DodgyBastard Posted June 30, 2015 Author Posted June 30, 2015 I made a new thread in the open forums with all the info needed about the place.
DodgyBastard Posted July 3, 2015 Author Posted July 3, 2015 After driving over 500 miles in the 305 the rear end has started creaking on every bump. I can't take it any more...
DodgyBastard Posted July 4, 2015 Author Posted July 4, 2015 I took the 305 out for the day, the rear end is still creaking quite badly... I went to the old unit. DSC_1644 by srblythe, on Flickr This notice was on the door! DSC_1643 by srblythe, on Flickr Does that mean he's now the owner of my FSO? Anyway I went up to a small graveyard near Peat inn where Andy CMS nearly got arrested... DSC_1653 by srblythe, on Flickr DSC_1655 by srblythe, on Flickr DSC_1660 by srblythe, on Flickr DSC_1662 by srblythe, on Flickr DSC_1665 by srblythe, on Flickr DSC_1666 by srblythe, on Flickr DSC_1681 by srblythe, on Flickr DSC_1680 by srblythe, on Flickr DSC_1679 by srblythe, on Flickr The point in my visit? DSC_1667 by srblythe, on Flickr Unfortunately nobody is ever home whenever I go round. The white Lada would be a good source of parts for mine. worldofceri, catsinthewelder and Semi-C 3
DodgyBastard Posted July 4, 2015 Author Posted July 4, 2015 Also got back to Foadwerx 2.0 and noticed I have a leak DSC_1720 by srblythe, on Flickr from here DSC_1719 by srblythe, on Flickr
Lacquer Peel Posted July 4, 2015 Posted July 4, 2015 Is it leaking from the accelerator spindle? It's supposed to be quite an easy fix.
DodgyBastard Posted July 5, 2015 Author Posted July 5, 2015 Yeah, that's where it's coming from. Sent from my D6603 using Tapatalk
BorniteIdentity Posted July 5, 2015 Posted July 5, 2015 On an unrelated note - can you give me the heads up if/when you move on that Ovlov 300? It's the spit of my first car - same colour/spec/year etc. Much obliged.
BorniteIdentity Posted July 5, 2015 Posted July 5, 2015 WTF? You mean I'm not the only one interested in such shite? I really AM at home round here. catsinthewelder 1
DodgyBastard Posted July 6, 2015 Author Posted July 6, 2015 On an unrelated note - can you give me the heads up if/when you move on that Ovlov 300? It's the spit of my first car - same colour/spec/year etc. Much obliged. The 360 glt belongs to mrs foad, she isn't interested in selling it at the moment.
DodgyBastard Posted July 8, 2015 Author Posted July 8, 2015 The list of jobs needing done on the fleet are starting to build up, The Proton needs the fuel filler neck replaced, the panda has a sticking brake caliper, the 360 has both front calipers sticking intermittently, the 305 needs a seal for the fuel pump and the rear trailing arm bushes doing. The Alto needs a front wheel bearing, The tata needs a lot of bodywork but still runs fine. The Lada needs a shitload of welding before anything else gets done on it..
derskine Posted July 8, 2015 Posted July 8, 2015 Might have a pair of serviceable 300 series calipers, if you define serviceable as sitting in an angry Irish man's back garden for 10 years.
Lacquer Peel Posted July 9, 2015 Posted July 9, 2015 Would you like an XUD9 (12 horses more!) with a Bosch pump complete with free* Citroen Xsara for its scrap value? DodgyBastard 1
DodgyBastard Posted July 9, 2015 Author Posted July 9, 2015 Would you like an XUD9 (12 horses more!) with a Bosch pump complete with free* Citroen Xsara for its scrap value? Perhaps!
DodgyBastard Posted July 9, 2015 Author Posted July 9, 2015 Is this what I'm looking for the fix that fucking creaking sound coming from the rear end? http://www.ebay.co.uk/itm/400803897216?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Richard Posted July 9, 2015 Posted July 9, 2015 I think so, but I'm not 100% sure. If it is you can get it cheaper here http://www.aepdirect.com/rear-arm-bearing-kit-p6015?category_id=647 DodgyBastard 1
DodgyBastard Posted July 9, 2015 Author Posted July 9, 2015 Worth a punt at £35, my local motor factors couldn't find any 305 kits listed but managed to find a c15 kit for £67 which shares the same code as the 305 kit listed on ebay...
DodgyBastard Posted July 9, 2015 Author Posted July 9, 2015 Now. any clues as where I can get the seals i need to stop the lucas pump leaking?
Lacquer Peel Posted July 9, 2015 Posted July 9, 2015 Do you have any diesel specialists nearby? Or http://www.ebay.co.uk/itm/LUCAS-CAV-DPC-DIESEL-FUEL-PUMP-SEALS-FOR-PEUGEOT-CITROEN-RENAULT-VOLVO-FIAT-FORD-/160993995705
Richard Posted July 9, 2015 Posted July 9, 2015 Patterson Diesel is within sight of the unit, I don't know how good they are though.
DodgyBastard Posted July 9, 2015 Author Posted July 9, 2015 Patterson Diesel is within sight of the unit, I don't know how good they are though. Yeah, they're in the next industrial estate. I was keeping them in mind to pop in and see if they can do anything with it.
Dave_Q Posted July 9, 2015 Posted July 9, 2015 If it's the accelerator spindle they are a standard size o ring, can't remember the exact size I'm afraid but you can just measure the old one and order from simply bearings etc. Lacquer Peel 1
DodgyBastard Posted July 10, 2015 Author Posted July 10, 2015 I went to Pattersons but they were wanting around £80 to replace the seals. Fuck that, it's nearly half of what I paid for the car...
DodgyBastard Posted July 10, 2015 Author Posted July 10, 2015 Found this on another forum so for future reference I'll stick it here... First put a tray under the vehicle below the pump to catch all the diesel which will come out (I didn't do this !).Next mark the position of the throttle lever and the cold start lever in relation to the pump top and make note of how the springs fit to these arms. undo the 17mm banjo connection for the fuel return pipe, move this out of the way. remove the 10mm nuts which secure the 2 arms, remove the arms noting how they fit etc. Remove the 4 small torx bolts and take the top off the pump - this is where you'll lose a good amount of fuel. Push the throttle shaft down and out of the lid as you pull the lid off. There are 2 "O" rings on the shaft - replace these with 2 new ones from the repair kit. My old seals broke off they were so hard and brittle. Put it back together (I Know this sounds like Haynes but it is just a straight reverse of taking it apart). Start it up and check for leaks. Lacquer Peel 1
twosmoke300 Posted July 10, 2015 Posted July 10, 2015 I've watched fil do these on a tractor and he had a homemade tool of some kind to stop the shafts pulling out as you lift the top off . Apparantly all the magic escapes if that happens Steviemillar 1
DodgyBastard Posted July 12, 2015 Author Posted July 12, 2015 The ex shitpeas pugs meet again... DSC_3039 by srblythe, on Flickr Richard, oldcars and vulgalour 3
DodgyBastard Posted July 12, 2015 Author Posted July 12, 2015 We also got some of this! unwanted police attention by srblythe, on Flickr brickwall 1
cobblers Posted July 12, 2015 Posted July 12, 2015 That 309 is new to me and it is flipping fit. I want to do wheelspins in it.
DodgyBastard Posted July 13, 2015 Author Posted July 13, 2015 Oh dear... Sent from my D6603 using Tapatalk oldcars, Richard, Jim Bergerac and 3 others 6
