320Touring's Toledo FIN
Having rattled 250 miles onto this so far, I reckon this is whit is needed..
Brakes/tyres
Fit last wheel cyl and bleed the system
Matched set of 175/70/13 wouldnt go amiss
Engine
Oil and filter change
Air filter change
Spark plug change
rotor arm and dizzy cap change
Timing belt plus aux belts change
Rocker cover gasket change
Rev counter sensor fix
Temp gauge sensor fix
Suspension
Front dampers change
Rear dampers change
Bodywork
A bloody good clean
Sort damage to drivers rear door
Sort driver and passenger mirrors
Clean and rust treat underneath
Interior
Sort passenger door rattle
drivers door speaker and cover need replaced and fitted
fit radio
Its all fairly basic stuff, and beyond the service and brake work, none of it is pressing
Belated Congrats on the Mot pass and the road trip. That work to do list isn't bad at all. Certainly needs alot less than my same age Cavalier has had!
Once the essentials are done you will rattle through the rest nae probs neebs. Good to see this car resurrected.
Cheers- Yeah its nice to have a car that is basically sound and just needs some titivation rather than indepth work!
your name is on the list to help re cleaning it:)
Another 3 things it needs
Cluch pedal adjusting
Gear linkage greasing/adjusting
a new gear gaiter
And another thing it needs: driven.
Another sound brief that wasn't exactly common in its day but bloody worthy nevertheless, get the essentials done and some miles on the clock.
As for tyres, I can't see myself using the 15" Corsa steels with 185/55r15 Maragoni winter tyres any time soon, so if you fancy a loan of them, give us a shout.
Having put 300 on it by close of play tomorrow I dont think she'll be lacking in the miles;)
thanks for the offer re wheels I'll look into options and let you know- the 70 profiles are well comfy!
Initial investigations suggest that I can get well cheap Uniroyal Rainexperts
although I am tempted by the tyres in the 2nd picture for lolz..
I decided that the ole workhorse needed to see some effort on my part..
First up was the air filter- including a favourite bit of design of mine on this car- the massive S on the airbox.
I also had a wee fiddle with the SPi setup- the car had a wee hesitation at low rpm-and I'd had similar with my old 1.8 years ago.
lo and behold the same vac pipe from the airbox had failed.
I trimmed it up and refitted.
Next up was the joy of sparkenplugen.
I'm unsure whether they'd ever been done on the car, So I took the precaution of getting the block nice and hot, then squirted some penetrating fluid onto each plug in turn.
Luckily they all came out easily and looked in fair condition.
I've got part numbers and costs for the dizzy cap and rotor arm so will have to check their condition presently
Last but not least it was oil change time..
First up was a mercy dash to Hellfrauds, as I couldnt find the filter I'd previously bought.
There was a fair amount of oil on the sump but it seems to be coming from the rocker cover.
Once the oil was drained, I tentatively turned the oil filter to get it off-taking it easy and it finally moved - it had certainly seen better days!
once everything was back together I topped up the oil and went to check the level.
the Dipstick and the top part of the tube came away in my hand:( It looks like the orange plastic is brittle and has failed.
Looks like I can get a replacement from ebay- the temporary* repair involved the foam cover from a scraper handle and some cable ties:)
Didn't see this thread before. Must read forum more often.
Had a wee lol at chaseracer inadvertent correct guess on first page.
You might get a seat...  ;)
Great find and save. These must be up there with the malaga on the rarity scale.
cheers chap-plenty happy with it so far:)
got the brakes bled this morning, feels much more positive:)
then loaded it up as a service wagon to go help the bro out with the 325
Brakes/tyres
Engine
Oil and filter change DONE
Air filter change DONE
Spark plug change DONE
Suspension
Rear dampers change
Bodywork
A bloody good clean
Interior
fit radio
a new gear gaiter
First tank of fuels is in..
398.7 miles on 50.93l of unleaded.
35.6mpg - pretty damn good given that the speedo doesn't read below 85;)
I'll drive it a bit more conservatively on this tank..
also tookbit ti the local Waitrose where it added some class to the carpark:)
I thought it only right that it got a wash, Clay and Wax seeing as how the Lupo got it
looking much better now:)
In an uncharacteristic splurge of cashola, I appear to have procured new door mirror glass, a new dipstick tube top and a new gear stick gaiter.
hopefully they will arrive this week and I can get them on the car PDQ.
I'll also need to give some consideration as to how I go about coating the underside to avoid rust issues.
Mirrors arrived for this today- 1 came with spring clips, 1 without.
neither seemed keen to mate up with the mount in the mirror:(
I didnt want to force them incase they broke-have emailed the seller for some info
Get yourself some Cans of Tetrosyl, it's proper stuff and goes on nice.
Before you do though, get the 2 pack of Dinitrol from eBay for about 25 quid. It comes with a metre long bendy lance which is shit hot for getting into all box sections.
Well worth the effort, it preserved the Corsa through many winters.
Major success today-got a 2nd key cut(a whole 11 pounds).
Also made it to its inaugural Scotoahite where It met up with its namesake..
Behold the tremendous Toledo Toledo Twins!
This is such a happy story so far.
Verily the dream is being lived.
I think CMS206 was rather taken by its ever present grip-even ib hurricane bawbagesque conditions
