Split_Pin Posted February 19, 2017 Posted February 19, 2017 You forgot to photoshop the wheeltrims back on too. Half a job! Ghosty, DodgyBastard, alf892 and 5 others 8
bub2006 Posted February 19, 2017 Posted February 19, 2017 I must sort the leaks out on my van. I removed drain plugs on drivers side but now it's coming down the passenger side! FOAD will you be kind enough to let me know if the driveshaft on the passenger side looks OK on your spares van. If so and you have no use for it may I put my name down please? Like the carlton too. Not seen one in years now.
DodgyBastard Posted February 19, 2017 Author Posted February 19, 2017 I must sort the leaks out on my van. I removed drain plugs on drivers side but now it's coming down the passenger side! FOAD will you be kind enough to let me know if the driveshaft on the passenger side looks OK on your spares van. If so and you have no use for it may I put my name down please? Like the carlton too. Not seen one in years now. I'm not sure about the driveshaft but I'll get a look at it tomorrow and let you know. It did drive fine without any noises so it should be ok. You can have it if you need it.
DodgyBastard Posted February 19, 2017 Author Posted February 19, 2017 You forgot to photoshop the wheeltrims back on too. Half a job! Schoolboy error, must try harder. HMC and DeeJay 2
Jim Bell Posted February 19, 2017 Posted February 19, 2017 Those trims would look pretty good rollered green. DodgyBastard, Richard, loserone and 1 other 4
They_all_do_that_sir Posted February 19, 2017 Posted February 19, 2017 Hope those are cut springs Sent from my D6603 using Tapatalk
DodgyBastard Posted February 19, 2017 Author Posted February 19, 2017 In other news I cut the rusty middle section off the 190e, it was a right bastard to get off and I had to resort to angle grinding the bolts off while lying on my back underneath the car. Even with safety goggles on I still managed to get grit in my eye and a face full of sparks. The cheapest replacement I could find was a bosal one at £100.All I have left to do is fit the exhaust, discs and pads and get it in for a retest next week. I'm also planning on doing some welding on the Alto before I put it in for another test, hopefully I'll get that done next weekend. DeeJay, HMC, CreepingJesus and 1 other 4
CortinaDave Posted February 19, 2017 Posted February 19, 2017 That may be the coolest motor you've had yet.Want. I like the crapness of the trims, but at the end of the day when its a 2 minute job for any future owner to kick them back on if they want to its hardly worth bothering about. I got a load of stick at a car show for sticking a set of slotmags on my Cortina... When its your car you have it how you want it! DodgyBastard and mk2_craig 2
bub2006 Posted February 19, 2017 Posted February 19, 2017 I'm not sure about the driveshaft but I'll get a look at it tomorrow and let you know. It did drive fine without any noises so it should be ok. You can have it if you need it.Thank you, I'm pretty sure that's what's clunking on mine. Right hand bends and islands but only on power.
DodgyBastard Posted February 20, 2017 Author Posted February 20, 2017 Shiny... Sent from my F5321 using Tapatalk HMC, Richard, rrsix and 1 other 4
DodgeRover Posted February 20, 2017 Posted February 20, 2017 I got a load of stick at a car show for sticking a set of slotmags on my Cortina... When its your car you have it how you want it!But slotmags make everything better! anonymous user 1
DodgyBastard Posted February 24, 2017 Author Posted February 24, 2017 W201 by srblythe, on Flickr Mercedes passed mot and has been pressed into daily service, it drives quite well but it will need a fan wired up/fixed as the temp rises a bit high when stationery. oldcars, HMC, KruJoe and 9 others 12
Mr_Bo11ox Posted February 24, 2017 Posted February 24, 2017 Alusilber, BorniteIdentity, Lacquer Peel and 1 other 4
dieselassist Posted February 24, 2017 Posted February 24, 2017 In other news I cut the rusty middle section off the 190e, it was a right bastard to get off and I had to resort to angle grinding the bolts off while lying on my back underneath the car. Even with safety goggles on I still managed to get grit in my eye and a face full of sparks. The cheapest replacement I could find was a bosal one at £100.All I have left to do is fit the exhaust, discs and pads and get it in for a retest next week. I'm also planning on doing some welding on the Alto before I put it in for another test, hopefully I'll get that done next weekend. Had to do the same with my old 190E 1.8 - weld up the middle section box n 2 into 1- front section that leads into that with the factory 'double U /m style clamp' - from memory it was a horrendous price so I welded in some random old exhaust tubing... rots around that clamp also, which is also a few quid to buy, once its fizzled to nothing -a couple of €3 normal exhaust clamps were welded up together into an M shape.
alcyonecorporation Posted February 25, 2017 Posted February 25, 2017 That may be the coolest motor you've had yet.Want. I like the crapness of the trims, but at the end of the day when its a 2 minute job for any future owner to kick them back on if they want to its hardly worth bothering about. I got a load of stick at a car show for sticking a set of slotmags on my Cortina... When its your car you have it how you want it!Which is why I don't often take my own car to car shows. Angrydicky 1
DodgyBastard Posted March 3, 2017 Author Posted March 3, 2017 Put the Alto in for an mot, it failed, now I need to source some parts.
Guest Hooli Posted March 4, 2017 Posted March 4, 2017 Which is why I don't often take my own car to car shows. I accidentally put my Midget in shows a couple of times when I had it. I'd gone as a normal visitor & got asked if I wanted to put it in, it was always cheaper than parking & entry so I said yes & had less walk to the interesting stuff. Was funny hearing the comments about 'non original stereo' or it's not clean enough etc. It was my daily driver ffs. Lacquer Peel and Angrydicky 2
DodgyBastard Posted March 4, 2017 Author Posted March 4, 2017 I bought this back today. Renault 18 gtd by srblythe, on Flickr Renault 18 gtd by srblythe, on Flickr Renault 18 gtd by srblythe, on Flickr I'm not a fan of the Aldi white so it'll be repainted soon enough. Either in the original colour or metallic brown. Coprolalia, Skizzer, Lacquer Peel and 10 others 13
privatewire Posted March 5, 2017 Posted March 5, 2017 Jeez, even after all this time, that shape just looks so right to me, must be one of the most handsome saloons ever. (IMHO) obv. chaseracer 1
Dick Cheeseburger Posted March 5, 2017 Posted March 5, 2017 I love the way the door shut reveals the colours of the last ten blowovers. Lacquer Peel, Skizzer, Braddon81 and 4 others 7
DodgyBastard Posted March 5, 2017 Author Posted March 5, 2017 On Friday we got the ramp back in action as one of the cables had snapped a couple of months back with Derskine's Volvo on the ramp. It was reasonably straight forward to fit new cables apart from having to cut some slots out of the ramp in order to guide the cables through.I needed to fit some new exhaust gaskets to the 190e because when I ordered the middle section I didn't replace the old ones which were actually lying somewhere on the garage floor. DSC_0456 by srblythe, on Flickr Mrs Foad checks which one goes where? DSC_0461 by srblythe, on Flickr Then the exhaust goes back on. DSC_0462 by srblythe, on Flickr Much quieter... before that we went to try filling it up with lpg. When I got to the pump I checked the fitting down by the tow bar. LPG Fittings by srblythe, on Flickr It clearly wouldn't work so I had a look online and found it needs an adapter to fill it. A quick rummage in the glovebox and I found this. LPG Fittings by srblythe, on Flickr With that fitted I went back to the petrol station and tried again, I stuck a tenners worth of autogas in and went for a drive. It won't idle very well on the LPG and regularly cuts out when not being driven.I read somewhere that the coolant temp needs to be right for the lpg system to work properly, the 190e runs cold when driven and the temp rises when sitting, the electric fan doesn't come on either. I suspect with a flush of the cooling system, new thermostat and fan wired in the car will run better on both petrol and lpg. loserone, oldcars and Skizzer 3
DodgyBastard Posted March 6, 2017 Author Posted March 6, 2017 I bought some nasty shit for the 18... It seems to work quite well... Sent from my F5321 using Tapatalk oldcars and loserone 2
Richard Posted March 6, 2017 Posted March 6, 2017 Would there be any interest at FOADWERX in a TD ZX with rusty sills and a couple of weeks MOT?
DodgyBastard Posted March 6, 2017 Author Posted March 6, 2017 Would there be any interest at FOADWERX in a TD ZX with rusty sills and a couple of weeks MOT?Yes, send me the details please. Sent from my F5321 using Tapatalk
DodgyBastard Posted March 6, 2017 Author Posted March 6, 2017 Sent from my F5321 using Tapatalk oldcars 1
DodgyBastard Posted March 6, 2017 Author Posted March 6, 2017 DSC_0484 by srblythe, on Flickr That stuff seems to work quite well, I didn't have time to do the whole car today but perhaps during the week I'll get the paint stripped and sanded ready for a respray by the end of the week. Skizzer, CGSB, The Moog and 3 others 6
loserone Posted March 6, 2017 Posted March 6, 2017 A couple of years ago I took the varnish and paint splashes off a simple wooden chair which three generations of my family have used as a decorating chair (it was probably quite nice, once). That ^^ looks like hard work.
