Carlton Weber carb help
Hi all just looking for some help with my Carlton , it's the 2.0 CIH engine with a 32/36 dgv fitted, the carbs been rebuilt , setup via an online guide and timed via a timing light.
It is running the best it's been but I still can't seem to get rid of a stutter after coming off the gas then going back on it there's a sort of jerk/delay then it goes unless you slight apply throttle????
Ta
How big is the stutter? A fraction of a second or a bloody long time?
Ive heard accelerator pump mentioned before reading up on them,
Theres a filter fitted to the fuel line in the bay that seems ok, dont know what other one is like.
Its only a fraction of a second but becomes annoying round town
That hesitation where the engine feels like it momentarily wants to die when you lightly press the accelerator is usually it going lean. It could be the accelerator pump jet a bit blocked, or I'm pretty sure it's a diaphragm that operates it might be perished or overly stretched. Another thing to check is the idle jets aren't blocked. There will be a cluster of little drillings around the throttle butterfly when it's closed - these are the idle circuit for running up to around 2000rpm. Check they're not blocked by poking a bit of wire in them.
Before messing with the carb I'd second Pete M and go electrical, I wonder if your distributor spindle is worn or bob weights moving correctly, I imagine it has a vacuum advance mechanism?
Cough - pedant - progression jets / drillings
If it's had a carb rebuild the accelerator pump is part of this . I just did it on my cortina as it was leaking,
Did you unplug the advance vacuum line when you did the timing ?
Yes, the vac advance was plugged off when setting the timing.
Is it auto choke ? Mine does this a bit and my half cocked theory is the choke isn't opening up enough so it's running rich .
It's a manual choke, if left on the idle raises enough to hide the hesitation.
Sounds like it's too lean - in days of old a rough idea of what was going on was to pop a sparkplug out and look at the colour of the electrode. I'm sure that the HBOL had comparison pictures in it.
