DodgyBastard Posted July 14, 2022 Author Posted July 14, 2022 Cord Fourteener, wuvvum, paulplom and 1 other 4
DodgyBastard Posted July 16, 2022 Author Posted July 16, 2022 Nice little run on the old smokers this afternoon. Matty, TrabbieRonnie, CGSB and 4 others 7
DodgyBastard Posted July 17, 2022 Author Posted July 17, 2022 Look what's back! juular, skoda_fan, Dirk Diggler and 14 others 16 1
Jikovron Posted July 17, 2022 Posted July 17, 2022 It seems I should have left the smokey but reliable s100 engine in it rather than gamble on a random 130 engine known for being extra fragile hgf wise, fucking things! Bleeding these simply entails parking front end down topping up the header tank and opening the bleed valve till runs out and tbh even if you fail to bleed it properly it just puts the heater out of action. All the skoda engines are tricky as the alloy block inevitably stretches up around the hot thermostat end leaving the liners 3 and 4 flush with the block deck, if the issue isn't massively bad it is possible just shim them up over so that the liners are protruding by the right 0.14ish mm amount relative to the deck but stepping up ~ 0.05mm relative to each other towards the rear of the flywheel end. Another way to rectify the issue is either deck the block to 95mm above the liner seats or fit a K series which ironically are bang on reliable in these rainagain 1
DodgyBastard Posted July 18, 2022 Author Posted July 18, 2022 11 hours ago, Jikovron said: It seems I should have left the smokey but reliable s100 engine in it rather than gamble on a random 130 engine known for being extra fragile hgf wise, fucking things! Bleeding these simply entails parking front end down topping up the header tank and opening the bleed valve till runs out and tbh even if you fail to bleed it properly it just puts the heater out of action. All the skoda engines are tricky as the alloy block inevitably stretches up around the hot thermostat end leaving the liners 3 and 4 flush with the block deck, if the issue isn't massively bad it is possible just shim them up over so that the liners are protruding by the right 0.14ish mm amount relative to the deck but stepping up ~ 0.05mm relative to each other towards the rear of the flywheel end. Another way to rectify the issue is either deck the block to 95mm above the liner seats or fit a K series which ironically are bang on reliable in these It might be ok, the guy I sold it to never bled it when he changed the thermostat so maybe if I get it flushed out and bled correctly it'll be fine.
DodgyBastard Posted July 18, 2022 Author Posted July 18, 2022 Look at the head on that! Also spewing steam from the oil breather. Still seems to be running ok. skoda_fan, Split_Pin, Coprolalia and 2 others 2 3
skoda_fan Posted July 19, 2022 Posted July 19, 2022 I get a thrill out of seeing these still in existence especially in the hands of obviously capable owners. On the other hand pix like the one above remind me why, having owned several, I don't want another.
DodgyBastard Posted July 22, 2022 Author Posted July 22, 2022 Ged has been working on his 305 a lot recently in a bid to get it motd for the car meet this Sunday. I dread to think how much time and money he's sunk into it. From replacing all of the braking components, discs, drums, lines to 3D printing moulds to make home made subframe bushes from polyurethane and everything in between. Unfortunately it didn't achieve a clean pass, the interior mirror fell of during the test and the horn stopped working. A couple of holes in the boot floor turned into massive holes after cleaning it back to fresh metal. Colour match is phenomenal with a can of Ford burgundy red. TrabbieRonnie, Mrs6C, RayMK and 10 others 13
DodgyBastard Posted July 23, 2022 Author Posted July 23, 2022 Ged's 305 passed the retest yesterday but broke down a few hours later when the engine consumed its own oil through the air intake... Shit luck, most likely needs another engine. In other news I swapped the unsaleable A3 for a phase 1 306 XRD. Nice enough car, drives fine. Seller failed to mention that the key for the ignition doesn't unlock the doors and there's only 1 key. Ordered a lock set off ebay so not the end of the world. Should hopefully be easier to flog than the Audi although it is quite a nice car so might keep it for a week or two. mk2_craig, Blake's Den, TrabbieRonnie and 20 others 22 1
Poweredbyhopealone Posted July 28, 2022 Posted July 28, 2022 Even with key fuckery you did well out of that deal
DodgyBastard Posted July 28, 2022 Author Posted July 28, 2022 I had a day off work today and with nothing better to do I got stuck into welding the LDV. rust cut out, inner sills patched up followed by the outer sills and runner for the sliding door. Also patched up the front bumper mount as it was hanging off. Only one bit of welding left to do from the mot failure and I'm not sure which part needs done, it says suspension components near side rear cross member but can't find any significant rot. CreepingJesus, LightBulbFun, Split_Pin and 3 others 6
CreepingJesus Posted July 28, 2022 Posted July 28, 2022 Could it be the web on the end of the crossmember that's cracked? Happened on mine and it was quite hard to detect, because it ran perpendicular to the chassis rail (i.e., longitudinally into the crossmember) and was quite near the end. It wasn't rotted out either, it was a stress fracture.
DodgyBastard Posted July 29, 2022 Author Posted July 29, 2022 12 hours ago, CreepingJesus said: Could it be the web on the end of the crossmember that's cracked? Happened on mine and it was quite hard to detect, because it ran perpendicular to the chassis rail (i.e., longitudinally into the crossmember) and was quite near the end. It wasn't rotted out either, it was a stress fracture. Wishful thinking it's the crusty part of the chassis next to where the shock mounts that was easy to access and I've just welded up. Looking at it last night I think it might be the bit behind the rear bumper which looks like a pain in the arse to access. CreepingJesus 1
DodgyBastard Posted July 29, 2022 Author Posted July 29, 2022 I ran out of welding wire last night, the 15kg reel of 0.8mm lasted forever or at least a few years. I found a 5kg reel of 0.6mm I must have bought a while ago but it's too thin to feed through the rollers on my machine, if anyone local shiters have any use for it let me know, free to collect. Split_Pin 1
DodgyBastard Posted July 31, 2022 Author Posted July 31, 2022 garbaldy, CreepingJesus, Split_Pin and 1 other 4
DodgyBastard Posted August 3, 2022 Author Posted August 3, 2022 Is there such a thing as too many bikes? RayMK, rainagain, CreepingJesus and 3 others 6
garbaldy Posted August 3, 2022 Posted August 3, 2022 2 hours ago, DodgyBastard said: Is there such a thing as too many bikes? Nope and as a bonus they're easier to store 😉
DodgyBastard Posted August 14, 2022 Author Posted August 14, 2022 I raffled off a few cars recently, 306 sold out instantly at £20 a go followed by the 205 at the same money. I swapped the Simson Star for a ropey Impreza. I raffled that off too at £20 a go, it made just under £1k in ticket sales so I just gave whatever numbers were left to random people and Ged had the misfortune of winning a car he never bought any tickets for. I went for a run up by Crieff for a monthly MZ meet. Bumped into a couple of bike snobs (not part of the MZ group) who said my bike was ancient and I needed to wash it. I very much wanted to tell them to piss off. Also bumped into someone who attended one of our retro car meets who recognised me and came over for a chat. He was on his bike today but turned up to the meet in this last time and said he'd probably come along on the 28th, nice to have the odd bit of shiny shite on show. Tenmil Socket, dome, AnnoyingPentium and 6 others 9
Split_Pin Posted August 14, 2022 Posted August 14, 2022 His bike was probably clean because it doesn't go fast enough to get dirty. skoda_fan 1
skoda_fan Posted August 14, 2022 Posted August 14, 2022 2 hours ago, DodgyBastard said: Bumped into a couple of bike snobs (not part of the MZ group) who said my bike was ancient and I needed to wash it. I very much wanted to tell them to piss off. You should've done. I hate people like that.
DodgyBastard Posted August 19, 2022 Author Posted August 19, 2022 Nice leisurely drive around Lochearn this afternoon. artdjones, gm, Split_Pin and 18 others 21
DodgyBastard Posted August 21, 2022 Author Posted August 21, 2022 Picked up another top quality motor in Perth then went on a 100 mile drive. Ged's 305 is going well after the engine swap. The 309 came from up in Tain, the guy drove it to Perth this morning. It goes well enough for a 1.9 diesel. Fumbler, LightBulbFun, CreepingJesus and 9 others 12
DodgyBastard Posted August 27, 2022 Author Posted August 27, 2022 Big bore kit fitted on the simson up to a whopping 60cc. Goes surprisingly well! paulplom and CreepingJesus 2
DodgyBastard Posted August 27, 2022 Author Posted August 27, 2022 Also bought a Honda pc50 for £180! Back_For_More, mk2_craig, Split_Pin and 1 other 4
Zelandeth Posted August 28, 2022 Posted August 28, 2022 16 hours ago, DodgyBastard said: Also bought a Honda pc50 for £180! That's a bargain and a half!
DodgyBastard Posted September 19, 2022 Author Posted September 19, 2022 The jawa moped is painfully slow on hills so think I'll be moving it on shortly. Camry failed it's MOT on Friday with 6 bits of welding required, new cat, shock and bushes. LDV has been away for over a month having work done to get it through its MOT, I did a lot of welding on it but just couldn't be arsed doing the rest of the failures. Now that the LDV is coming back with a fresh MOT I towed the Skoda to the same garage for head gasket replacement. AnnoyingPentium, Popsicle, Coprolalia and 5 others 8
jonathan_dyane Posted September 19, 2022 Posted September 19, 2022 How did the Skoda tow? Did the light front end make for any handling difficulties?
