2019 Always remember Junkman's classic phrase; Do not paint !
PhilA Posted March 6, 2019 Author Posted March 6, 2019 Well, I would like this Not To Rust, so I Shall Paint. I could have painted it Disney Go Away Green. Phil
PhilA Posted March 6, 2019 Author Posted March 6, 2019 It had been suggested that I check the water redistribution tube that goes from the water pump outlet all the way past the valves for cooling, then to the rest of the engine. It's a brass contraption and falls apart. I am happy to report that it's in good shape. In this (rather terrible) factory service manual diagram you can just see the enthusiastic squirt of water from the tube: From http://pontiac.oldcarmanualproject.com/manuals/1949/1949%20Pontiac%20Shop%20Manual/09-Engine%20Cooling%20and%20Oiling/page1.html I also did a Squire Dawson and bought a roll of 1/64" gasket paper. I'm going to buy a roll of cork and another of composite because it's cheaper than buying precut gaskets. Phil LightBulbFun, Squire_Dawson, Junkman and 4 others 7
tooSavvy Posted March 7, 2019 Posted March 7, 2019 ..I'm going to buy a roll of cork and another of composite because it's cheaper than buying precut gaskets.. Supplying your own craft knife & post-cut fingers?
PhilA Posted March 8, 2019 Author Posted March 8, 2019 I ordered a spare spark plug to replace the Autolite oddity amongst the Delcos. They changed the size of the things. This one is smaller... I may order 7 more else that'll break my OCD. Traced the water pump gasket. Cut it out. Then measured the thickness of the paper properly and realized it needs to be 1/32" thick not 1/64". Shall try again. Finished painting the head. That's now drying, hopefully no flies decide to land in the fresh paint. Phil Squire_Dawson, mat_the_cat, somewhatfoolish and 4 others 7
Junkman Posted March 8, 2019 Posted March 8, 2019 Always remember Junkman's classic phrase; Do not paint !I'm with Phil there.Its natural beauty has long since been destroyed by brush and spray gun, so I'd paint the living shit out of it.I'm still not decided whether I like the non authentic colour thingy, though.Thanks God fuck my opinion isn't important here.
PhilA Posted March 8, 2019 Author Posted March 8, 2019 Well, I know you owned one and I'm not sure if it still had its original color but the paint on the timing cover is the original shade on this example: Compare to my choice and I believe your pessimism may be quenched slightly. Phil
Junkman Posted March 8, 2019 Posted March 8, 2019 You did a good job approximating it.I'd also try to match it instead of shelling out on some authentic resto stuff from Bill Hirsch. http://www.hirschauto.com/ENGINE-ENAMEL/productinfo/EE-QUART/PON%20BL%20GRN/ PhilA 1
Squire_Dawson Posted March 8, 2019 Posted March 8, 2019 Good work. It looks much better painted and as the engine is out, why not. I would cut another gasket and use them together equals correct thickness. PhilA 1
PhilA Posted March 8, 2019 Author Posted March 8, 2019 I was considering it, but I'll pick up the correct thickness stuff, in composite. That's the correct type for it. It's also a little more forgiving of surfaces that aren't 100% smooth. Phil Squire_Dawson and LightBulbFun 2
PhilA Posted March 8, 2019 Author Posted March 8, 2019 You did a good job approximating it.I'd also try to match it instead of shelling out on some authentic resto stuff from Bill Hirsch. http://www.hirschauto.com/ENGINE-ENAMEL/productinfo/EE-QUART/PON%20BL%20GRN/I was considering that, but it's going to be next time round. I want to get the body painted in the correct shade of blue, to do that I want to pull the body off and do it right, as there is not an insignificant amount of rust repair needed on the body.That point would be where it starts getting the absolute correct hues- chassis, engine, gearbox, body, dashboard. Right now I want to get it mechanically and electrically safe so I can start driving it about. Phil Skizzer, tooSavvy and LightBulbFun 3
Junkman Posted March 8, 2019 Posted March 8, 2019 Incidentally mine was rotten as a pear. Kansas car. But the frame was sound, so I didn't care.I also had to rebuild the gearbox. Otherwise it was mechanically sound and the brakes were better than the ones on my Exner era Imperials, which feel twice as rapid.
PhilA Posted March 8, 2019 Author Posted March 8, 2019 Yeah, the frames are definitely made from better metal than Fisher was using. The brakes on mine are good, though they do need a bit of adjustment because the pedal travel is excessive. Mine is bad along the passenger side sill, A pillars are both bad and the base of the C pillars in front of the rear wheels- all the places mud collects and stays damp. The air here is so moist that any unprotected steel looks Italian within a few months- my old engine lifting chain pictured a few pages back was galvanized and now looks like it's been sat in salt water at the docks for decades. We don't get the gentle patina like you do out west, here the rust bites in hard, but usually top down. It's odd to find a vehicle here where the underside has gone before the top. This car spent a lot of its life inland. Phil hauserplenty and Squire_Dawson 2
Squire_Dawson Posted March 8, 2019 Posted March 8, 2019 Will you fit the water pump gasket dry, or put something on it? I'm tempted to put a little jointing compound on when I do mine.
PhilA Posted March 8, 2019 Author Posted March 8, 2019 I have some sealant left over from when I did the Renault that's in good condition still (expensive, good stuff). I'm going to use a light smear of that. It's a funny RTV style compound. Phil
Snipes Posted March 8, 2019 Posted March 8, 2019 Yeah, the frames are definitely made from better metal than Fisher was using. The brakes on mine are good, though they do need a bit of adjustment because the pedal travel is excessive. Mine is bad along the passenger side sill, A pillars are both bad and the base of the C pillars in front of the rear wheels- all the places mud collects and stays damp. The air here is so moist that any unprotected steel looks Italian within a few months- my old engine lifting chain pictured a few pages back was galvanized and now looks like it's been sat in salt water at the docks for decades. We don't get the gentle patina like you do out west, here the rust bites in hard, but usually top down. It's odd to find a vehicle here where the underside has gone before the top. This car spent a lot of its life inland. PhilSills? Surely you mean rockers?
PhilA Posted March 8, 2019 Author Posted March 8, 2019 I was trying to be nice. If I had said my rockers were rusty, some smartypants would have been along to point out I have a sidevalve engine. Phil tooSavvy, Squire_Dawson, SiC and 2 others 5
Squire_Dawson Posted March 8, 2019 Posted March 8, 2019 I have some sealant left over from when I did the Renault that's in good condition still (expensive, good stuff). I'm going to use a light smear of that. It's a funny RTV style compound. Phil RTV? A coating of grease is another option, the trouble is that makes 3 choices I must decide from, my theory is grease will aid future removal but jointing compound should give a better seal. Keep us updated. mat_the_cat 1
PhilA Posted March 8, 2019 Author Posted March 8, 2019 RTV? A coating of grease is another option, the trouble is that makes 3 choices I must decide from, my theory is grease will aid future removal but jointing compound should give a better seal. Keep us updated.With composite gaskets on a moderately small surface area like thermostat housing, RTV works well in my experience because: 1) if you pull those apart they've crushed to match the surface and leak if you use them again2) with rtv they tear, no matter what. But, the surface can be cleaned with a blade and a new gasket applied The thermostat is easy to work on. The water pump is awkward because of the proximity to the radiator. I'll go with RTV because I just want to put it on and not have to worry. Phil
PhilA Posted March 9, 2019 Author Posted March 9, 2019 In the spirit of Autoshite, I have cleaned up the head gasket. It's in good shape. Plus I'm kinda skint right now. Bonus points for cleaning it with a Mister Muscle Magic Eraser. Also, because head gasket is a 15 minute job with the engine in the car... Phil Lacquer Peel, Junkman, LightBulbFun and 4 others 7
PhilA Posted March 10, 2019 Author Posted March 10, 2019 This morning I went to Napa and bought a roll of 1/32" gasket. $25, not cheap but it's good stuff. Traced the old water pump gasket with a pencil. Gasket scraper also doubles as a knife. Tube of Renault RTV from when I did the GTA's engine. Thin layer applied to get the gasket to stick... And attached and tightened down. Cleaned the junk out of the threads- I do need to get another stud. Pulled the gasket off. This is where it was leaking from. Gently put my file to it- there's a couple raised pieces. This was leaking. Now there's only a low section, which isn't too low. The sections I took off were at least 1/64" raised. Cleaned up the head bolts. Wire brush, then run the die up the threads, then wire brush again on the threads. Then a gentle wipe down with an oily cloth to protect. Thirty of the blasted things later... Cleaned the deck down and applied the gasket. Head cleaned down and applied to the block. Head bolts in finger tight. And finally stuck the plugs in to stop anything from getting into the bores. Ran out of time, gonna do a two-stage torque on the head bolts tomorrow (25, 60 lb/ft) and then turn it over to check compression. Phil Conrad D. Conelrad, adw1977, RayMK and 22 others 25
