Forty-two Posted July 27, 2015 Posted July 27, 2015 I need a single spark plug and some oil. Looking at the Halfords website to start off with, its the closest place to work so I can nip out at lunch to pick the bits up. Oil, no problem, Spark plug, more complicated. I can't browse the spark plugs, I need to enter the make and model of a car or a reg plate. I am looking for a spark plug for a lawn mower, no reg plate, it ain't a car. Euro Car Parts have the same method of searching. Am I doing it wrong? I am sure once upon a time it was possible to browse the different types of plugs. I wonder if I can get a split fire plug for my Briggs and Stratton?
Barry Cade Posted July 27, 2015 Posted July 27, 2015 http://www.ngkpartfinder.co.uk/horti.php?type=SPARK%2520PLUGS&manufact=BRIGGS%2520%2526%2520STRATTON&cat=Engines&model=10.0HP%2520251400%252C%2520251700%2520Series%2520%2528L-Head%2529
Honey Badger Posted July 28, 2015 Posted July 28, 2015 I need a single spark plug and some oil. Looking at the Halfords website to start off with, its the closest place to work so I can nip out at lunch to pick the bits up. Oil, no problem, Spark plug, more complicated. I can't browse the spark plugs, I need to enter the make and model of a car or a reg plate. I am looking for a spark plug for a lawn mower, no reg plate, it ain't a car. Euro Car Parts have the same method of searching. Am I doing it wrong? I am sure once upon a time it was possible to browse the different types of plugs. I wonder if I can get a split fire plug for my Briggs and Stratton? Ring your local agricultural plant place, they will have all this kind of stuff in stock,
Noel Tidybeard Posted July 28, 2015 Posted July 28, 2015 Block & Quail used to do spunk plugs for lawn mowers along with oils etc saucedoctor 1
pshome Posted July 28, 2015 Posted July 28, 2015 Does it have a Bosch pump?Was sonst... barefoot, Inspector Morose, purplebargeken and 2 others 5
Pillock Posted July 28, 2015 Posted July 28, 2015 Fit a Pinto to your mower. And use the registration from a pinto engined car. The Moog and derskine 2
Taff Posted July 28, 2015 Posted July 28, 2015 Fit a Pinto to your mower. And use the registration from a pinto engined car. don't be ridiculous. Kent engine for lawnmowers, silly. derskine 1
Vince70 Posted July 30, 2015 Posted July 30, 2015 don't be ridiculous. Kent engine for lawnmowers, silly.Everyone knows you should only use a ford V4 when doing an engine conversion..
fordperv Posted July 30, 2015 Posted July 30, 2015 Everyone knows 3.0 Essex engines are the best for lawnmowers because of the torque and the sound to entertain the neighbours
