1951 Pontiac Chieftain
Someone on the AACA found this video which shows the air cleaner bracket very nicely.
It also has the advantage of sounding nice. Turn it up.
Phil
^^ I'm getting quite excited about my upcoming pooper-pipe 'refresh'.... For quite the same reason
What a Glorious Sound :wub:
Wow that battery is unusual I thought it was a Suitcase!
Think you need nice pipes on yours something that makes it sing yet is in keeping and old school :mrgreen:
As you can hear in that video, with no downpipe on the manifold, it's a very quiet engine, even when opened up a bit. The stock muffler is a single straight-through so under idle to light throttle is rather quiet, opened up you get that TGHRRGRRGRRGRRGRR note quite pronounced from it.
Once it's going I'll be making some films to be enjoyed. It's a nice sounding engine.
Phil
with the slightly lumpy fast idle that sounds like an aeroplane engine lol
It does. I'll need to set the idle mix and timing properly after I've redone the tappets.
I realized after someone mentioned it that the head bolt that should be at the front to hold the air cleaner was in the wrong place.
Moved the two, no idea why the front one had a washer so that's gone.
Bought a length of steel bar. Got as far as drilling a 3/8" hole in it tonight. Need to cardboard up the design and then bend and cut the bar to length as the support.
Phil
Right underneath  "Feed The Headlamp Masks to a Crocodile" hopefully....
They have officially been donated to a colleague at work. I last saw them hanging on his pinboard. You can sleep better at night now.
Phil
Only been able to watch it now
That's what I thought
Biplane
Metalwork.
Needs a bit of adjustment but it should be okay. It holds the oil pan up okay.
First blood has officially been shed for this vehicle also, I caught the back of my knuckles on the hacksaw blade.
Phil
Went find my SAE spanners and hung them up on the wall. Tidies up the bench.
Adjusted the bracket a little and gave it a try. Not bad, though I think bracket mk2 is in the future.
Even with no filter material or oil in, the intake is quieter than the rest of the engine.
I really need to redo the tappets...
On a side note I took the front right wheel trim off to inspect. I just ordered some clear red lacquer to redo the center badge.
They're not bad looking wheels. They also have provision for the poverty spec wheel caps.
Phil
Has that been lowered? It looks suspiciously like it should be featured on RetroRides in that photo?
It has, just a little bit.
Phil
Pulled the old wire out from the gearshift linkage.
Cleaned up the connector, checked to see if it would take solder. It did.
Bought a reel of 14 gauge wire, a bit overkill but still, it's what was there.
Put the wire in but the old plastic housing had split.
Hot glued it into place to help it stay put.
Much better!
Got it back down the column. This time there's no bare wire hanging out.
That's definitely better.
All back in place in the housing.
Lamp assembly in place.
Yup, it works, though I'm going to replace this with an LED for cool running and longevity.
Not bad. Need to redo the green discs, I think. The reverse one lets a lot of white past.
Phil
Probably, and I was thinking about it. The discs are nearly opaque, designed to let only the smallest amount of light through. The position light should merely glow, not be a searchlight. Therefore the green discs would have to remain and plus, I didn't order any green LED's
The LEDs I did order are due to be here tomorrow (they went to New Orleans, 67 miles away, went past my house and are now in Lafayette, about 130 miles away).
Hopefully that shipping SNAFU is fixed. We'll see what it all looks like with the LED lighting in place... Then I'll begin tearing out the old wiring.
Point of no return!
Phil
SNAFU
Situation Normal Always a F#ck Up ...... ?? [Guess]
Situation Normal All F#ucked Up ...... [Googled] :)
SNAFU
That's the one
Have discovered where the horn wiring comes out of the steering column; not sure how the slip ring comes out. Further investigation required.
Adjusted the green filters, the light is better now. Fixed things in place a little better and blocked the gaps the light was coming out of. Plus the digits don't rattle any more.
Phil
Also found the reason I couldn't figure out where the throttle return spring is meant to go.
That'll be because the hook it's meant to connect to is missing (just below the square access plate in the flywheel housing).
Bolt with a shank to be purchased and modified to suit purpose.
Phil
Bought a couple screws, a couple nuts and some rubber bungs that I cut down to fit.
Hood now sits level.
Hopefully tomorrow I'll sort out the return spring mount.
Phil
After having spent more time traveling in circles around America than they did getting from China to here, my bulbs have finally arrived.
I'll give them a try tonight and see how well (or otherwise) they work.
If they're good there's some more pretty looking ones with nicely enclosed optics available, for ones like the glovebox and such where the bulb is visible.
Phil
that happened here once
bought something from scotland it went dumfries hertfordshire warrington then here
coulda collected it from warrington and they wonder why it took 4 days ffs
It probably got put on the wrong truck at New Orleans, which is why it vanished off eastbound to Lafayette.
They could have just dropped it off on the way...
Phil
I made a SPRING BOSS.
Fits into the flywheel housing.
Now the pedal goes back, feels smooth. Might need a spring with a few more pounds behind it though.
The LED's have a rather strange gamut. The skeeters got real bad because it's been a hot day so more on that tomorrow. Typically the thing doesn't fit inside the gearshift thingy.
Such is life.
Phil
This picture looks scarry, it's like a scene from the film "Christine" where your just about to be the cars next victim !
I'm going to have nightmares now!
I think for Halloween, smoke machine, cardboard teeth covered in tin foil in the grille, more red and orange lights scattered about and a lightning light for outside the back window of the garage.
Phil
