garage carpet- attract mice or no?
i rent an old concrete garage in a block , i was thinking id like a bit of carpet on the floor to help when rolling about under the car
but will it attract mice as i cba with all that
If anything, it'll repel them, because they'll have to take their shoes off inside.
Sent from my SM-G900F using Tapatalk
And they hate hoovering.
Had carpet in mine for twenty years and no problems.
We do have several cats though...........
Do cats even wear shoes though?
Have you not heard of puss in boots??
no, you'll be fine unless you feed them :-D
+1 for working on carpet, I use the old rugs the kids destroy in the house every couple of years.
Anything on the carpet is either a tool or came off the car.
Stuff doesn't roll away on carpet, how many times has a dropped bolt or screwdriver rolled just out of reach ?
I sometimes work on the grass, its nice to work outside on a sunny day, carpet stops things getting lost .
As for mice and carpet, your car has carpet, is it full of mice ?
Saving up for a two post lift, that is my next big purchase.
I have a old carpet from the house in the garage. It makes it better to work on and stops the dust from coming up and covering the car
If you can find some heavy duty rubber matting. I find once carpet gets oil/diesel/antifreeze etc soaked on to it it won't go away and you'll be laid on it.
Carpet offcuts from our local carpet place (unsurprisingly) have served me well. Just use them then replace when they get nasty. Often free for smaller pieces, or just a couple of quid.
Mice have never been a problem.
Mice wouldn't be a problem even if they visited really. Unless they chewed anything important. Which they haven't so far. Years ago I had a family of wood mice living in my garage. They were incredibly tame and did no harm. I even named the more obvious ones. Destructive mice can be an issue though..
Suspect the carpet will not be an attractant though.
Blankets off the kids' beds does just as well.
As does an old duvet.
Don't forget to put them back on before they go to bed though.
clogs man, with mice it's clogs.
Shoes FFS
and anyway you should be ok as long as it isn't a stair carpet
Pouring oil, diesel and antifreeze on my carpet has never helped me get laid :-(
I have carpeted mine with old carpet tiles (rescued from a classroom refit at work) glued down in the areas around the cars and loose up the centre so they can be taken up and scrubbed. Also have a couple of shelves from an old filing cabinet under the oily bits for drips (these have oil absorbent sheets - liberated from the oil spill kit at work too)
